Highlighted
Beginner
3602i AP's w/ 802.11ac module input and crc errors connected to 3850 switches
I have a client with 3602i AP's with the AC module on 3850  switches.  They are seeing Input Errors and CRC Errors on every port that has an AP connected to it incrementing every 30 seconds.  The client has 3 separate 3850 switch stacks connected to a  4500X distribution where the 5760 controller is also plugged in.  They  are getting input errors every 30 seconds on any port that has an access  point (3602i w/ the AC module).  I initially thought it was cabling but  not for all 41 AP's.  I also moved an AP from it's location to the switch stack and connected it via a 5' cable and it still gets the errors.  Below is a sample output from one of the ports.
CUSTOMER-X#sho int gig4/0/44
GigabitEthernet4/0/44 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 7c95.f32e.c42c (bia 7c95.f32e.c42c)
  Description: AP-MGMT VLAN 20
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 253/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:20, output never, output hang never
  Last clearing of "show interface" counters 00:12:18
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 2000 bits/sec, 4 packets/sec
     400 packets input, 187166 bytes, 0 no buffer
     Received 50 broadcasts (38 multicasts)
     25 input errors, 25 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 38 multicast, 0 pause input
     3441 packets output, 285480 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
CUSTOMER-X#sh controll e gig4/0/44
Transmit                  GigabitEthernet4/0/44                 Receive
   6057493580 Total bytes                  1412121936 Total bytes
      7506457 Unicast frames                  3770203 Unicast frames
   4479561048 Unicast bytes                1316508570 Unicast bytes
      4470282 Multicast frames                 211157 Multicast frames
    390870316 Multicast bytes                78283645 Multicast bytes
     12801608 Broadcast frames                 113463 Broadcast frames
   1187062216 Broadcast bytes                17329721 Broadcast bytes
            0 System FCS error frames               0 IpgViolation frames
            0 MacUnderrun frames                    0 MacOverrun frames
            0 Pause frames                          0 Pause frames
            0 Cos 0 Pause frames                    0 Cos 0 Pause frames
            0 Cos 1 Pause frames                    0 Cos 1 Pause frames
            0 Cos 2 Pause frames                    0 Cos 2 Pause frames
            0 Cos 3 Pause frames                    0 Cos 3 Pause frames
            0 Cos 4 Pause frames                    0 Cos 4 Pause frames
            0 Cos 5 Pause frames                    0 Cos 5 Pause frames
            0 Cos 6 Pause frames                    0 Cos 6 Pause frames
            0 Cos 7 Pause frames                    0 Cos 7 Pause frames
            0 Oam frames                            0 OamProcessed frames
            0 Oam frames                            0 OamDropped frames
      9112170 Minimum size frames              483897 Minimum size frames
      7542094 65 to 127 byte frames             66410 65 to 127 byte frames
      4613789 128 to 255 byte frames          2409181 128 to 255 byte frames
       959282 256 to 511 byte frames           569562 256 to 511 byte frames
        73061 512 to 1023 byte frames          277447 512 to 1023 byte frames
      2477951 1024 to 1518 byte frames         288326 1024 to 1518 byte frames
            0 1519 to 2047 byte frames         133612 1519 to 2047 byte frames
            0 2048 to 4095 byte frames              0 2048 to 4095 byte frames
            0 4096 to 8191 byte frames              0 4096 to 8191 byte frames
            0 8192 to 16383 byte frames             0 8192 to 16383 byte frames
            0 16384 to 32767 byte frame             0 16384 to 32767 byte frame
            0 > 32768 byte frames                   0 > 32768 byte frames
            0 Late collision frames                 0 SymbolErr frames
            0 Excess Defer frames                   0 Collision fragments
            0 Good (1 coll) frames                  0 ValidUnderSize frames
            0 Good (>1 coll) frames                 0 InvalidOverSize frames
            0 Deferred frames                       0 ValidOverSize frames
            0 Gold frames dropped              133612 FcsErr frames
            0 Gold frames truncated
            0 Gold frames successful
            0 1 collision frames
            0 2 collision frames
            0 3 collision frames
            0 4 collision frames
            0 5 collision frames
            0 6 collision frames
            0 7 collision frames
            0 8 collision frames
            0 9 collision frames
            0 10 collision frames
            0 11 collision frames
            0 12 collision frames
            0 13 collision frames
            0 14 collision frames
            0 15 collision frames
            0 Excess collision frames
Any help/advice is appreciated.
