1310 bridge alignment using the outdoor wallmount kit?
martnord05
How flexible is the outdoor mast/wallmount kit when it comes to alignment of two 1310 bridges point-2-point? I mean it is rather useful to be able to adjust the bridges both vertically and horisontally to some extent, especially when using the internal antenna.
MATTHEW BALYUZI
It's been a while since I installed one of these, but I don't remember having any problems adjusting alignment in either direction.
Horizontally it rotates about the pole, and vertically there is angle adjustment within the bracket. When it's at the right angle you do the bolts up tight. Ours are pointing about ten degrees off vertical and this was not a problem to achieve.
