Cisco Community Designated VIP Class of 2020
830
Highlighted
Beginner
2500 as anchor / compatibility and limitations
with FW 7.4.100.0 a 2500 controller works as anchor controller, now.
I have 3 questions.
1) What are the limitations? 15 EoIP tunnel, Clients? something else?
2) Have Cisco a compatibility matrix about Anchor - Foreign Firmware? (Example works 7.4.100.0 anchor with 7.0.x.x foreign?)
3) A controller works only as anchor. A controller version with lowest AP licence is needed. Right?
Thanks and regards
Sven
Everyone's tags (4)
1 ACCEPTED SOLUTION
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp102554
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
3 REPLIES 3
Cisco 2500 Series Wireless LAN Controllers can now act as guest anchors and up to 15 EoIP tunnels are supported.
  and I would think it is stil 500 clients max as well.
yup, so long as you are in the 7.x it should work...I'll see if I can't find the link
  Well, 'needed' isn't the right word.  You can be licensed for any number of AP, but the lowest makes the best sense.
HTH,
Steve
HTH,
Steve
Beginner
Hello Stephen,
thanks for your answer.
Sven
Content for Community-Ad
August's Community Spotlight Awards
