1230AG non-root bridge not associating
steinmetzssj
Hello everyone,
I am new at setting up root and non-root bridges. I am trying to set-up three 1230ag devices.
One as the root and the othe two as non-root, I copied the config txt from the root and
copied that into the two I am going to use for the non-root. That way the ssid's are the
same. When I set the role to non-root the radio is not enabled and I get a message saying
Interface Dot11Radio0,cannot associate:No Response
Does any know what I am doing wrong, and how to fix it
jeff.kish
Level 7
Level 7
The radio interface will go down in response to being configured as a non-root bridge, so that much is working.  But there must be a configuration error if it won't associate.  Can you post the configs so we can review them?
Are the bridges mounted, or are they on your desk?
Right now they are on my desk, But even when they are mounted they still don't associate
The attached files are for the root and non-root bridges.
Thanks for your help.
Steve
