Highlighted
Beginner
1522 Connectivity Issue
Hi There,
I have 4404 WLC running 5.2,I have connected this WLC to a switch using LAG.My AP and WLC are on seprate segment.For illustration i can say Controller is on 192.168.50 and all my ap are on 142.240.83.0,Now 35 of my ap's connect to controller(i am sending dhcp option 43),but 6 of my ap's do not connect but if change the segment for these 6 ap to 142.240.82.0 than they also connect to same contoller without an issue.I am clueless why it is happening
2 REPLIES 2
Highlighted
Hall of Fame Community Legend
Re: 1522 Connectivity Issue
Maybe the trunk port are prunning what VLAN is/are allowed.
Contributor
The APs shouldn't be connected to trunk ports though. If they are, that may indeed be the problem though.
Are your APs getting DHCP addresses? You can tell by consoling into them once they've booted.
Content for Community-Ad
