Cisco uBR10012 with MC20X20V line card. Upload speed issues
c.maverley
Hello I really hope someone can help me.
I work with CMTSs by Arris and Casa and Cisco 7200 uBR.
Recently I have been tasked with deploying a uBR10012. I have a problem with upstream performace.
When approx 40 CMs register on an upstream there is no upstream capacity available. Customers are unable to run the upload part of the test on speedtest.net. I see the same issue with my tests and I can't even get as far as a login prompt to my FTP server.
I don't have this issue when 1 CM is registered upload speed is fine and I can make a connection to my FTP server and I don't have this issue on a Casa C2200 with 400CMs registered.
I'm guessing it must be something I'm not fully understanding in the configuration.
My application requires 2 bonded downstreams and no bonded upsteams. I am using 8/0/1 US0,US1 for the physical connections.
Here is the running config:
Building configuration...
Current configuration : 23327 bytes
! Last configuration change at 13:33:41 UTC Wed Jul 22 2015
! NVRAM config last updated at 13:33:46 UTC Wed Jul 22 2015
version 12.2
no service pad
hostname Ubr10k
boot-start-marker
boot-end-marker
enable secret 5 $1$SWHU$4mS2UCI27lWA43STb0T5b/
no aaa new-model
facility-alarm outlet-temperature major 58
facility-alarm outlet-temperature minor 48
facility-alarm intake-temperature major 51
facility-alarm intake-temperature minor 41
card 1 4jacket-1
card 1/0 SPA-1XTENGE-XFP-V2
card 1/1 2cable-dtcc
card 2/1 2cable-dtcc
card 8/0 ubr10k-clc-mc2020v license 20X20
cable admission-control preempt priority-voice
cable service class 1 name resbasicds
cable service class 1 downstream
cable service class 1 max-rate 2048000
cable service class 2 name resbasicus
cable service class 2 upstream
cable service class 2 max-rate 256000
cable service class 3 name resplusds
cable service class 3 downstream
cable service class 3 max-rate 3072000
cable service class 4 name resplusus
cable service class 4 upstream
cable service class 4 max-rate 512000
cable service class 5 name resmaxds
cable service class 5 downstream
cable service class 5 max-rate 4096000
cable service class 6 name resmaxus
cable service class 6 upstream
cable service class 6 max-rate 512000
cable service class 7 name bizbasicds
cable service class 7 downstream
cable service class 7 max-rate 3072000
cable service class 8 name bizbasicus
cable service class 8 upstream
cable service class 8 max-rate 1024000
cable service class 9 name bizplusds
cable service class 9 downstream
cable service class 9 max-rate 6096000
cable service class 10 name bizplusus
cable service class 10 upstream
cable service class 10 max-rate 1024000
cable service class 11 name bizmaxds
cable service class 11 downstream
cable service class 11 max-rate 20480000
cable service class 12 name bizmaxus
cable service class 12 upstream
cable service class 12 max-rate 2048000
cable service class 13 name testds
cable service class 13 downstream
cable service class 13 max-rate 10240000
cable service class 14 name testus
cable service class 14 upstream
cable service class 14 max-rate 2048000
no cable qos permission create
no cable qos permission update
cable qos permission modems
cable util-interval 10
ip subnet-zero
username xxx privilege 15 password 0 xxx
redundancy
 mode sso
controller Integrated-Cable 8/0/0
 rf-channel 0 cable downstream channel-id 169
