Highlighted
Beginner
5760 AP join
Hi there
Have a 5760 with 2600 APs'. When connecting AP's on L2 they join the contoller. Connecting AP's on different network they won't join.
Have tried with DNS/DHCP option 43 and manual controller config so pretty sure they know the controller :-)... I also see them in the controller but as NOT JOIN.
From controller
7c69.f604.c560  0000.0000.0000  AP7c69.f604.c560      10.252.3.207     Not Joined
7c69.f6bc.5b90  0000.0000.0000  AP7c69.f6bc.5b9a      10.252.3.216     Not Joined
7c95.f307.8f80  c08c.600f.0b7e  APc08c.600f.0b7e      10.252.0.205     Joined
With debug on controler i got the following:
Oct  2 15:12:22.443: 7C69.F6BC.5B90 Discovery Request from 10.252.3.216: 1 wcm: 50618
Oct  2 15:12:22.443: 7C69.F6BC.5B90 Discovery request: 1 wcm:  Total msgEleLen = 99
Oct  2 15:12:22.443: 7C69.F6BC.5B90 msgEleLength = 1 msgEleType = 20
1 wcm:  = 99
Oct  2 15:12:22.443: 7C69.F6BC.5B90 Discovery Type = Static Config
1 wcm:
Oct  2 15:12:22.443: 7C69.F6BC.5B90 Total msgEleLen = 94
1 wcm:  Config
Oct  2 15:12:22.443: 7C69.F6BC.5B90 msgEleLength = 40 msgEleType = 39
1 wcm: = 99
Oct  2 15:12:22.443: 7C69.F6BC.5B90 Total msgEleLen = 50
1 wcm: eType = 39
Oct  2 15:12:22.444: 7C69.F6BC.5B90 msgEleLength = 1 msgEleType = 41
1 wcm:
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Total msgEleLen = 45
1 wcm: Type = 41
Oct  2 15:12:22.444: 7C69.F6BC.5B90 msgEleLength = 1 msgEleType = 44
1 wcm:
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Total msgEleLen = 40
1 wcm: Type = 44
Oct  2 15:12:22.444: 7C69.F6BC.5B90 msgEleLength = 10 msgEleType = 37
1 wcm: = 99
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Vendor specific payload from AP 7C69.F6BC.5B90 validated
1 wcm: 0x0
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery request: 1 wcm:  Vendor payload type = 207, length = 10
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Board data options: 1 wcm:  apType 0, joinPriority 1
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Total msgEleLen = 26
1 wcm: ype 0, joinPriority 1
Oct  2 15:12:22.444: 7C69.F6BC.5B90 msgEleLength = 22 msgEleType = 37
1 wcm: riority 1
1 wcm:
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery request: 1 wcm:  Vendor payload type = 5, length = 22
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Total msgEleLen = 0
1 wcm: dor payload type = 5, length = 22
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery apType = 0, apModel = , Discovery supportedRadios = 0, incomingRadJoinPriority = 1, Discovery versionNum = 117702949 1 wcm: 0
Oct  2 15:12:22.444: 7C69.F6BC.5B90 AP Model not populated in Discovery Request. Let the AP proceed to Join & veify AP model in Join request. 1 wcm: rsionNum = 117702949
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 1000, joined Aps =1 1 wcm: in request.
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Validated Discovery request with dest ip : 1 wcm:  10.252.0.24 from AP  10.252.3.216. Response to be sent using ip : 10.252.0.24
Oct  2 15:12:22.444: 7C69.F6BC.5B90 1. 0 0
1 wcm: d Discovery request with dest ip : 10.252.0.24 from AP  10.252.3.216. Response to be sent using ip : 10.252.0.24
Oct  2 15:12:22.444: 7C69.F6BC.5B90 2. 232 3
1 wcm: Discovery request with dest ip : 10.252.0.24 from AP  10.252.3.216. Response to be sent using ip : 10.252.0.24
Oct  2 15:12:22.444: 7C69.F6BC.5B90 3. 1 0
1 wcm:
Oct  2 15:12:22.444: 7C69.F6BC.5B90 4. 232 3
Oct  2 15:12:22.444: 7C69.F6BC.5B90 msgLength = 36
1 wcm: ery request with dest ip : 10.252.0.24 from AP  10.252.3.216. Response to be sent using ip : 10.252.0.24
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery resp: 1 wcm:  AC Descriptor message element len = 40
Oct  2 15:12:22.444: 7C69.F6BC.5B90 acName = WLC01.Billundkommune.dk
1 wcm: age element len = 40
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery resp: 1 wcm: AC Name message element length = 67
Oct  2 15:12:22.444: 7C69.F6BC.5B90 CAPWAP_DOT11_MSGELE_WTP_RADIO_INFORMATION supported radio types 0
1 wcm: 252.3.216. Response to be sent using ip : 10.252.0.24
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery resp: 1 wcm:  WTP Radio Information msg length = 76
Oct  2 15:12:22.444: Encode static AP manager 10.252.0.24, AP count 1
1 wcm: on msg length = 76
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery resp: 1 wcm:  CAPWAP Control IPV4 Address len = 86
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery resp: 1 wcm:  CAPWAP Control IPV6 Address len = 108
Oct  2 15:12:22.444: acEncodeMwarTypePayload encode mwarType = 1  in capwapMwarTypePayload. 1 wcm: o types 0
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery resp: 1 wcm:  Mwar type payload len = 119
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Send AP Timesync of 1380726742 source MANUAL 1 wcm: pePayload.
