02-12-2017 05:01 AM - edited 03-01-2019 03:05 PM
I have a cisco 2600 router.
I have /27 public Ip Pool which has been provided by my Isp
Link Speed 25mbps
I want to assign 5mbps to one of the public ip address and remaining 20 mbps should be shared among remaining IP addresses
02-21-2020 04:43 PM
05-20-2021 10:31 AM - edited 05-21-2021 10:14 AM
@Francesco Molino Dear Fran
can you plz help me to solve a simple issue i am getting a direct link from the provider PE which means direct Public to my laptop for test purpose, i can reach internet throw ping only i can ping any address but no browsing ?!!!
any suggestions !
05-21-2021 02:11 PM
Don't understand the sketch you've done.
On your router you're defining a static route with your laptop as next-hop?
Internet link is on the router? Can you detail a bit what you're trying to do?
05-21-2021 04:10 PM - edited 05-21-2021 04:59 PM
Sketch is very simple
Yes vrf static route
Yes internet link from the Provider Edge directly connected to my laptop , i can ping to any website but i can not browse.
