3602i Errors in log, bad throughput
jonesea
I just acquared a 3602i.  It was running lightweight, but I changed it to autonomous.
From the start I notced absomal throughput when only 10-20 feet away, bouncing from 0 to 7 Mb/s when using iperf over a 30 second period.  If I used the same client on my 3502, I get a solid consistant throughput of 37 Mb/s.
When I looked at the logs, I noticed the following section:
  1. Sep 29 11:18:13 MDT: %DOT11-6-ASSOC: Interface Dot11Radio0, Station ap 001f.3b05.ecd7 Associated KEY_MGMT[WPAv2 PSK]
  2. Sep 29 11:18:17 MDT: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001f.3b05.ecd7 Reason: Sending station has left the BSS
  3. Sep 29 17:18:25.552: Cmd Timeout After 12s
  4. Sep 29 11:18:25 MDT: %DOT11-6-GEN_ERROR: Error on Dot11Radio0 -
  5. Radio interface bus down --
  6. -Traceback= 219A458z 2771628z 2FBB980z 276FBC8z 2770094z 2772818z 2329810z 230E6D8z
  7. Sep 29 11:18:25 MDT: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to resetPCI reset port 0
  8. Sep 29 17:18:26.863: soap_pci_reconfig_radio: radio id 0
  9. Sep 29 11:18:26 MDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
  10. Sep 29 11:18:32 MDT: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
  11. Sep 29 17:18:32.921: dot11_mgmt: bad cookie returned from driver for mac 001f.3b05.ecd7(expected 0x0, got 0x843E6D4) - force driver to delete client
Those errors are none that I have seen before.
Ideas?  I have an idea what is wrong, but I wanted some feedback before suggesting anything.  The performance is bad with more than just this specific client that I'm testing with.
7 Replies 7
What IOS version you running here ? Also compare "show dot11 associations " output with 3602 & 3502 when client connected. Specially "current rate" parameter.
Some of the error msg like hardware related like "Radio interface bus down" etc. I would upgrade the software & see.
Rasika
**** Pls rate all useful responses ****
Lin Guo
3602i only should work in lap mode, what IOS you used to covert it to AP mode?
jonesea
I'm running the latest autonomous code (July 31st 2013) - ap3g2-k9w7-xx.152-4.JA1 , but I was also running an old one and had the same errors as I originally posted.
I finally got around the testing again with my two APs
On my troubled 3602i:
ap#show dot11 associations 001f.3b05.ecd7
Address           : 001f.3b05.ecd7     Name             : ap
IP Address        : 172.16.1.91        IPv6 Address        : ::
Gateway Address   : 0.0.0.0
Netmask Address   : 0.0.0.0            Interface        : Dot11Radio 0
Bridge-group        : 1
reap_flags_1        : 0x0     ip_learn_type       : 0x0       transient_static_ip : 0x0
Device            : ccx-client         Software Version : NONE
CCX Version       : 4                  Client MFP       : Off
State             : Assoc              Parent           : self
SSID              : InOut2
VLAN              : 100
Hops to Infra     : 1                  Association Id   : 1
Clients Associated: 0                  Repeaters associated: 0
Tunnel Address    : 0.0.0.0
Key Mgmt type     : WPAv2 PSK          Encryption       : AES-CCMP
Current Rate      : m13b               Capability       : WMM ShortHdr ShortSlot
Supported Rates   : 1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Voice Rates       : disabled           Bandwidth        : 20 MHz
Signal Strength   : -59  dBm           Connected for    : 167 seconds
Signal to Noise   : 34  dB            Activity Timeout : 20 seconds
Power-save        : Off                Last Activity    : 0 seconds ago
Apsd DE AC(s)     : NONE
Packets Input     : 119034             Packets Output   : 55189
Bytes Input       : 174092109          Bytes Output     : 3603931
Duplicates Rcvd   : 18862              Data Retries     : 11745
Decrypt Failed    : 1                  RTS Retries      : 0
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
IP source guard failed : 0             PPPoE passthrough failed : 0
DAI failed : IP mismatch  : 0             src MAC mismatch : 0             target MAC mismatch : 0
Existing IP failed :  0              New IP failed :  0
11w Status       : Off
Session timeout   : 0 seconds
Reauthenticate in : never
And I have the following errors during my iperf test:
Oct  6 20:14:23 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 8 AES-CCMP TSC replays
Oct  6 20:14:35 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 5 AES-CCMP TSC replays
Oct  6 20:14:46 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 3 AES-CCMP TSC replays
Oct  6 20:14:53 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 16 AES-CCMP TSC replays
Oct  6 20:15:00 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 11 AES-CCMP TSC replays
Oct  6 20:15:07 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 8 AES-CCMP TSC replays
Oct  6 20:15:14 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 5 AES-CCMP TSC replays
Oct  6 20:15:21 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 11 AES-CCMP TSC replays
Oct  6 20:15:28 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 13 AES-CCMP TSC replays
Oct  6 20:15:35 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 23 AES-CCMP TSC replays
Oct  6 20:16:14 MDT: %DOT11-4-CCMP_REPLAY: Client 001f.3b05.ecd7 had 19 AES-CCMP TSC replays
While on my 3502i I have much better success:
Bridge-group        : 1
SSID              : InOut
VLAN              : 100
Hops to Infra     : 1                  Association Id   : 11
Current Rate      : m15-               Capability       : WMM ShortHdr ShortSlot
Signal Strength   : -56  dBm           Connected for    : 173 seconds
Signal to Noise   : 40  dB            Activity Timeout : 20 seconds
Packets Input     : 154059             Packets Output   : 79315
Bytes Input       : 225124589          Bytes Output     : 5124766
Duplicates Rcvd   : 4                  Data Retries     : 3044
11w Status       : Off
Autonomous code has been released by Cisco, it's available from the support/download page.  While I totally understand these classes of lighweight radios were meant to only be used this way and that autonomous was for surveying with a limited feature set, my 3502i has worked flawless for 4+ months.
Also, I also don't think the errors I'm seeing are a result of using the Autonomous mode, these seem like much lower level of errors that woudl impact your ability to even do a proper suvrey.
Endaff,
Did you ever find an fix for this (other than switching to the 3502)?  We have been having the same issue for quite a while.  We are using 2602 radios for both the RB and NRB.  Switching from 1242's radios to the 2602's seemed to work for a bit, but the same logs have shown back up, and the NRB's drop there assococation periodically, but do usually reassociate on their own.  The problem is it is causing troubles with our end devices connecting to the NRB while the connection is down.  Any information you can provide would be appreciated.  Thanks
Don't use IOS version 15.0, if possible.  Use 12.4.
Hi Endaf,
Please try to add the infrastructure-client command root access point radio stops the message.
If this is only for a  specific client looks like , client related issue. That MAC OUI look like an intel card, ensure that it is running the latest driver.Hope that helps.
https://discussions.apple.com/thread/3042800?start=165&tstart=0
Hope it helps.
jonesea
No, I have not resolved this.  I havn't had time to work on this lately, but I'm in the process of moving this specific radio to a WLC enviorment to test again.
I'm trying to determine if this is a hardware fault or firmware issue.