1 ACCEPTED SOLUTION
Highlighted
Beginner
This fixed my issue - have
This fixed my issue - have six 3702Is plugged directly into a 3850.  All interfaces showed FCS and RCV errors (tens of thousands after a few months), but stopped incrementing after using the "ap name no jumbo-mtu" command.
29 REPLIES 29
Highlighted
Hall of Fame Community Legend
Re: 3602i AP's w/ 802.11ac module input and crc errors connected
You have a cable problem.  Value highlighted should ALWAYS be 255.
Run a TDR to determine where the faulty cable is:
1.  Command:  test cable tdr int G4/0/44;
2.  Wait for approximately 5 to 7 seconds;
3.  Command:  sh cable tdr int G4/0/44; and
4.  Post output to #3.
Highlighted
Beginner
Leo,
Thank you for the reply.  I initially thought it was cabling too but it is only happening on the AP ports and this is a brand new building with over 600 ports.  Below is another output from a different port that has a reliability of 255 as well as the tdr output from both ports.
CUSTOMER-X#sho int gig 2/0/24
GigabitEthernet2/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e8ed.f300.5698 (bia e8ed.f300.5698)
  Description: AP-MGT Wireless
  Last input 00:00:00, output never, output hang never
  5 minute output rate 3000 bits/sec, 5 packets/sec
     3168502 packets input, 1383220350 bytes, 0 no buffer
     Received 324646 broadcasts (211234 multicasts)
     133657 input errors, 133657 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 211234 multicast, 0 pause input
     20602354 packets output, 2658516551 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     46442 unknown protocol drops
CUSTOMER-X#sho controll e gig 2/0/24
Transmit                  GigabitEthernet2/0/24                 Receive
   2658517487 Total bytes                  1383220708 Total bytes
      3327189 Unicast frames                  2843856 Unicast frames
   1080327462 Unicast bytes                1287597192 Unicast bytes
      4470715 Multicast frames                 211235 Multicast frames
    390903687 Multicast bytes                78313645 Multicast bytes
     12804464 Broadcast frames                 113412 Broadcast frames
   1187286338 Broadcast bytes                17309871 Broadcast bytes
      9114093 Minimum size frames              483973 Minimum size frames
      7588898 65 to 127 byte frames             79534 65 to 127 byte frames
      2331126 128 to 255 byte frames          1248944 128 to 255 byte frames
      1121371 256 to 511 byte frames           733990 256 to 511 byte frames
        35339 512 to 1023 byte frames          257104 512 to 1023 byte frames
       411541 1024 to 1518 byte frames         364958 1024 to 1518 byte frames
            0 1519 to 2047 byte frames         133657 1519 to 2047 byte frames
            0 Gold frames dropped              133657 FcsErr frames
CUSTOMER-X#test cable tdr int g4/0/44
TDR test started on interface Gi4/0/44
A TDR test can take a few seconds to run on an interface
Use 'show cable-diagnostics tdr' to read the TDR results.
CUSTOMER-X#sh cable tdr int g4/0/44
TDR test last run on: February 17 20:02:56
Interface Speed Local pair Pair length        Remote pair Pair status
Gi4/0/44  1000M Pair A     39   +/- 10 meters Pair A      Normal
                Pair B     39   +/- 10 meters Pair B      Normal
                Pair C     39   +/- 10 meters Pair C      Normal
                Pair D     39   +/- 10 meters Pair D      Normal
CUSTOMER-X#test cable tdr int g2/0/24
TDR test started on interface Gi2/0/24
CUSTOMER-X#sh cable tdr int g2/0/24
TDR test last run on: February 17 20:03:55
Gi2/0/24  1000M Pair A     26   +/- 10 meters Pair A      Normal
                Pair B     26   +/- 10 meters Pair B      Normal
                Pair C     26   +/- 10 meters Pair C      Normal
                Pair D     26   +/- 10 meters Pair D      Normal
Highlighted
Beginner
Just noticed the obvious correlation here.  The "133657 1519 to 2047 byte frames" is the same count as the input errors.
