11-28-2008 04:42 AM - edited 03-01-2019 02:09 PM
Hi Guys I have an SCE 2000 which failed after installation. the problem is i cant get access through the console, it does not respond. when i get access through the AUX port, the first prompt is [VxWorks Boot] if i try to reboot it gives the error cant load bootfile.
kindly assist
11-27-2009 05:17 AM
Hi everybody,
This is an old post, but I have the same problem... somebody knows how to boot the SCE from the VxWorks console?
Gustavo.
02-04-2010 02:14 PM
Hi Gustavo,
Did you get an answer to this problem?
I have the same problem !!!
02-05-2010 04:23 AM
First you need is a file named "SEos"... I looked for this file in the download area of Cisco could not find it.
Then the procedure is very similar to others using VxWorks...
Gustavo.
06-30-2010 06:25 AM
If you have a running box, you can extract the OS file and boot it with TFTP.
The file name is 'seos'.
09-30-2011 07:58 AM
Hi, I have the same issue, but the network card doesnt boot, how can I get the management Ethernet interface to come up in the VX works boot mode so I can copy the seos file from another working device?