 rf-channel 0 frequency 273000000 annex B modulation 64qam interleave 32
 rf-channel 0 rf-power 52.0
 rf-channel 0 rf-shutdown
 rf-channel 1 cable downstream channel-id 170
 rf-channel 1 frequency 279000000 annex B modulation 64qam interleave 32
 rf-channel 1 rf-power 52.0
 rf-channel 1 rf-shutdown
 rf-channel 2 cable downstream channel-id 171
 rf-channel 2 frequency 285000000 annex B modulation 64qam interleave 32
 rf-channel 2 rf-power 52.0
 rf-channel 2 rf-shutdown
 rf-channel 3 cable downstream channel-id 172
 rf-channel 3 frequency 291000000 annex B modulation 64qam interleave 32
 rf-channel 3 rf-power 52.0
 rf-channel 3 rf-shutdown
controller Integrated-Cable 8/0/1
 rf-channel 0 cable downstream channel-id 173
 rf-channel 0 frequency 285000000 annex B modulation 64qam interleave 32
 rf-channel 0 rf-power 54.0
 no rf-channel 0 rf-shutdown
 rf-channel 1 cable downstream channel-id 174
 rf-channel 1 frequency 291000000 annex B modulation 64qam interleave 32
 rf-channel 1 rf-power 54.0
 no rf-channel 1 rf-shutdown
 rf-channel 2 cable downstream channel-id 175
 rf-channel 2 frequency 297000000 annex B modulation 64qam interleave 32
 rf-channel 2 rf-power 54.0
 rf-channel 3 cable downstream channel-id 176
 rf-channel 3 frequency 303000000 annex B modulation 64qam interleave 32
 rf-channel 3 rf-power 54.0
controller Integrated-Cable 8/0/2
 rf-channel 0 cable downstream channel-id 177
 rf-channel 0 frequency 621000000 annex B modulation 256qam interleave 128
 rf-channel 1 cable downstream channel-id 178
 rf-channel 1 frequency 627000000 annex B modulation 256qam interleave 32
 rf-channel 2 cable downstream channel-id 179
 rf-channel 2 frequency 633000000 annex B modulation 256qam interleave 32
 no rf-channel 2 rf-shutdown
 rf-channel 3 cable downstream channel-id 180
 rf-channel 3 frequency 639000000 annex B modulation 256qam interleave 32
 no rf-channel 3 rf-shutdown
controller Integrated-Cable 8/0/3
 rf-channel 0 cable downstream channel-id 181
 rf-channel 1 cable downstream channel-id 182
 rf-channel 2 cable downstream channel-id 183
 rf-channel 3 cable downstream channel-id 184
controller Integrated-Cable 8/0/4
 rf-channel 0 cable downstream channel-id 185
 rf-channel 1 cable downstream channel-id 186
 rf-channel 2 cable downstream channel-id 187
 rf-channel 3 cable downstream channel-id 188
interface FastEthernet0/0/0
 ip address 10.1.1.215 255.255.255.0
 media-type rj45
 speed auto
 duplex auto
interface TenGigabitEthernet1/0/0
 no ip address
interface TenGigabitEthernet1/0/0.151
 encapsulation dot1Q 151
 ip address 192.168.2.213 255.255.255.0
interface Cable8/0/0
 downstream Integrated-Cable 8/0/0 rf-channel 0-1 upstream 0
 cable mtc-mode
 no cable packet-cache
 cable default-phy-burst 4096
 cable bundle 1
 cable upstream max-ports 4
 cable upstream bonding-group 1
  attributes 80000000
 cable upstream ranging-poll interval 25000
 cable upstream 0 connector 0
 cable upstream 0 frequency 28300000
 cable upstream 0 channel-width 3200000 3200000
 cable upstream 0 ingress-noise-cancellation 400
 cable upstream 0 power-level 7
 cable upstream 0 description "South-Horizontal 273 & 279 Red"
 cable upstream 0 docsis-mode tdma
 cable upstream 0 minislot-size 2
 cable upstream 0 range-backoff 3 6
 cable upstream 0 modulation-profile 21
 cable upstream 0 equalization-coefficient
 cable upstream 0 rate-adapt priority 6 rate 30000000
 no cable upstream 0 shutdown
 cable upstream 1 connector 1
