09-08-2011 06:47 AM - edited 07-03-2021 08:44 PM
I am in need of assistance with one of our autonomous 1252APs. It loses network connectivity irregularly and ends up disconnecting everyone. It may stay up from a few days to a few weeks. I don't see any log messages that give any clues to why it is doing this. We have 30 of these working worldwide (on the same software level and same config) and this is the only one having the problem.
Things I have tried:
I had a few cases open with TAC, and they were unable to find anything wrong - gave them sh techs of prior to the event and after the event. It was one of those where the tickets were open for a weeks with no updates.
I am wondering... could a client cause this? Any other ideas as to what I should try?
Any assistance would be wonderful!
Lily
09-08-2011 06:54 AM
Did we change the switchport on the Switch and test once?? in the mean time send "show tech" from the AP and Switchport on which the AP is connected running config, Native VLAN on the Switch and AP..
Surendra
09-08-2011 07:09 AM
No, we never looked at the switchport config. Is there a way for me to send the sh tech and sh run attachments to you without having to go through the config and X things out?
09-08-2011 07:20 AM
u can test by changing the switchport.. n u can post the configs here by attaching!!
Surendra
09-08-2011 10:00 AM
I just eanted to know why w=do we have 40 and 18 as native on the switch?? it should be just one VLAN acting as the Native right??
Is this the way rest all APs are installed??
Surendra
09-08-2011 01:15 PM
Hi Surendra,
This is how the other APs and switches are setup at this site.
Lily
09-13-2011 10:53 AM
Hi Surendra,
I changed the switchport the AP was connected to on Friday and it just had the issue. Do you have any other suggestions as to what I should try?
Lily
01-24-2012 08:36 AM
Seems like the same problem I have experienced. usually after reboot 1252 AP sometimes loses all layer 3 communication with switch the AP appears in CDP Neightbours but no IP address is shown in detail (IP address is statically set on AP). The AP still broadcasts SIDD's but no network communication is possible for clients further reboots sometimes fix this but often a factory reset is required which is not easy as AP's are in ceiling did you get to the bottom of the problem I've tried different firmware but so far nothing is fixing this issue (it is sporadic and some of my sites have never experienced this issue but the same template configs are used globally)
01-24-2012 01:30 PM
Hi Stuart,
1. This issue is affecting SOME of your WAPs and not all, is this correct?
2. When the WAPs disconnects the clients, can you still see or manage the WAP?
3. What are in the logs of the WAPs?
4. Can you check the WAP's flash if there are any "crashinfo" files/sub-directory? If there are, can you please post the latest three?
01-24-2012 01:41 PM
Hi Stuart,
I was never able to get an answer from Cisco TAC. What I ended up doing was rolling back to a previous software level, one that was stable prior to the flakiness happening. It sounds like you've tried multiple code levels... not sure if you've tried any that used to be stable for you.
Good luck!
Lily