Oct  2 15:12:22.444: 7C69.F6BC.5B90 Discovery resp: 1 wcm:  Time sync payload len = 134
Oct  2 15:12:22.444: 7C69.F6BC.5B90 encodeLen = 134 len = 16
1 wcm: payload len = 134
Oct  2 15:12:22.444: acEncapSendPacket via CAPWAP_CTRL_UDP_PORT,length 150, ipAddr 0xafc0018, mwarPort 5246,lradIp 0xafc03d8, lradPort 50618, dtls_flags 0x0, frag 0 1 wcm:  4:^HXLhe^EwH):^H\177
Oct  2 15:12:22.444: sock 0x89 len 150 src 0xafc0018(0x147e) dst 0xc5ba(0xafc03d8) appl_flags 0x0 1 wcm: Port 5246,lradIp 0xafc03d8, lradPort 50618, dtls_flags 0x0, frag 0
Oct  2 15:12:22.445: 7C69.F6BC.5B90 Discovery Response sent to 10.252.3.216: 1 wcm: 50618
Oct  2 15:12:22.445: 7C69.F6BC.5B90 WTP already released 1 wcm: nt to 10.252.3.216:50618
Oct  2 15:12:22.823:  Recieved CAPWAP Packet from(port =47344 srcAddr=10.252.0.205) 1 wcm: ppl_flags.D^Ew
Oct  2 15:12:22.823: CAPWAP Control Msg Received from 10.252.0.205: 1 wcm: 61624
Oct  2 15:12:22.823: 7C95.F307.8F80 length = 4, packet received from 7c95.f307.8f80
1 wcm: pl_flags.D^Ew
Oct  2 15:12:22.823: 7C95.F307.8F80 packet received of length 40 from 10.252.0.205: 1 wcm: 61624
Oct  2 15:12:22.823: <<<<  Start of CAPWAP Packet  >>>> 1 wcm: ength 40 from 10.252.0.205:61624
Oct  2 15:12:22.823: CAPWAP Control mesg Recd from 10.252.0.205, Port 61624 1 wcm: .0.205:61624
Oct  2 15:12:22.823:         HLEN 4,   Radio ID 0,    WBID 1 1 wcm: 05, Port 61624
Oct  2 15:12:22.823:         Msg Type   : 1 wcm:    CAPWAP_WTP_EVENT_REQUEST
Oct  2 15:12:22.823:         Msg Length : 1 wcm:  10
Oct  2 15:12:22.823:         Msg SeqNum : 1 wcm:  96
Oct  2 15:12:22.823:    1 wcm:      Msg SeqNum : 96
Oct  2 15:12:22.823:      Type : 1 wcm:  CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 6
Oct  2 15:12:22.823:         Vendor Identifier  : 1 wcm:  0x00409600
Oct  2 15:12:22.823:
    IE            : 1 wcm:    UNKNOWN IE 0
Oct  2 15:12:22.823:     IE Length     : 1 wcm:    0
Oct  2 15:12:22.823:     Decode routine not available, Printing Hex Dump
1 wcm: ngth 6
Oct  2 15:12:22.823:
1 wcm:   Decode routine not available, Printing Hex Dump
Oct  2 15:12:22.823: <<<<  End of CAPWAP Packet  >>>>
1 wcm: Printing Hex Dump
Oct  2 15:12:22.823: 7C95.F307.8F80 Msg Type = 9 Capwap state = 11
1 wcm: Dump
Oct  2 15:12:22.823: 7C95.F307.8F80 WTP Event Request from 10.252.0.205: 1 wcm: 61624
Oct  2 15:12:22.823: 7C95.F307.8F80 WTP event request: 1 wcm:  Total msgEleLen = 10
Oct  2 15:12:22.823: 7C95.F307.8F80 WTP event request: 1 wcm:  msgEleLength = 6 msgEleType = 37
Oct  2 15:12:22.823: 7C95.F307.8F80 Vendor payload type = 0, length = 0
1 wcm: sgEleType = 37
Oct  2 15:12:22.823: 7C95.F307.8F80 WTP event request: 1 wcm:  Total msgEleLen = 0
Oct  2 15:12:22.823: 7C95.F307.8F80 encodeLen = 0 len = 8
1 wcm: l msgEleLen = 0
Oct  2 15:12:22.823: 00000000: 1 wcm:  00 00 00 0a 60 00 03 00                           ....`...^M
Oct  2 15:12:22.823: <<<<  Start of CAPWAP Packet  >>>> 1 wcm:                          ....`...^M
Oct  2 15:12:22.823: CAPWAP Control mesg Sent to 10.252.0.205, Port 61624 1 wcm:        ....`...^M
Oct  2 15:12:22.823:         Msg Type   : 1 wcm:    CAPWAP_WTP_EVENT_RESPONSE
Oct  2 15:12:22.823:         Msg Length : 1 wcm:  0
1 wcm: EVENT_RESPONSE
Oct  2 15:12:22.823: 7C95.F307.8F80 Sending encrypted packet to AP 10: 1 wcm: 252:0:205 (61624)
Oct  2 15:12:22.823: acEncapSendPacket via CAPWAP_CTRL_UDP_PORT,length 16, ipAddr 0xafc0018, mwarPort 5246,lradIp 0xafc00cd, lradPort 61624, dtls_flags 0x3, frag 1 1 wcm:
Oct  2 15:12:22.823: sock 0x89 len 16 src 0xafc0018(0x147e) dst 0xf0b8(0xafc00cd) appl_flags 0xc 1 wcm: Port 5246,lradIp 0xafc00cd, lradPort 61624, dtls_flags 0x3, frag 1
Oct  2 15:12:22.824: 7C95.F307.8F80 WTP Event Response sent to 10.252.0.205: 1 wcm: 61624
Oct  2 15:12:22.824: 7C95.F307.8F80 Releasing WTP 1 wcm: onse sent to 10.252.0.205:61624
Output on  AP:
*Mar  1 00:00:26.147: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:26.147: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:26.287: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:26.855: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:29.667: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed
