1230 Series LAP and WCS 6.0.199.0 Heatmap Problem
drakow
I recently upgraded from WLC 4.2.207.0 to 6.0.199.0 (WiSM), and WCS 5.2.130.0 to 6.0.196.0. All my heatmaps that contain 1231G LAPs are solid "maroon" (-35 dBm) in color. If I remove the 1231 APs from the heatmap selection on the right hand side, my coexisting 1131 and 1142's display their heatmaps properly. My maps are all CAD format (dwg) converted to .png's using WCS. My goal is to migrate to 802.11n in small steps which our Cisco rep said we could do. Any ideas?
rob.drye
Unfortunately, this is a bug in 6.0.199.0.  The "fix" is to upgrade to 7.0.98.0 or 6.0.199.4.  As you figured out, it only affects 1230 series APs, and only on the 802.11b/g side.  Bug ID was
CSCti05687
Incorrect power unit was used on AIR-AP1231G-A-K9 and IR-AP1220-IOS-UPGRD.
