problem in cellular interface
ahmedabdelbaqi
Dears
we have Cisco ISR 1100
c1100-universalk9_ias.16.09.02.SPA.bin
we have problem on Cellular interface
it is working at startup normally , but suddenly it goes down and we get the following log
%FMFP-3-OBJ_DWNLD_TO_DP_FAILED: R0/0: fman_fp_image: PORTLIST: (tcp/10.138.48.39 port 5062 - 6085) download to DP failed
you can see the port status when it is up and logs and when it is down
sh int cellular 0/2/0
Cellular0/2/0 is up, line protocol is up
Hardware is LTE Adv CAT6 - Multimode LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS
Description: Primary_
Internet address is 10.138.48.39/32
MTU 1500 bytes, BW 50000 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive not supported
DTR is pulsed for 1 seconds on reset
Time to interface disconnect: idle 00:01:46
Last input never, output 00:00:13, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
20 packets input, 1993 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
29 packets output, 1962 bytes, 0 underruns
0 unknown protocol drops
0 carrier transitions
*May 12 10:06:13.872: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*May 12 10:06:13.892: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NTP, can be obtained.
*May 12 10:06:13.964: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*May 12 10:06:38.376: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing.
*May 12 10:06:38.377: %SMART_LIC-5-COMM_RESTORED: Communications with the Cisco Smart Software Manager or satellite restored
*May 12 10:07:19.067: %CELLWAN-6-SIM_PRESENT: [Cellular0/2/0]: SIM is present in Slot 1
*May 12 10:07:19.067: %CELLWAN-5-SIM_DETECT_COMPLETE: [Cellular0/2/0]: SIM presence detection has completed !!
*May 12 10:08:24.632: %CELLWAN-2-MODEM_UP: Modem in slot 0/2 is now UP
*May 12 10:08:24.833: %CELLWAN-2-MODEM_RADIO: Cellular0/2/0 Modem radio has been turned on
*May 12 10:09:00.334: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to up
*May 12 10:09:01.334: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/2/0, changed state to up
*May 12 10:20:18.098: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to down
*May 12 10:20:19.098: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/2/0, changed state to down
*May 12 10:20:58.471: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: R0/0: fman_fp_image: PORTLIST: (tcp/10.138.48.39 port 5062 - 6085) download to DP failed
*May 12 10:21:00.457: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to up
*May 12 10:21:01.457: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/2/0, changed state to up
*May 12 10:31:28.948: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to down
*May 12 10:31:29.949: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/2/0, changed state to down
*May 12 10:39:12.234: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: R0/0: fman_fp_image: PORTLIST: (tcp/10.138.48.39 port 5062 - 6085) download to DP failed
*May 12 10:39:14.224: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to up
*May 12 10:39:15.224: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/2/0, changed state to up
*May 12 10:41:18.388: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to down
*May 12 10:41:19.387: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/2/0, changed state to down
*May 12 10:46:33.161: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: R0/0: fman_fp_image: PORTLIST: (tcp/10.138.48.39 port 5062 - 6085) download to DP failed
*May 12 10:46:35.152: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to up
*May 12 10:46:36.152: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/2/0, changed state to up
Cellular0/2/0 is up (spoofing), line protocol is up (spoofing)
Internet address will be negotiated using IPCP
Last input 00:13:17, output 00:03:07, output hang never
72 packets input, 6845 bytes, 0 no buffer
97 packets output, 6393 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
Giuseppe Larosa
Hello Ahmed,
looking for error message %FMFP-3-OBJ_DWNLD_TO_DP_FAILED:  there are several Cisco bugs that appear.
I would suggest to perform a software upgrade to see if the problem will be fixed
Hope to help
Giuseppe
Problem ended up being a VZ issue on this ISR i have several WAN interfaces once being a comcast ip which has a icmp SLA. When the probes get sent out and the LTE cell interface is the default route, VZ see's a non VZ sourced IP which causes a violation on their end and VZ drops the connection. The problem is the returned VZ error wasn't that descriptive. In order to fix this issue anything going out the LTE cell interface must be sourced from a VZ ip or you need to NAT all ips to the cell interface. Hopefully this helps someone. FYI this source violation only happens with VZ LTE, it doesnt affect other carriers.
Thanks, Paul
#sh cellular 0/2/0 connection call-history
Start Time Stop Time Duration
Mon Jul 29 11:38:17 2019 Mon Jul 29 11:43:15 2019 298 seconds
Call disconnect reason
Call end mode =
Session disconnect reason type = (0)
Session disconnect reason = (0)
Mon Jul 29 11:43:47 2019 Mon Jul 29 11:48:45 2019 298 seconds
Call end mode = 3GPP
Session disconnect reason type = 3GPP specification defined(6)
Session disconnect reason = Regular deactivation(36)
Mon Jul 29 11:49:17 2019 Mon Jul 29 11:54:15 2019 298 seconds
paul amaral
Level 4
Level 4
did you find a solution for this? im having a similar issue.
thanks, Paul
JoeSemos27769
Hope you can get your solution for the given problem