*Mar  1 00:00:29.667: DPAA Initialization Complete
*Mar  1 00:00:29.667: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:30.667: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:54.747: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:59.715: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.252.3.218, mask 255.255.255.0, hostname APc08c.600f.0e52
Translating "CISCO-CAPWAP-CONTROLLER.wireless.local"...domain server (10.252.0.30) [OK]
*Mar  1 00:01:09.647: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:48.079: %CDP_PD-4-POWER_OK: Full power - NON_CISCO-NO_CDP_RECEIVED inline power source
*Mar  1 00:01:49.167: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:50.167: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:50.259: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:51.259: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
Not in Bound state.
*Mar  1 00:02:05.147: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:02:08.155: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:02:08.219: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.252.3.218, mask 255.255.255.0, hostname APc08c.600f.0e52
*Mar  1 00:02:16.147: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
On controller the following command is set: wireless management interface Vlan600
(the AP VLAN is 2040 for this particular location....ping is fine)
I'm a bit stucked (and almost missing the aOS CT :-))... Anyone has a suggestion or hint?
Best Regards
Kasper
5 REPLIES 5
Highlighted
Hall of Fame Community Legend
You didn't configure DHCP Option 43.
Highlighted
Hmm, I see the AP's on the controller (as NOT JOIN), so i think they know the controller (DNS configured..also static controller address)... Don't know why they keep complaining about this DHCP IP...
Option 43 also configured... only with 0A FC 00 18 type in...no option 60-vendor specific used.
Rg
Kasper
Highlighted
It was a routing issue... AP JOIN now works....
Bg
Kasper
Highlighted
I had the "AP Model not populated in Discovery Request. Let the AP proceed to Join & veify AP model in Join request." message today and APs were not joining when primary controller was set on the current controller, by command line on the AP via a console cable and with an Option 43 configured on DHCP. 5760s are new to our organisation, and this is my first day with them.
Googled the error message and this thread was the only result.
Routing issue was that there isn't a field to enter ip default gateway via the GUI. Entered it via command line and my APs started joining.
Highlighted
Hello Kasper,
What routing issue did u faced? I´ve the same issue but AP and WLC can see each other.
*Apr 12 11:27:51.446: %IOSXE-7-PLATFORM: 1 process wcm: f8c2.88a3.5060 Discovery Request from 10.20.250.195:13575
*Apr 12 11:27:51.446: %IOSXE-7-PLATFORM: 1 process wcm: f8c2.88a3.5060 Discovery apType = 0, apModel = , Discovery supportedRadios = 0, incomingRadJoinPriority = 1, Discovery versionNum = 117637429
*Apr 12 11:27:51.446: %IOSXE-7-PLATFORM: 1 process wcm: f8c2.88a3.5060 AP Model not populated in Discovery Request. Let the AP proceed to Join & veify AP model in Join request.
*Apr 12 11:27:51.446: %IOSXE-7-PLATFORM: 1 process wcm: f8c2.88a3.5060 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 1000, joined Aps =42
*Apr 12 11:27:51.446: %IOSXE-7-PLATFORM: 1 process wcm: f8c2.88a3.5060 Validated Discovery request with dest ip : 10.16.127.1 from AP 10.20.250.195. Response to be sent using ip : 10.16.127.1
*Apr 12 11:27:51.446: %IOSXE-7-PLATFORM: 1 process wcm: Encode static AP manager 10.16.127.1, AP count 42
*Apr 12 11:27:51.446: %IOSXE-7-PLATFORM: 1 process wcm: acEncodeMwarTypePayload encode mwarType = 0 in capwapMwarTypePayload.
*Apr 12 11:27:51.446: %IOSXE-7-PLATFORM: 1 process wcm: f8c2.88a3.5060 Discovery Response sent to 10.20.250.195:13575
_lucas
Content for Community-Ad
