Highlighted
Enthusiast
Re: 3504 fails update to 8.8.125
Please see the output requested below
(Cisco Controller) >test system disk-usage
Filesystem Size Used Available Use% Mounted on
devpts 1.7G 388.0K 1.7G 0% /dev/pts
none 1.7G 64.0K 1.7G 0% /var/run
none 1.7G 468.0K 1.7G 0% /tmp
none 1.7G 388.0K 1.7G 0% /dev
/dev/mmcblk0p2 16.4G 754.2M 14.8G 5% /mnt/wlc
/dev/mmcblk0p3 7.2G 17.4M 6.8G 0% /var/log
/dev/mmcblk0p1 464.8M 77.2M 359.3M 18% /boot
/dev/loop3 110.0K 10.0K 92.0K 10% /root/.csl
tmpfs 512.0M 0 512.0M 0% /mnt/download
tmpfs 40.0M 0 40.0M 0% /mnt/ap_bundle
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.8.120.0
RTOS Version..................................... 8.8.120.0
Bootloader Version............................... 8.5.103.0
Emergency Image Version.......................... 8.5.103.0
OUI File Last Update Time........................ N/A
Build Type....................................... DATA + WPS
IP Address....................................... 172.16.4.2
IPv6 Address..................................... ::
Last Reset....................................... Cold reset due to PLL_DC_OK
System Up Time................................... 4 days 18 hrs 30 mins 45 secs
System Timezone Location......................... (GMT -8:00) Pacific Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... -10 to 80 C
Internal Temperature............................. +70 C
Mgig Temp Alarm Limits........................... -10 to 78 C
Mgig Temperature................................. +52 C
External Temp Alarm Limits....................... -10 to 71 C
External Temperature............................. +45 C
Fan Status....................................... OK
Fan Speed Mode................................... Disable
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 5
Number of Active Clients......................... 10
OUI Classification Failure Count................. 49
Memory Current Usage............................. 42
Memory Average Usage............................. 42
CPU Current Usage................................ 0
CPU Average Usage................................ 0
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Maximum number of APs supported.................. 150
WLC MIC Certificate Types........................ SHA1/SHA2
Highlighted
Hall of Fame Community Legend
Try using TFTP.
Highlighted
Enthusiast
Have tried the following file transfers same result with all.
HTTPS
FTP
TFTP
SFTP
Highlighted
Enthusiast
I am starting to think there may be a licensing issue.  I am using RTU license.  I added (5) license to match what I had on the 2504 controller I am replacing.
Enthusiast
Well the licensing appears to be the issue.  I removed the RTU licenses and the unit updated to 8.8.125.  I did notice that my RTU count of (5) put me at (6) including the one license that comes with the unit.  I have since reassigned to a total of (5).  See what happens next update.
Highlighted
Enthusiast
Thanks to all for the input.
Content for Community-Ad
August's Community Spotlight Awards
