Highlighted
Enthusiast
Re: 5508 8.0.140.0 ipad dropping connection
Check your user idle timeout configuration under the WLAN. We adjusted
that setting to a longer timeout(86400) and that resolved the issue for us.
By default, the client user idle timeout is set to 300 secs as a global
setting.
Highlighted
Participant
We solved it by replacing all our aironets with Meraki APs.
Highlighted
cheers thank you, we are considering this option too actually. good to know
it works well with Meraki
Highlighted
thank you for the tip, we'll change the setting and see how it goes,
appreciated.
Content for Community-Ad
Cisco COVID-19 Survey
