12-02-2019 03:46 AM - edited 07-05-2021 11:22 AM
Hi guys,
I am having some weird problems with my 2504 controller running on 8.5.151.0
I noticed today that I am unable to achieve more than 30-32Mbps on an individual device. It's like there is a hard-cap that doesn't let the device getting more bandwidth.
I have played alot, trying to tweak different QoS settings, but apparently 2500 is very limited in configuration of the bandwidth rates, burts and traffic profiles. I was unable to find a way to completely disable the qos for an SSID and just let it be on "best effort".
My questions are:
* are there any built-in, default policers for different classes and if so - what are the values?
* Is there anyway possible I can completely switch off that behaviour (preferably on a per SSID basis?)
* Is that an 8.5.151.x problem because I don't recall having this problem on older versions
12-02-2019 04:11 AM
- What AP-models are you using ?
M.
12-02-2019 04:32 AM - edited 12-02-2019 06:15 AM
Hi, apologies I forgot to mention this - AIR-AP1852I-E-K9.
All my devices support 802.11ac/Wave2 and I am literally under one of the APs (with RSSI of -44).
I noticed that my pings to other devices on the network (wired ones) are very strange. They progressively increas from 2-3-5-50-110-160-200-280ms and then normalize .. again back to 1-2ms .. and this is happening every 5-10 sec. It looks like some sort of a buffer / queueing that kicks in :|
P.s. some screenshots
12-02-2019 09:02 AM
12-02-2019 09:20 AM
Hi Scott & thanks for your inputs.
I have tested with numerous of devices, all of which (for good or worse) are apple.
The results I observe are identical - I cannot achieve more than 32-35Mbps using a basic "Speedtest.net" test. Now I know this is not the best measurement tool, but I do get a similar results copying (AFP/CIFS) from a server connecte to the same switch where the WLC is connected to and I cannot get more than ~4MBs (32-35Mbps) even there.
I have two iPads, two phones and three Apple computers (2xMacBook pro's & 1Mac Pro) and they're all having the same results (when it comes to the speedtest). If I connect the device physically to the switch - I get the full bandwidth (CAR) from the ISP.
It's very weird issue, but I have done 60-65MBs (~500Mbps) using CIFS on same equipment a few months back, with exactly the same config and everything and today - I can barely get 1/20th of that - it's just weird...
None of the devices (WLC) nor the switch report any CRCs or any other type of errors...
12-02-2019 10:54 AM
12-02-2019 01:02 PM
Thanks Scott.
I have roughly around 42 devices too, but only 5 APs. When you say "look at your configuration" - can you elaborate, which bit would you advise me looking at? Again, I am very confident there is no IP overlapping in the network as there are only a handful of devices configured with static IPs, which are outside the DHCP scope.
I am not sure what the separate SSID will prove tbh if I don't know what settings I need to tweak. I just tried running iperf and the results are better, but only because I played a bit with the TCP window size (as it is a major factor considering the observed results and RTTs jumping over 500-600 ms). As you may or may not have seen, I am using 80Mhz channels. Flex connect I wouldn't consider using because I roam with some devices and that'll be a problem.
I find speedtest.net quite useful as it tracks the whole connection - end-to-end and this is something I have always used to measure both - my internet service as well as my wireless one. Check the below picture - it's very clear. Up until recently, I've always got at least 200+ Mbps. Regardless what I did today, I cannot get more than 30-32Mbps. (unless I get on the wire were I get the whole ~215 Mbps).. The only thing I've changed lately was the AirOS. I have tried changing this now to 8.3.150, but it's the same result.. now my problem is I can't remember what I was running on before I upgraded to 8.5.150 so I can get back to it ....
12-02-2019 02:00 PM
12-03-2019 02:10 AM - edited 12-03-2019 02:24 AM
I only use the 5Ghz on all the devices. The 2.4 is for some IOT stuff that I have around the house and I can't turn it off (not that it is a problem anyway). I haven't tested the 2.4 / multi-channel, but I don't want to dig into this for now.
I checked a few tools to check for channel overlapping as well as channel utilisation and it's nothing there either!
As per my original topic, I was wondering if you guys know:
Also, what is your opinion on this "Best practices" menu. At the moment I am on 29/50, but some of these are not for home users anyway.
12-03-2019 06:28 AM
12-02-2019 09:22 AM
But to answer your questions:
- Don't think it's a driver issue as the problem doesn't follow an end-device, but it rather follows the "network" (Wireless)
- I am not 100% about configuration issue, but pretty much everything I could have though of - I've checked and it seems to be alright.
- There is no duplicate of addresses on the network.
Hope the above makes sense & thanks very once again for your time guys!
12-02-2019 09:38 AM
Some more data.
I have used another, non-apple computer (IBM Lenovo) which also has 802.11AC capable adapter and here is the results from it too:
12-05-2019 12:00 AM
12-05-2019 10:28 AM
Hiya,
I have tried numerous of times rebooting the whole setup - nothing helped. I even switched back to 8.3.150 but it was all the same!
I agree with the interference thing, but I only have a limited amount of software tools to analyse what's on the spectrum. From what I can see there is nothing reported and I tried (literally) all the possible channels (and getting connected to different APs (different physical locations in the house) and nothing helped!) it's super annoying and I have no idea where to look next :|
check the below screenshots but I can't find any correlations between latency going up and anything massively changing on the "left hand side" .. :| Is there anyway possible there could be some non-wifi interference on 5Ghz!? I don't know what to think anymore...
P.s. the latency isn't as bad as it was right now... but I am still unable to achieve more than 35Mbps :| It all leads me to the controller, like there is a queue or a buffer / queueing happening and as soon as this happens, TCP is just ... being TCP, trying to adapt to these latencies and basically dropping the bandwidth. If I play with iperf and increase the TCP window size or simply start whacking UDP traffic - I can eventually get to ~400Mbps, but that's not the point .. (as it is more or less useless If I have this latency issue as any protocol (especially chatty ones such as CIFS/AFP will suffer big time))
I really hope that makes sense ...
12-05-2019 01:08 PM