Highlighted
That's not the cause of your line errors.  It's caused by FCS.
Highlighted
Line error of G2/0/24 is caused by FCS.  Connect the AP directly to the switch and see if the errors increment.  This is your best test.
TDR shows good result but that won't be an indicator.
Highlighted
Beginner
I tried that and they still do.  I took the AP that was connected on int G4/0/44 and connected it directly to the switch via a 5' cable and the errors still incremented.
Highlighted
Beginner
Here is another output if this will help.  The highest error ports are the ones with AP's connected.
CUSTOMER-X#sho int count err
Port        Align-Err     FCS-Err    Xmit-Err     Rcv-Err  UnderSize  OutDiscards
Gi1/0/1             0           0           0           0          0            0
Gi1/0/2             0           0           0           0          0            0
Gi1/0/3             0           0           0           0          0            0
Gi1/0/4             0           0           0           0          0            0
Gi1/0/5             0           0           0           0          0            0
Gi1/0/6             0           0           0           0          0            0
Gi1/0/7             0           0           0           0          0            0
Gi1/0/8             0           0           0           0          0            0
Gi1/0/9             0           0           0           0          0            0
Gi1/0/10            0           0           0           0          0            0
Gi1/0/11            0           0           0           0          0            0
Gi1/0/12            0           0           0           0          0            0
Gi1/0/13            0           0           0           0          0            0
Gi1/0/14            0           0           0           0          0            0
Gi1/0/15            0           0           0           0          0            0
Gi1/0/16            0           0           0           0          0            0
Gi1/0/17            0           0           0           0          0            0
Gi1/0/18            0           0           0           0          0            0
Gi1/0/19            0           0           0           0          0            0
Gi1/0/20            0           0           0           0          0            0
Gi1/0/21            0           0           0           0          0            0
Gi1/0/22            0           0           0           0          0            0
Gi1/0/23            0           0           0           0          0            0
Gi1/0/24            0           0           0           0          0            0
Gi1/0/25            0           0           0           0          0            0
Gi1/0/26            0           0           0           0          0            0
Gi1/0/27            0           0           0           0          0            0
Gi1/0/28            0           0           0           0          0            0
Gi1/0/29            0           0           0           0          0            0
Gi1/0/30            0           0           0           0          0            0
Gi1/0/31            0           0           0           0          0            0
Gi1/0/32            0           0           0           0          0            0
Gi1/0/33            0           0           0           0          0            0
Gi1/0/34            0           0           0           0          0            0
Gi1/0/35            0           0           0           0          0            0
Gi1/0/36            0           0           0           0          0            0
Gi1/0/37            0           0           0           0          0            0
Gi1/0/38            0           0           0           0          0            0
Gi1/0/39            0           0           0           0          0            0
Gi1/0/40            0           0           0           0          0            0
Gi1/0/41            0           0           0           0          0            0
Gi1/0/42            0           0           0           0          0            0
Gi1/0/43            0           3           0           3          0            0
Gi1/0/44            0           0           0           0          0            0
Gi1/0/45            0           0           0           0          0            0
Gi1/0/46            0           0           0           0          0            0
Gi1/0/47            0           0           0           0          0            0
Gi1/0/48            0           0           0           0          0            0
Gi1/1/1             0           0           0           0          0            0
Gi1/1/2             0           0           0           0          0            0
Te1/1/3             0           0           0           0          0            0
Te1/1/4             0           0           0           0          0            0
Gi2/0/1             0           0           0           0          0            0
Gi2/0/2             0           0           0           0          0            0
Gi2/0/3             0           0           0           0          0            0
Gi2/0/4             0           0           0           0          0            0
Gi2/0/5             0           0           0           0          0            0
Gi2/0/6             0           0           0           0          0            0
Gi2/0/7             0           0           0           0          0            0
Gi2/0/8             0           0           0           0          0            0
Gi2/0/9             0           0           0           0          0            0
Gi2/0/10            0           0           0           0          0            0
