354
Beginner
5.2 dBi pillar-mount Dual omnidirectional antennas
Hi ,
May I know when I can use this antennas? and what's purpose of design this dual omni-direcitonal antennas?
4 REPLIES 4
Re: 5.2 dBi pillar-mount Dual omnidirectional antennas
What's the exact part number ?
Beginner
AIR-ANT2452V-R
Antennas are like light bulbs. You have a regular bulb and without a lamp shade it goes everywhere. You have flash lights that have a directed light. All depends on the situation.
I haven't used this antenna myself. I look at the azimuth and gain to see how this antenna will provide coverage. This antenna has a direct coverage pattern and is an indoor antenna. One could use this for lighting up very specific areas like a flash light of sorts ..
Adding to George's post.
     the antenna you linked isn't Dual, it is for 2.4GHz only.  So IMO this would have gone on a 1230 or 1240 series AP.  You could still use it on 1600/2600/3500/3600, but you would need multiple to keep the higher 802.11n rates operational.
Most of the Antenna that are listed as Dual are Dual Banded like the AIR-ANT2544V4M-R.  In this case dual means that it is for 2.4GHz and 5GHz on the same leads, as that is required with the newer AP to have both frequencies operational
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Content for Community-Ad
August's Community Spotlight Awards
