Community Helping Community
261
Beginner
1815i multiple SSID mapping to VLANs
I have 1815i access point, OS 8.5.140, I want to create 4 SSID mapped to different VLANs
- when access point boots, it gets to "(Cisco Controller)>" prompt, not ap# prompt
- attached files shows booting output, and GUI, they are not as described in config guides. so I can't follow the steps.
6 REPLIES 6
Rising star
Re: 1815i multiple SSID mapping to VLANs
The 1815 can use Mobility express.
you need to configure it via the mobility express controller
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Beginner
it's the only access point I have right now. can it be configured with SSID's mapped to different VLAN's.
Rising star
yes you map the WLANs to different VLANs and need port connecting to AP to be a trunk port allowing the VLANs
Beginner
the access point boots with "(cisco controller)>" prompt, not ap#, also GUI is different that what is described in guides.
how can I configure it
VIP Mentor
Configure AP as master AP, it will act as WLC as well.
see the example here:
https://www.lookingpoint.com/blog/mobility-express
https://keepcalmandping.online/2019/03/18/cisco-mobility-express-experience/
After Setup, configure the port on switch side as: The following is a sample switch port configuration.
Interface GigabitEthernet1/0/37
description » Connected to Master AP «
switchport trunk native vlan 122
switchport trunk allowed vlan 10,20,122,123,124
switchport mode trunk
Dontf orget to rate helpful posts
Highlighted
Beginner
I will try resetting the AP, and follow the advised tutorials, and post the updates.
thanks,
Content for Community-Ad
August's Community Spotlight Awards
