1810W wired Port reset on logout (802.1x)
0rsnaric
We have been trying to get 802.1x setup on the 1810W built in switches.  Works great initially, but if a user logsout, doesn't shut down, the port stays active and the next user to login stays in the same VLAN as the previous user.  If you disconnect the ethernet cable and plug it back in the vlan switch works.
How do we get a port bounce on logout?  All of our test clients work fine on 3650 switches.  Logging out immediately bounces the port, dumping it back in the default vlan until another user authenticates and RADIUS sends VLAN info.
Thanks!
Rick
0 Replies 0
