Pankaj Palyekar
Beginner
How to route public IP and assign particulr speed on same routed public Ip
I have a cisco 2600 router.
I have /27 public Ip Pool which has been provided by my Isp
Link Speed 25mbps
I want to assign 5mbps to one of the public ip address and remaining 20 mbps should be shared among remaining IP addresses
18 REPLIES 18
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
@Francesco Molino  Dear Fran
can you plz help me to solve a simple issue i am getting a direct link from the provider PE which means direct Public to my laptop for test purpose,  i can reach internet throw ping only i can ping any address but no browsing ?!!!
any suggestions !
Don't understand the sketch you've done.
On your router you're defining a static route with your laptop as next-hop?
Internet link is on the router? Can you detail a bit what you're trying to do?
Francesco
Sketch is very simple
Yes vrf static route
Yes internet link from the Provider Edge directly connected to my laptop ,   i can ping to any website but i can not browse.
