ctioko
Beginner
SCE Bootup Problem
Hi Guys I have an SCE 2000 which failed after installation. the problem is i cant get access through the console, it does not respond. when i get access through the AUX port, the first prompt is [VxWorks Boot] if i try to reboot it gives the error cant load bootfile.
kindly assist
5 REPLIES 5
Gustavo Paiva
Beginner
Hi everybody,
This is an old post, but I have the same problem... somebody knows how to boot the SCE from the VxWorks console?
Gustavo.
Hi Gustavo,
Did you get an answer to this problem?
I have the same problem !!!
First you need is a file named "SEos"... I looked for this file in the download area of Cisco could not find it.
Then the procedure is very similar to others using VxWorks...
Gustavo.
miroslav.slavkov
Beginner
If you have a running box, you can extract the OS file and boot it with TFTP.
The file name is 'seos'.
Hi, I have the same issue, but the network card doesnt boot, how can I get the management Ethernet interface to come up in the VX works boot mode so I can copy the seos file from another working device?
Content for Community-Ad