Gi2/0/11            0           0           0           0          0            0
Gi2/0/12            0           0           0           0          0            0
Gi2/0/13            0           0           0           0          0            0
Gi2/0/14            0           0           0           0          0            0
Gi2/0/15            0           0           0           0          0            0
Gi2/0/16            0           0           0           0          0            0
Gi2/0/17            0           0           0           0          0            0
Gi2/0/18            0           0           0           0          0            0
Gi2/0/19            0      133724           0      133724          0            0
Gi2/0/20            0      133677           0      133677          0            0
Gi2/0/21            0      133750           0      133750          0            0
Gi2/0/22            0           0           0           0          0            0
Gi2/0/23            0      133721           0      133721          0            0
Gi2/0/24            0      133706           0      133706          0            0
Gi2/0/25            0           0           0           0          0            0
Gi2/0/26            0           0           0           0          0            0
Gi2/0/27            0           0           0           0          0            0
Gi2/0/28            0           0           0           0          0            0
Gi2/0/29            0           0           0           0          0            0
Gi2/0/30            0           0           0           0          0            0
Gi2/0/31            0           9           0           9          0            0
Gi2/0/32            0           0           0           0          0            0
Gi2/0/33            0           0           0           0          0            0
Gi2/0/34            0           0           0           0          0            0
Gi2/0/35            0           0           0           0          0            0
Gi2/0/36            0           0           0           0          0            0
Gi2/0/37            0           0           0           0          0            0
Gi2/0/38            0           0           0           0          0            0
Gi2/0/39            0           0           0           0          0            0
Gi2/0/40            0           0           0           0          0            0
Gi2/0/41            0           0           0           0          0            0
Gi2/0/42            0           0           0           0          0            0
Gi2/0/43            0           0           0           0          0            0
Gi2/0/44            0           0           0           0          0            0
Gi2/0/45            0           0           0           0          0            0
Gi2/0/46            0           0           0           0          0            0
Gi2/0/47            0           0           0           0          0            0
Gi2/0/48            0           0           0           0          0            0
Gi2/1/1             0           0           0           0          0            0
Gi2/1/2             0           0           0           0          0            0
Te2/1/3             0           0           0           0          0            0
Te2/1/4             0           0           0           0          0            0
Gi3/0/1             0           0           0           0          0            0
Gi3/0/2             0           0           0           0          0            0
Gi3/0/3             0           0           0           0          0            0
Gi3/0/4             0           0           0           0          0            0
Gi3/0/5             0           0           0           0          0            0
Gi3/0/6             0           0           0           0          0            0
Gi3/0/7             0           0           0           0          0            0
Gi3/0/8             0           0           0           0          0            0
Gi3/0/9             0           0           0           0          0            0
Gi3/0/10            0           0           0           0          0            0
Gi3/0/11            0           0           0           0          0            0
Gi3/0/12            0           0           0           0          0            0
Gi3/0/13            0           0           0           0          0            0
Gi3/0/14            0           0           0           0          0            0
Gi3/0/15            0           0           0           0          0            0
Gi3/0/16            0           0           0           0          0            0
Gi3/0/17            0           0           0           0          0            0
Gi3/0/18            0           0           0           0          0            0
Gi3/0/19            0           0           0           0          0            0
Gi3/0/20            0           0           0           0          0            0
Gi3/0/21            0           0           0           0          0            0
Gi3/0/22            0           0           0           0          0            0
Gi3/0/23            0           0           0           0          0            0
Gi3/0/24            0           0           0           0          0            0
Gi3/0/25            0           0           0           0          0            0
Gi3/0/26            0           0           0           0          0            0
Gi3/0/27            0           0           0           0          0            0
Gi3/0/28            0           0           0           0          0            0
Gi3/0/29            0           0           0           0          0            0
