03-20-2018 01:58 PM - edited 07-05-2021 08:24 AM
I am facing some weird issue. when I use 1572IC DC power to the AP's it works fine till 100ft
if the power cable runs over 100 feet AP starts rebooting every 15mins or so
does any one faced such issue ?
any specific restrictions related to power cable distance usage on 1572IC ??
Thanks in advance.
03-20-2018 02:12 PM
03-20-2018 02:34 PM
Thats the problem.
longer the electrical cable AP doesn't light up and doesn't connect to controller.
I have an AP at 120Ft which works fine and another AP at 225 Ft which reboots in 15 mins post connected to controller.
anyway to find out Ap is getting enough current or not ?
03-20-2018 04:28 PM
First you need to check on the datasheet how many exactly ampere the AP requires. And then you can measure your circuit with a tool called Amper meter.
Power injector probably will allow you longer distance as UTP cable is made to cover up to 100 meter.
-If I helped you somehow, please, rate it as useful.-