 cable upstream 1 frequency 41500000
 cable upstream 1 channel-width 6400000 6400000
 cable upstream 1 ingress-noise-cancellation 400
 cable upstream 1 maintain-psd
 cable upstream 1 docsis-mode atdma
 cable upstream 1 minislot-size 4
 no cable upstream 1 concatenation
 cable upstream 1 range-backoff 3 6
 cable upstream 1 modulation-profile 221
 cable upstream 1 equalization-coefficient
 cable upstream 1 rate-adapt priority 6 rate 30000000
 cable upstream 1 shutdown
 cable upstream 2 connector 2
 cable upstream 2 frequency 48000000
 cable upstream 2 channel-width 6400000 6400000
 cable upstream 2 ingress-noise-cancellation 400
 cable upstream 2 maintain-psd
 cable upstream 2 docsis-mode atdma
 cable upstream 2 minislot-size 4
 no cable upstream 2 concatenation
 cable upstream 2 range-backoff 3 6
 cable upstream 2 modulation-profile 221
 cable upstream 2 equalization-coefficient
 cable upstream 2 rate-adapt priority 6 rate 30000000
 cable upstream 2 shutdown
 cable upstream 3 connector 3
 cable upstream 3 frequency 54500000
 cable upstream 3 channel-width 6400000 6400000
 cable upstream 3 ingress-noise-cancellation 400
 cable upstream 3 maintain-psd
 cable upstream 3 docsis-mode atdma
 cable upstream 3 minislot-size 4
 no cable upstream 3 concatenation
 cable upstream 3 range-backoff 3 6
 cable upstream 3 modulation-profile 221
 cable upstream 3 equalization-coefficient
 cable upstream 3 rate-adapt priority 6 rate 30000000
 cable upstream 3 shutdown
interface Cable8/0/1
 description "xxxxxxxxxxxxxxxx"
 downstream Integrated-Cable 8/0/1 rf-channel 0-1 upstream 0-1
 no cable mtc-mode
 cable bundle 2
 cable upstream 0 connector 4
 cable upstream 0 power-level 3
 cable upstream 0 description "xxxxxxxxxxxx"
 cable upstream 1 connector 5
 cable upstream 1 frequency 37900000
 cable upstream 1 channel-width 3200000 3200000
 cable upstream 1 power-level 3
 cable upstream 1 description "xxxxxxxxxxxx"
 cable upstream 1 docsis-mode tdma
 cable upstream 1 minislot-size 2
 cable upstream 1 modulation-profile 21
 no cable upstream 1 shutdown
 cable upstream 2 connector 6
 cable upstream 2 frequency 12540000
 no cable upstream 2 shutdown
 cable upstream 3 connector 7
 cable upstream 3 frequency 18940000
 no cable upstream 3 shutdown
interface Cable8/0/2
 shutdown
 downstream Integrated-Cable 8/0/2 rf-channel 0-3
 cable mtc-mode
 cable bundle 3
  upstream 0
  upstream 1
  upstream 2
  upstream 3
  attributes 80000000
 cable upstream 0 connector 8
 cable upstream 0 frequency 25340000
 cable upstream 0 channel-width 6400000 6400000
 cable upstream 0 power-level 5
 cable upstream 0 maintain-psd
 cable upstream 0 docsis-mode atdma
 cable upstream 0 minislot-size 4
 cable upstream 0 modulation-profile 221
 cable upstream 1 connector 9
 cable upstream 1 frequency 31740000
 cable upstream 2 connector 10
 cable upstream 2 frequency 38140000
 cable upstream 3 connector 11
 cable upstream 3 frequency 44540000
interface Cable8/0/3
 shutdown
 downstream Integrated-Cable 8/0/3 rf-channel 0-3
 cable mtc-mode
 cable bundle 4
 cable upstream bonding-group 4
  upstream 0
  upstream 1
  upstream 2
  upstream 3
  attributes 80000000
 cable upstream 0 connector 12
 cable upstream 0 frequency 44540000
 cable upstream 1 connector 13
 cable upstream 1 frequency 50940000
 cable upstream 2 connector 14
 cable upstream 2 frequency 5734000
 cable upstream 3 connector 15
 cable upstream 3 frequency 6374000
interface Cable8/0/4
