Community Helping Community
174
Beginner
3702e not registering with WLC ver 7.6.130
We are not able to join AP 3702e to WLC ver 7.6.130. Software version and console output is an attached file.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702E-D-K9 (PowerPC) processor (revision A0) with 376810K/134656K bytes of memory.
Processor board ID FGL1909X179
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.110.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A8:9D:21:DF:F1:98
Part Number                          : 73-15397-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC19050J4U
 --More--
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.25Top Assembly Part Number             : 068-05055-04
Top Assembly Serial Number           : FGL1909X179
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3702E-D-K9
Configuration register is 0xF
7.6.130 wlc
Kamlesh
8 REPLIES 8
Beginner
does this post help?https:/
Beginner
The OS you list is compatible
The OS you list is compatible with this AP model, however it appears to be a country code mismatch between the AP and wireless controller settings.  The specific AP hardware sku you listed is 'D' which is manufactured for regulatory compliance in countries such as India.  This AP model will not associate to the wireless controller without a matching country code.  Disable the SSIDs on the controller, go to Wireless tab and down to Country and select IN or another supported country code for this model of AP, reenable the SSIDs and the AP will be able to be staged.  Regards
http://www.cisco.com/c/en/us/products/collateral/wireless/access-points/product_data_sheet0900aecd80537b6a.html
Beginner
Hi Adams, Country code is
Hi Adams,
Country code is already IN and more then 250 APs already registered and working in Flexconnect mode.
Kamlesh
Beginner
Hi, TAC advise us to upgrade
TAC advise us to upgrade AP software version from 15.3(3)JA1 to 15.3(3)JA4.
Kamlesh
Beginner
Hi, After upgrading IOS, it
After upgrading IOS, it is still not registering, same problem.
Kamlesh
Hall of Fame Community Legend
You are hiding some important
You are hiding some important information.
Reboot the AP and post the COMPLETE output.  I want to see what the AP is doing.
Post the COMPLETE output to the WLC command of "sh sysinfo".
Highlighted
Beginner
Hi Leo, It has been resolved,
Hi Leo,
It has been resolved, actually there is encryption enabled in WAN link which was not enabled at WLC side, after enabling encryption, all APs register without upgrade.
Kamlesh
Beginner
Hi Kamlenegi, I have same
Hi Kamlenegi,
I have same problem with my WLC and AP. How did you fix the problem?
Content for Community-Ad
August's Community Spotlight Awards
