03-26-2012 09:53 AM - edited 07-03-2021 09:52 PM
I'm trying to mesh a 1522 MAP through a 1042 RAP but this doen´t work. I get strange messages on the trap log:
1 Mon Mar 26 18:40:19 2012 Mesh child node 'f0:25:72:d9:69:6f' has changed its parent to mesh node '58:35:d9:c6:60:10' from mesh node '58:35:d9:c6:60:1f'. .. .
3 Mon Mar 26 18:37:13 2012 Mesh child node 'f0:25:72:d9:69:6f' has changed its parent to mesh node '58:35:d9:c6:60:10' from mesh node '58:35:d9:c6:60:10'. 4 Mon Mar 26 18:34:00 2012 Mesh node 'f0:25:72:d9:69:6f' has changed its parent 5 times in last one hour.
5 Mon Mar 26 18:34:00 2012 Mesh child node 'f0:25:72:d9:69:6f' has changed its parent to mesh node '58:35:d9:c6:60:10' from mesh node '58:35:d9:c6:60:1f'. 6 Mon Mar 26 18:33:44 2012 Mesh child node 'f0:25:72:d9:69:6f' is no longer associated with mesh node '58:35:d9:c6:60:10'.
9 Mon Mar 26 18:30:33 2012 Mesh child node 'f0:25:72:d9:69:6f' has changed its parent to mesh node '58:35:d9:c6:60:10' from mesh node '58:35:d9:c6:60:1f'. ...
12 Mon Mar 26 18:27:27 2012 Mesh child node 'f0:25:72:d9:69:6f' has changed its parent to mesh node '58:35:d9:c6:60:10' from mesh node '58:35:d9:c6:60:1f'.
... etc ...
30 Mon Mar 26 18:08:48 2012 Mesh child node 'f0:25:72:d9:69:6f' has changed its parent to mesh node '58:35:d9:c6:60:10' from mesh node '58:35:d9:c6:60:10'.
If i debug the 1042 i also see "... has 1 AES-CCMP TSC replays messages..."
Any ideas?
I have some 1522 MAP meshing through 1142 working fine on same 5508 controller version, i think there are few differences between 1042 an 1142.
03-27-2012 09:19 AM
Update:
Doing some more testing in my lab i discover that the problem is the 1522 is not upgrading version through 1042, neither through 1142. Once the upgrade version process is done the 1522 MAP works fine through the 1142 RAP.
As i don´t have physical access to the 1522, ¿is there any way to upgrade the version through wireless?