 shutdown
 downstream Integrated-Cable 8/0/4 rf-channel 0-3
 cable mtc-mode
 cable bundle 5
 cable upstream bonding-group 5
  upstream 0
  upstream 1
  upstream 2
  upstream 3
  attributes 80000000
 cable upstream 0 connector 16
 cable upstream 0 frequency 7014000
 cable upstream 1 connector 17
 cable upstream 1 frequency 7654000
 cable upstream 2 connector 18
 cable upstream 2 frequency 8294000
 cable upstream 3 connector 19
 cable upstream 3 frequency 8934000
interface Integrated-Cable8/0/0:0
 cable bundle 1
 cable rf-bandwidth-percent 25
interface Integrated-Cable8/0/0:1
 cable bundle 1
interface Integrated-Cable8/0/0:2
interface Integrated-Cable8/0/0:3
interface Integrated-Cable8/0/1:0
 cable bundle 2
 cable rf-bandwidth-percent 50
interface Integrated-Cable8/0/1:1
 cable bundle 2
interface Integrated-Cable8/0/1:2
 no cable rf-bandwidth-percent
interface Integrated-Cable8/0/1:3
interface Integrated-Cable8/0/2:0
 cable bundle 3
interface Integrated-Cable8/0/2:1
 cable bundle 3
interface Integrated-Cable8/0/2:2
 cable bundle 3
interface Integrated-Cable8/0/2:3
 cable bundle 3
interface Integrated-Cable8/0/3:0
 cable bundle 4
interface Integrated-Cable8/0/3:1
 cable bundle 4
interface Integrated-Cable8/0/3:2
 cable bundle 4
interface Integrated-Cable8/0/3:3
 cable bundle 4
interface Integrated-Cable8/0/4:0
 cable bundle 5
interface Integrated-Cable8/0/4:1
 cable bundle 5
interface Integrated-Cable8/0/4:2
 cable bundle 5
interface Integrated-Cable8/0/4:3
 cable bundle 5
interface Wideband-Cable8/0/0:1
 cable bundle 1
 cable rf-channel 0 bandwidth-percent 25
 cable rf-channel 1 bandwidth-percent 25
 cable rf-channel 2 bandwidth-percent 25
 cable rf-channel 3 bandwidth-percent 25
interface Wideband-Cable8/0/1:1
 cable bundle 2
 cable rf-channel 0 bandwidth-percent 50
 cable rf-channel 1 bandwidth-percent 50
interface Wideband-Cable8/0/2:1
 cable bundle 3
interface Wideband-Cable8/0/3:1
 cable bundle 4
interface Wideband-Cable8/0/4:1
 cable bundle 5
interface Bundle1
 description "xxxxx
 ip address 172.21.12.1 255.255.252.0 secondary
 ip address 172.26.10.1 255.255.254.0 secondary
 ip address 192.168.120.1 255.255.252.0
 cable arp filter request-send 3 2
 cable arp filter reply-accept 3 2
 cable dhcp-parse option-43
 cable dhcp-giaddr policy
 cable helper-address 10.1.1.51 cable-modem
 cable helper-address 10.1.1.68 host
 cable helper-address 10.1.1.79 mta
interface Bundle2
 description "xxxxx"
 ip address 172.21.34.1 255.255.255.0 secondary
 ip address 172.26.6.1 255.255.254.0 secondary
 ip address 192.168.78.1 255.255.254.0
interface Bundle3
 description "East"
 no ip address
interface Bundle4
 no ip address
interface Bundle5
 no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.211
no ip http server
no ip http secure-server
logging cmts ipc-cable log-level errors
logging cmts sea syslog-level errors
cpd cr-id 1
nls resp-timeout 1
snmp-server community private RO
snmp-server manager
control-plane
alias exec scm show cable modem
alias exec ccm clear cable modem
alias exec sic show int cable
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password 1234
 login
 international
line vty 5 15
 login
scheduler isr-watchdog
cable fiber-node 1
 upstream Cable 8/0 connector 0-3
cable fiber-node 2
 upstream Cable 8/0 connector 4-5
cable fiber-node 3
cable fiber-node 4
cable fiber-node 5
ntp clock-period 17180145
ntp server 10.1.1.51
end
Thanks in advance,
Chris.
0 Replies 0
