Optical received/transmit power Cisco GSR12K
sumit menaria
Hi Guys,
I am unable to find the optical received and transmit power on my interfaces a Cisco 12K box running below version.
IOS (tm) GS Software (C12KPRP-K4P-M), Version 12.0(33)S10, RELEASE SOFTWARE (fc1)
Hardware details are as below.
NAME: "Chassis", DESCR: "12410/PRP chassis, Hw Serial#: TBA09310138, Hw Revision: 0x00"
PID: 73-5318-3 rev 80 dev 0, VID: 0x00, SN: TBA09310138
NAME: "slot 29", DESCR: "GSR 12410 Fan tray"
PID: 800-5574-01 rev A0 dev 62379, VID: 1.0, SN: CAT08130WCM
NAME: "slot 0", DESCR: "4 port Edge Engine3 Gigabit Ethernet"
PID: 800-22811-06 rev A0 dev 0, VID: V00, SN: SAL09253HRH
NAME: "slot 2", DESCR: "1 port ISE OC12 Channelized to DS1/E1"
PID: CHOC12/DS1-SM-IR , VID: V00, SN: SAD092609NG
NAME: "slot 3", DESCR: "ISE 10G Modular Services Card v2"
PID: 12000-SIP-601 , VID: V04, SN: SAD1214050C
NAME: "SPA subslot 3/0", DESCR: "1-port 10 Gigabit Ethernet Shared Port Adapter XFP based"
PID: SPA-1XTENGE-XFP , VID: V03, SN: JAE1213CBWO
NAME: "subslot 3/0 transceiver 0", DESCR: "OC192 + 10GBASE-L"
PID: 10-1989-02XFP , VID: 02 , SN: ONT121110DX
NAME: "slot 4", DESCR: "ISE 10G Modular Services Card v2"
PID: 12000-SIP-601 , VID: V04, SN: SAD121404Y3
I tried using
1)show controllers interface gi4/0/0
2)show interface gi4/0/0 controllers
3)show module (does not run)
sumit menaria
Alright just found out :)
router#show hw-module subslot 4/0 transceiver 0 status
The Transceiver in slot 4 subslot 0 port 0 is enabled.
Module temperature = 32.199 C
Transceiver Tx bias current = 70780 uAmps
Transceiver Tx power = 2 dBm
Transceiver Rx optical power = -3 dBm
