03-05-2015 06:26 AM - edited 07-05-2021 02:39 AM
Hi all,
I am having trouble getting a 1532E outdoor accesspoint to show up in prime infrastructure. The AP joins the controller, but won't show up in prime.
It is a lightweight accesspoint.
Prime version is 2.2
Controller IOS is 7.6.130.0
Does anyone know if Prime 2.2 supports the 1532E lightweight accesspoint?
Thanks!
Best regards,
Fabian
03-05-2015 07:25 PM
Yes, it is supported, refer details from the below link
Have you synchronize your WLC with PI 2.2 ?
Services > Mobility Services > Synchronize Services > Controllers
Rasika
*** Pls rate all useful responses ****
03-09-2015 07:00 PM
Yes, Prime 2.2 supports the 1532E lightweight accesspoint
03-13-2015 03:45 AM
This is something between WLC and PI, can try for syn. services there for WLC
