Showing results forĀ
Search instead forĀ
Did you mean:Ā
xmodem console download procedure using rommon for cisco 7604
khaelmogsby
Community Member
Good day to you all,
I have a cisco 7604 router, and it stuck  in Rommon mode, I cannot go with the TFTP server to upload the IOS image, so the other solution is to use xmodem, however, I could not success in that and I do not know any other solution for the problem. Any suggestions and thanks in advanced.
Leo Laohoo
Why are you failing?  What error message are you getting?
The attached pictures are the command that I applied and the output I got
