1310 LAP unable to join WLC 5508
ahmedbishry
Hi All,
Hope to you a very happy new year,
I have an (AIR-LAP1310G-E-K9R) and I tried to join it to WLC 5508 but I'm facing an error,
I get this error from the LAP 1310 console as below:
Compiled Mon 17-Jul-06 11:45 by alnguyen
*Mar  1 00:00:05.289: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:06.289: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:23.337: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:33.477: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.114.36.25, mask 255.255.255.0, hostname APe4d3.f1c2.8882
examining image...
*Mar  1 00:00:44.781: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Jan 11 15:21:37.178: %LWAPP-5-CHANGED: LWAPP changed state to IMAGE
%Error opening  (Protocol error)archive download: takes 6 seconds
*Jan 11 15:21:43.178: LWAPP_CLIENT_ERROR_DEBUG:  Retransmission count for packet exceeded more than max(IMAGE_DATA
, 1)
*Jan 11 15:21:43.178: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Jan 11 15:21:43.179: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Jan 11 15:21:43.181: LWAPP_CLIENT_ERROR: not receive read response(3)
*Jan 11 15:21:43.185: lwapp_image_proc: unable to open tar file
*Jan 11 15:21:43.200: %SYS-5-RELOAD: Reload requested by lwapp image download proc. Reload Reason: Reason unspecified.
*Jan 11 15:21:43.201: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
*Jan 11 15:21:43.207: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERYXmodem file system is available.
flashfs[0]: 3 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1861632
flashfs[0]: Bytes available: 5879808
flashfs[0]: flashfs fsck took 14 seconds.
Base ethernet MAC Address: e4:d3:f1:c2:88:82
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1310-rcvk9w8-mx/c1310-rcvk9w8-mx"...#######################################################################################################################################################################
File "flash:/c1310-rcvk9w8-mx/c1310-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1310 Software (C1310-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Image text-base: 0x00003000, data-base: 0x00359EA0
Initializing flashfs...
flashfs[1]: 3 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 1861632
flashfs[1]: Bytes available: 5879808
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-LAP1310G-E-K9R   (PowerPCElvis) processor (revision B0) with 24566K/8192K bytes of memory.
Processor board ID FGL1649T00U
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from reload
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: E4:D3:F1:C2:88:82
Part Number                          : 73-8960-09
PCA Assembly Number                  : 800-24963-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC16447J1K
Top Assembly Part Number             : 800-28479-05
Top Assembly Serial Number           : FGL1649T00U
Top Revision Number                  : D0
Product/Model Number                 : AIR-LAP1310G-E-K9R
Press RETURN to get started!
*Mar  1 00:00:04.329: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:33.352: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.114.36.28, mask 255.255.255.0, hostname APe4d3.f1c2.8882
examining image...
*Mar  1 00:00:44.783: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Jan 11 15:21:37.189: %LWAPP-5-CHANGED: LWAPP changed state to IMAGE
*Jan 11 15:21:43.189: LWAPP_CLIENT_ERROR_DEBUG:  Retransmission count for packet exceeded more than max(IMAGE_DATA
, 1)
*Jan 11 15:21:43.189: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Jan 11 15:21:43.192: LWAPP_CLIENT_ERROR: not receive read response(3)
*Jan 11 15:21:43.195: lwapp_image_proc: unable to open tar file
*Jan 11 15:21:43.210: %SYS-5-RELOAD: Reload requested by lwapp image download proc. Reload Reason: Reason unspecified.
*Jan 11 15:21:43.210: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
*Jan 11 15:21:43.216: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERYXmodem file system is available.
Reset done!
Please Advise,
Thanks in advanced,
Ahmed,
Usually the release notes keep saying that it is not supported, but actually I never had a problem with it.
Of course you will lose all the configuration that is specific to 7.2, and you could run into problems if you are using flexconnect settings, because before 7.2 this feature used to be called hreap.
So I strongly recommend to backup your configuration before doing the downgrade. If your configuration is not too complex, it could be a good idea to do the upgrade, reset your wlc to factory settings, and reconfigure your controller.
regards
Stefan
11 Replies 11
stefan.angerer
Ahmed,
on which code version is your 5500 running?
The 1300 bridges are only supported until 7.0.x as you can see in the WLC release notes:
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn73.html#wp976967
regards
Stefan
Dear Stefan,
Many thanks for your kind reply,
Please find the information below:
Controller Summary
Management IP Address10.114.44.131
Service Port IP Address
10.114.23.20
Software Version7.2.111.3
Field Recovery Image Version 6.0.182.0
System NameCIR906.WLC.5508
Please Advise,
Ahmed,
Your WLC needs to be on 7.0 code. 7.2 and above isnt supported.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Dear George,
Is there is any workaround solution?
Because I have another LAP (AIR-LAP1261N-E-K9) and it not able to work with the old version,
Please advise,
Ahmed,
It depends on the number of APs, but maybe if you have just a few of the 1300s, maybe you could run them in autonomous mode without a WLC?
regards
Stefan
Dear Stefan,
I will try to think of this option,
But I really appreciate if there is any workaround solution to join these LAP to the WLC,
Please Advise,
Ahmed,
If you only have legacy APs (basically all except 1600, 2600,3600) then you could downgrade to 7.0.
The 1260 series is supported with 7.0.
Stefan
Dear Stefan,
I will try to do the downgrade, is there any concern about this downgrade,
Please advise for the best steps to do this downgrade, because this is my first time to do a downgrade,
Ahmed,
regards
Stefan
How many 1300 do you have?
If you have a little funds, you can look for 4402/4404 to run legacy APs.  Because the 4400 is already End-of-Sale, you could find traded-in units from Cisco Refurbished.
Dear Leolaohoo,
Many thanks for your great advise,
I believe you are right,
Ahmed,
