01-21-2016 10:06 AM - edited 07-05-2021 04:31 AM
8.0MR3 (8.0.132.0) is now posted, the beta process is closed. Thanks for all the feedback!
Resolved Caveats
CSCtl96208 |
capwap ap hostname CLI returns "ERROR!!! Command is disabled." |
CSCtu45614 |
Spectrum Management Bit Should be set to 1 all the time |
CSCul07738 |
DPAA Tx/Rx stuck; reload due to ethernet interface receive failure |
CSCum86031 |
Roaming 5508 to 5760 applies wrong QOS policy on configuring aaa-overrid |
CSCun12965 |
Lightweight AP should not send jumbo frame by default |
CSCun52472 |
show dtls connection shows blank in AP Name column for Capwap_Data |
CSCuo16301 |
HA:-Unable to pair up the active/Standby wlc due to config sync failure. |
CSCuo48442 |
Stale old DTLS data_encryption session histories are left on WLC |
CSCup13091 |
Local eap, local user, created for specific WLAN works for diferent wlan |
CSCup56257 |
SNMP PMIP NAI type attribute support is required |
CSCup64468 |
WLC device sends invalid format "#" in front of syslog message |
CSCup68372 |
Stats are carried over when session timeout occurs |
CSCup72502 |
5500 on 7.6 does not deauth client when Flex ACL is not present on AP |
CSCup75446 |
Default interface takes precedence over foreign VLAN mapping with CWA |
CSCup80403 |
Low iMac Tput -supported rate IE in association response has ZERO length |
CSCup88910 |
630937505 - AP impersonation flood of events on WLC 8510-SR14-00512 |
CSCuq50069 |
SHA1 key cipher not working between WLC 80 and MSE 80 CCO versions. |
CSCuq56604 |
GRE key DB can leak in case of flapping clients |
CSCuq56829 |
Flex+Bridge Maps drop after assoc - Failed to receive data keep-alive |
CSCuq68753 |
5500 anchor running 7.6.122.21 crashed on osapiBsnTimer |
CSCuq73590 |
WLC adds incorrect class attribute in accounting stop |
CSCuq86274 |
1530 dfs detection across all channels |
CSCuq88573 |
Thunderbird-[DBS] : Client type count is incorrect |
CSCuq88748 |
Rogue APs wrong classification from malicious to unclassified |
CSCur08754 |
Local auth is not working for flex ap auth users |
CSCur11060 |
False positive on honeypot alert with multple SSIDs |
CSCur13400 |
DHCP Option 82 and Sub Option 5 issue in WLC 8.0 |
CSCur24512 |
3602/3702 unexpected reload |
CSCur25239 |
Controller crash on mping command over telnet/ssh |
CSCur30618 |
SNMP WALK fails for all APS if Country code is not present for single AP |
CSCur32475 |
NewMobility Web-Auth on MacFilter Failure always send client to web-auth |
CSCur33320 |
SC1/SC2/SC3 Radio reset w/ FW stuck in macenb (Cont. of CSCuo27106) |
CSCur43124 |
WSSI module stops working after Upgrade from 7.4.121.0 to 7.6 MR3 |
CSCur46376 |
Controller crash with task "webauthRedirect" under heavy load |
CSCur48612 |
8.1 emWeb crash when adding devices to mDNS policy |
CSCur48944 |
Problem in Client Stats Reports and Optimized Roaming |
CSCur49165 |
WiSM2 system crash radiusTransportThread aaaRadiusAuth |
CSCur57909 |
Client misses to override vlan after shifting wlan. |
CSCur60218 |
New mobility web auth on mac filter failure Export Anchor request fails |
CSCur69774 |
8500 wlc crashed with snmp task |
CSCur71315 |
1552 bridge Transmit voice queue stuck leading to out of TX buffers |
CSCur74208 |
Name/OID: cLMobilityExtMgrAddress.0; Returning in IP in Reverse Order |
