Showing results forĀ
Search instead forĀ
Did you mean:Ā
GPS issue in ASR9K
twanaothman
Dears,
I have ASR 9K with RSP board type of (A9K-RSP880-SE)  and GPS ports (1PPS, 10MHz and RS232) are connected to the RSP board but the GPS light in the RSP isn't turning up.
Your suggestion is highly appricated.
twanaothman
I have doubt that GPS should be configured first, any thought ? please
clock-interface sync 2 location 0/RSP0/CPU0
port-parameters
gps-input tod-format gprmc pps-input ttl
frequency synchronization
selection input
priority 2
wait-to-restore 0
ssm disable
quality receive exact itu-t option 2 generation 2 PRS
