Highlighted
Beginner
1131 AG lap keeps locking up.
I have a Cisco 2100 with 16 1131 AG LAP's.  Every few days an AP seems to lock up and lose connection to the controller.  This has happened a few times with various methods to fix.  I either reboot the AP, reboot the controller or reboot the switch and then the controller.
Does anybody know why this may be happening?
I have instaaleda similar setup on various other sites and have had no issues.
All help greatly appreciated.
9 REPLIES 9
Highlighted
wat does the logs on the WLC say?? or debug say?
Surendra
Surendra BG
Highlighted
I will post the logs ASAP.  It is a remote site with no remote access so will physically have to go to site to retrieve.
Thanks for the quick reply.
Highlighted
Hall of Fame Community Legend
Better yet, what does the log say ON THE AP?
Highlighted
AP logs attached.
Thanks for your help.
Highlighted
Log files attached
Many thanks
Highlighted
Enthusiast
Power issues?
Why dont you check mac-address activity in nthe port where AP is connected... What about cabling... hmnnmmm
Highlighted
Cabling is fine..  Brand new cabling install for these Ap's.  Brand new switch installed also.  Do you mean check the port on the switch?
Cheers
Highlighted
I'm not buying this.  We purchased 1k straight-through cable for our wireless rollout.  The manufacturer claims that the cables were "tested".  Suuuuuuuuuuure.  We suffered 10% failure rate.
Lucky for us all our switches are 2960 because we run TDR testing on all the links just to make sure.
Highlighted
Right, even if it is brannd new, test the cable...
You never knnow... even power issues
Content for Community-Ad
