I have some AP 1100 and 1200 that shows 100% busy channel from 6 to 11 everytime.
Is there anybody with the same problem?
I tried to disconnect the radio alarms close to AP but there are still interferences.
Any suggests?
Thanks in advance
Antonio
Antonio,
The only way to be sure of what's happening is to get a Spectrum Analyser.
Richard
As stated before,get a spectrum analyzer. Turn off G and use B only and see if the percentage goes down.
If you do not have access to a real spectrum analyzer and/or one is too expensive, get a WiSpy from http://www.metageek.net/
They are cheap and give a good idea of channel usage, but are not a substitute for a full blown analyzer. To what it looks like:
http://www.metageek.net/products/chanalyzer/chanalyzer-21-screenshots
