Multicast stream not being forwarded to reciever in switched environment
ehammons1
Scenario:
Trying to pull a raw MC stream. no upstream router
-The source is sending the MC stream. The port is incrementing MC packets but the source port isnt forwarding the packets to the reciever attached to a different port.
-IGMP snooping is enabled. But there appears to be a valid join request from the receiver
-The source is a raw MC stream...no upstream router
-running a VLAN - it's the RP/ Rendezvous Point...its running PIM spare mode
- IGMP snooping is on and working for many other MC streams
- terminated directly in the VLAN
-the Cisco 4948 looks like it knows our DCM wants the stream
Vlan39 is up, line protocol is up
  Internet address is 172.20.9.14/24
  IGMP is enabled on interface
  Current IGMP host version is 2
  Current IGMP router version is 3
  IGMP query interval is 60 seconds
  IGMP configured query interval is 60 seconds
  IGMP querier timeout is 120 seconds
  IGMP configured querier timeout is 120 seconds
  IGMP max query response time is 10 seconds
  Last member query count is 2
  Last member query response interval is 1000 ms
  Inbound IGMP access group is not set
  IGMP activity: 246 joins, 187 leaves
  Multicast routing is enabled on interface
  Multicast TTL threshold is 0
  Multicast designated router (DR) is 172.20.9.14 (this system)
  IGMP querying router is 172.20.9.14 (this system)
  Multicast groups joined by this system (number of users):
      224.0.1.40(1)
 #show ip igmp snooping querier
Vlan      IP Address        IGMP Version   Port
39        172.20.9.14       v3             Router
chrihussey
More information may be helpful. Could you supply a sanitized config?