Gi3/0/30            0           0           0           0          0            0
Gi3/0/31            0           7           0           7          0            0
Gi3/0/32            0           0           0           0          0            0
Gi3/0/33            0           0           0           0          0            0
Gi3/0/34            0           0           0           0          0            0
Gi3/0/35            0           0           0           0          0            0
Gi3/0/36            0           0           0           0          0            0
Gi3/0/37            0           0           0           0          0            0
Gi3/0/38            0           0           0           0          0            0
Gi3/0/39            0           0           0           0          0            0
Gi3/0/40            0           0           0           0          0            0
Gi3/0/41            0           0           0           0          0            0
Gi3/0/42            0           0           0           0          0            0
Gi3/0/43            0      133722           0      133722          0            0
Gi3/0/44            0      133760           0      133760          0            0
Gi3/0/45            0      133752           0      133752          0            0
Gi3/0/46            0      119456           0      119456          0            0
Gi3/0/47            0      133695           0      133695          0            0
Gi3/0/48            0      122068           0      122068          0            0
Gi4/0/1             0           0           0           0          0            0
Gi4/0/2             0           0           0           0          0            0
Gi4/0/3             0           0           0           0          0            0
Gi4/0/4             0           0           0           0          0            0
Gi4/0/5             0           0           0           0          0            0
Gi4/0/6             0           0           0           0          0            0
Gi4/0/7             0           0           0           0          0            0
Gi4/0/8             0           0           0           0          0            0
Gi4/0/9             0           0           0           0          0            0
Gi4/0/10            0           0           0           0          0            0
Gi4/0/11            0           0           0           0          0            0
Gi4/0/12            0           0           0           0          0            0
Gi4/0/13            0           0           0           0          0            0
Gi4/0/14            0           0           0           0          0            0
Gi4/0/15            0           0           0           0          0            0
Gi4/0/16            0           0           0           0          0            0
Gi4/0/17            0           0           0           0          0            0
Gi4/0/18            0           0           0           0          0            0
Gi4/0/19            0           0           0           0          0            0
Gi4/0/20            0           0           0           0          0            0
Gi4/0/21            0           0           0           0          0            0
Gi4/0/22            0           0           0           0          0            0
Gi4/0/23            0           0           0           0          0            0
Gi4/0/24            0           4           0           4          0            0
Gi4/0/25            0           0           0           0          0            0
Gi4/0/26            0           0           0           0          0            0
Gi4/0/27            0           0           0           0          0            0
Gi4/0/28            0           0           0           0          0            0
Gi4/0/29            0           0           0           0          0            0
Gi4/0/30            0           0           0           0          0            0
Gi4/0/31            0           0           0           0          0            0
Gi4/0/32            0           0           0           0          0            0
Gi4/0/33            0           0           0           0          0            0
Gi4/0/34            0           0           0           0          0            0
Gi4/0/35            0           0           0           0          0            0
Gi4/0/36            0           0           0           0          0            0
Gi4/0/37            0           0           0           0          0            0
Gi4/0/38            0           0           0           0          0            0
Gi4/0/39            0           0           0           0          0            0
Gi4/0/40            0           0           0           0          0            0
Gi4/0/41            0      133632           0      133632          0            0
Gi4/0/42            0      133757           0      133757          0            0
Gi4/0/43            0      133757           0      133757          0            0
Gi4/0/44            0         421           0         421          0            0
Gi4/0/45            0      133758           0      133758          0            0
Gi4/0/46            0      133760           0      133760          0            0
Gi4/0/47            0           0           0           0          0            0
Gi4/0/48            0           0           0           0          0            0
Po1                 0           0           0           0          0            0
Highlighted
Take off the 802.11ac module.
Highlighted
Beginner
I just verified it happens without the module as well.
Highlighted
I've got two 3700 on the network and the only line errors I can see right now are Giants.
