Highlighted
Beginner
2504 and 3802i new install not happening
I installed a new 2504 WLC and new 3802i APs, however the APs are not fully functional. They keep cycling the LED RED/GREEN/BLUE which I don't even see in the troubleshooting guide. WLC running 8.3.102.0, APs connect, take a license, but none of the radios come up and it doesn't even see 2.4Ghz. I have installed 5508s before, and WiSMs and didn't have this issue with 1252/1142/2602 APs. Not sure what the heck I am missing and hoping the group can help me out. TAC told me they are not getting enough power which is a scripted answer. Controller shows PoE as PoE/Full Power. Was I supposed to install a device pack on the controllers? I went from 8.1.115.0 (Factory) right to 8.3.102.0 because 115 doesn't support 3802s.
Access Point Summary
  Total   Up   Down
802.11a/n/ac Radios   Detail
802.11b/g/n Radios   Detail
Dual-Band Radios   Detail
All APs   Detail
1 ACCEPTED SOLUTION
Highlighted
VIP Mentor
3800 require PoE+ (802.3at)
3800 require PoE+ (802.3at) to operate. Since you got a PoE line card it won't work properly. See below for power requirement for 3800 series.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_cisco_aironet_series_2800_3800_access_point_deployment_guide/b_cisco_aironet_series_2800_3800_access_point_deployment_guide_chapter_01010.html
Not sure what you want for a console output, so I posted AP run-config and show log:
If you have full console output when AP trying to register, we can see the exact issue going on. Even with the limited log messages you can see it is PoE negotiation failed.
If you have any PoE+ switch you can confirm a 3802 works without any problem. In that way you can confirm the issue with PoE
Rasika
*** Pls rate all useful responses ***
6 REPLIES 6
Highlighted
VIP Mentor
Which switch is powering
Which switch is powering these APs ?
Post a console output from AP to see what's the exact problem
Rasika
Highlighted
Beginner
Hi Rasika,
Hi Rasika,
Powered by a 6513
7 Policy Feature Card 3 WS-F6K-PFC3B
7 MSFC3 Daughterboard WS-SUP720
WS-X6148A-GE-45AF Line Card
Interface Admin Priority Oper Power(Watts) Device Class Police ActConsumption
(enabled ) From PS To PD
Gi1/2     static n/a        on            18.9    16.8 AIR-AP3802I-B-K9        0 off              11.4
3802i# show running-config
AP Name : 3802i
Admin State : Enabled
AP Mode : Local
AP Submode : None
Reboot Reason : Controller Reload command
Primary controller name :
Primary controller IP : 0.0.0.0
Secondary controller name :
Secondary controller IP : 0.0.0.0
Tertiary controller name :
Tertiary controller IP : 0.0.0.0
Controller from DNS server : 10.1.x.x, 10.1.x.x
AP join priority : 1
Last Joined Controller name: WLC_2504_1
DTLS Encryption State : Disabled
Discovery Timer : 10
Heartbeat Timer : 30
CDP State : Enabled
Watchdog monitoring : Enabled
RRM State : Enabled
LSC State : Disabled
SSH State : Disabled
AP Username : xxxxxx
Session Timeout : 300
Extlog Host : 0.0.0.0
Extlog Flags : 0
Extlog Status Interval : 0
Syslog Host : 255.255.255.255
Syslog Facility : 0
Syslog Level : 6
Core Dump TFTP Ip Addr : 0.0.0.0
Core Dump Flag: : 0
Core Dump Filename :
Client Trace Status : Enabled(All)
Client Trace All Clients : Enabled
Client Trace Filter : 0x0000000F
Client Trace Out ConsoleLog: Disabled
WLC Link LAG status : Disabled
AP Link LAG status : Disabled
Nov 4 16:40:27 brain: Restart POE negotiation
Nov 4 16:40:32 brain: CDP PoE negotiation START
Nov 4 16:40:32 brain: CDP PoE negotiation FAILED !!
Nov 4 16:40:32 brain: LLDP PoE negotiation START
Nov 4 16:41:04 brain: LLDP PoE negotiation FAILED !!
Nov 4 16:41:04 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Nov 4 16:41:09 brain: Restart POE negotiation
Nov 4 16:41:14 brain: CDP PoE negotiation START
Nov 4 16:41:14 brain: CDP PoE negotiation FAILED !!
Nov 4 16:41:14 brain: LLDP PoE negotiation START
Nov 4 16:41:46 brain: LLDP PoE negotiation FAILED !!
Nov 4 16:41:46 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Nov 4 16:41:51 brain: Restart POE negotiation
Nov 4 16:41:56 brain: CDP PoE negotiation START
Nov 4 16:41:56 brain: CDP PoE negotiation FAILED !!
Nov 4 16:41:56 brain: LLDP PoE negotiation START
Nov 4 16:42:28 brain: LLDP PoE negotiation FAILED !!
Nov 4 16:42:28 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Nov 4 16:42:33 brain: Restart POE negotiation
Nov 4 16:42:38 brain: CDP PoE negotiation START
Nov 4 16:42:38 brain: CDP PoE negotiation FAILED !!
Nov 4 16:42:38 brain: LLDP PoE negotiation START
Nov 4 16:43:11 brain: LLDP PoE negotiation FAILED !!
Highlighted
VIP Mentor
Rasika
Highlighted
Beginner
I read that too, but didn't
I read that too, but didn't see the note. Thank you for the second look!
Note: If the AP2800 and AP 3800 are powered from an 802.3af power source the LED will cycle though the colors and the radios will be disabled.
Thanks CDW for selling this to me!!
Highlighted
Beginner
Hello Peter,
Hello Peter,
If you could please help me on something.
I have a 2504 controller and i upgraded similarly from 8.0.115.0 to 8.3.102.0 but it never loads to the newer firmware. During the boot, it shows that it has successfully loaded 8.3 but it eventually loads 8.0.115.0 instead. I have opened a separate thread for this but noone actually helped me out on that. Could you please have a look at this thread and give us some insight?
https://supportforums.cisco.com/discussion/13138006/wlc-2504-fails-load-latest-image-831200
Highlighted
Beginner
Re: 3800 require PoE+ (802.3at)
Rasika,
Do you know if the 3802 not only needs PoE+, but also CDP?  I have a few access points that will do exactly what this thread is about - they'll boot up with radios down due to low power.  However they are on a non-Cisco PoE+ switch.  I'm wondering if Cisco requires CDP or LLDP.  The switch I am using likely does not support CDP as it is not Cisco.
Content for Community-Ad
