05-03-2011 08:33 AM - edited 07-03-2021 08:09 PM
Using an 1142 in a stand a lone environment, (I changed the default firmware to the stand alone) - how do I also set up security to support a MAC address along with WPA2 Personal?
05-03-2011 08:39 AM
here is the link to configure WPA2 on the AP..
Lemme know if this answered ur question!!
Surendra
05-03-2011 08:51 AM
Actually I see WPA, but I don’t see where to enable MAC level security.
Michael
05-03-2011 08:56 AM
Here is the link to do MAC auth
and MAC filtering..
lemme know if this answered ur question!!
Surendra
05-03-2011 09:38 AM
What I am trying to do is to set up security on my home 1142. I currently have a Linksys router (AP) using WPA2 (pre-shared key) and also MAC filtering. I am trying to do the same with the 1142.
If I can do RADIUS, etc, then that is cool also, just looking for a secure AP. NOTE: I would need to leverage the APs RADIUS server, if it has one, etc.
05-03-2011 05:38 PM
use the ASSOCIATION ACCESS LIST option...
05-06-2011 06:28 AM
MAC filiter is pretty easy to break by spoofing it, just an FYI.
05-06-2011 07:28 AM
Thanks for the details guys.
As a note, to spoof the MAC, dont you need to know what to spoof though? So with MAC filtering and WPA2 Personal, I woudl think this is pretty secure.
Michael