I don't see any other line errors other than that.
Post those "sh interface" again.  I want a fresh output.
Highlighted
Beginner
Thanks again for the help Leo.  Here is the latest from g2/0/24.  I haven't reset the counters on this one.  The only other case similar to this one was related to an older 4500 series switch and 3700 series AP's.  I know our other clients are running fine with these AP's on 3750's.  I'm wondering if it isn't another "feature" in the 3850 switches.
CUSTOMER-X#sho int g2/0/24
  5 minute input rate 3000 bits/sec, 1 packets/sec
  5 minute output rate 4000 bits/sec, 6 packets/sec
     3243097 packets input, 1412749784 bytes, 0 no buffer
     Received 329453 broadcasts (214875 multicasts)
     135990 input errors, 135990 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 214875 multicast, 0 pause input
     20963964 packets output, 2702239247 bytes, 0 underruns
CUSTOMER-X#sho controll e g2/0/24
   2702239247 Total bytes                  1412749784 Total bytes
      3401068 Unicast frames                  2913644 Unicast frames
   1102570846 Unicast bytes                1315688862 Unicast bytes
      4548037 Multicast frames                 214875 Multicast frames
    398088370 Multicast bytes                79676427 Multicast bytes
     13014859 Broadcast frames                 114578 Broadcast frames
   1201580031 Broadcast bytes                17384495 Broadcast bytes
      9267288 Minimum size frames              492141 Minimum size frames
      7738721 65 to 127 byte frames             82981 65 to 127 byte frames
      2371018 128 to 255 byte frames          1285633 128 to 255 byte frames
      1130624 256 to 511 byte frames           747754 256 to 511 byte frames
        37359 512 to 1023 byte frames          261511 512 to 1023 byte frames
       418954 1024 to 1518 byte frames         373077 1024 to 1518 byte frames
            0 1519 to 2047 byte frames         135990 1519 to 2047 byte frames
            0 Gold frames dropped              135990 FcsErr frames
Highlighted
I'm still seeing this to be a cable issue.   The issue I've got is I don't know WHERE it's coming from.
If you console into the AP, can you post the output to the command "sh interface g0"?
Highlighted
Beginner
Instead of taking down an existing one, I got a different one and hooked it up directly to the switch in the closet I am working in.  I cleared the counters on the switch port before hooking the AP up.  Below are the current sho interfaces from both the switch and the AP.  I do not know why the reliability is at 252.  It is a brand new Panduit CAT 6 patch cable plugged into the AP.  However, other AP's that are at 255 are still having this issue.  All 41 of them to be precise.
SWITCH OUTPUT#sho int g2/0/38
GigabitEthernet2/0/38 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 7c95.f3a2.bea6 (bia 7c95.f3a2.bea6)
  Description: Zone1 Access Ports
     reliability 252/255, txload 1/255, rxload 1/255
  Last input 00:00:06, output never, output hang never
  Last clearing of "show interface" counters 00:18:41
  30 second output rate 2000 bits/sec, 2 packets/sec
     1463 packets input, 482365 bytes, 0 no buffer
     Received 76 broadcasts (51 multicasts)
     30 input errors, 30 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 51 multicast, 0 pause input
     4638 packets output, 598155 bytes, 0 underruns
     4 unknown protocol drops
AP OUTPUT#sh int g0
GigabitEthernet0 is up, line protocol is up
  Hardware is PowerPC Ethernet, address is 7c69.f663.52d9 (bia 7c69.f663.52d9)
  MTU 1792 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full Duplex, 1Gbps, media type is T
  output flow-control is unsupported, input flow-control is unsupported
  Input queue: 0/18174/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 2000 bits/sec, 4 packets/sec
     6456 packets input, 645139 bytes, 0 no buffer
     Received 5168 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1587 packets output, 469012 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
Highlighted
Reliability should ALWAYS be 255/255.
I've never used Panduit but do you have any other cables to test?
Content for Community-Ad
Cisco COVID-19 Survey