CSCur80006 |
Unable to enable HTTPS redirect in WLC GUI |
CSCur80935 |
8.0.100.0:AAA overridden acl is not applied on Guest access controller |
CSCur88307 |
AP name unknown in dissoc messages (Intermittent) |
CSCur90555 |
T8.0 WLC keeps ghost client entry |
CSCur91936 |
MDNS discovery issue with WLC 8.0.100 |
CSCur94924 |
emWeb Memory Leak on 8500 SP WiFi Profile Testbed |
CSCur95365 |
Controller crashes when issuing command show ap config general |
CSCur98573 |
Memory increase on DTLS connections when >500 APs join 5508. |
CSCur99863 |
CWA: WLC 8.0 some times moves to RUN state while in redirect state |
CSCus03406 |
Dataplane crash on 8500 WLC with 7.6 |
CSCus03487 |
AP 3700 sends wrong TLV during power level negotiation |
CSCus07013 |
Adding mac filter check when client is changing SSID for webauth |
CSCus17191 |
AP 1142 DHCP renew delay after Eap-Fast authentication |
CSCus20991 |
Radius NAC Client auth issues for 7.6.130.0 |
CSCus21502 |
Flex AP1142 crashes while debug dot11 mgmt station enabled |
CSCus30429 |
OEAP600 not giving ip on remote LAN port in 8.0 |
CSCus33759 |
Local Policies not working after OUI Update |
CSCus39396 |
8.0.100.0 QoS Bronze Profile not marking traffic to AF11 on Flex |
CSCus46424 |
Band select not working on 1042 AP |
CSCus48467 |
Core file upload fails crash file not showing any content for WLC crash |
CSCus53635 |
Add 802.11a Philipines country support for 1532I Aps joined to 5760. |
CSCus54751 |
sisfSwitcherTask crash and came up with blank config |
CSCus61445 |
DNS ACL on wlc is not working - AP not Send DTLS to WLC |
CSCus62323 |
Web-Auth on MacFilter Failure mobility enum change needed |
CSCus68340 |
Standby keeps auto rebooting and stays in "STANDBY COLD" state |
CSCus73932 |
Multicast configuration issue on 8510 WLC OS 8.0.110.4 |
CSCus74299 |
New mobility:Client not deleted on 5508 when it roams at webauth state |
CSCus76833 |
CT5508 crashes at sisfSwitcherTask |
CSCus77368 |
WLC: Crash ewaFormSubmit_cell_edit |
CSCus77477 |
NGWC Increase the number of URLs allowed in a DNS ACL in wlc |
CSCus78002 |
AP1262 crash right after STACKLOW for Dot11 DB Audit |
CSCus79185 |
QN - Standby Controller crash on fp_main_task |
CSCus80249 |
Reaper reset with APF Guest crash with scale |
CSCus80478 |
CAP1530 not forward send packets to wired side after bootup |
CSCus80685 |
AP sends few frames with previous security association's packet number |
CSCus89468 |
Need to add AP802 to list of APs that support Flex+Bridge mode |
CSCus89485 |
Negative rogue count reported in show rogue ap summary |
CSCus91251 |
Probe Filter mis-config causing issues with FastLocate and FlexConnect |
CSCus91439 |
WLC - Memory leak - k_mib_cisco_lwapp_dot11_client.c |
CSCus92667 |
GET on Ap groups Table after set - response missing |
CSCut02524 |
default NAS-ID value at the AP-Groups should be empty or "none" |
CSCut03762 |
On 8500-Endianess issue with debug mobility keep-alive enable peer-ip |
CSCut06502 |
WLC crash due to task name RRM-CLNT-5_0 |
CSCut09821 |
Unused Data DTLS session is remained on WLC running 7.6.130.19 |
CSCut11821 |
WLC: ad-hoc containment doesn't stop |
CSCut14459 |
session ID changes for an intercontroller client roam using EAPFAST |
CSCut14796 |
Cafe-17 Alpha: NMSP link is down between MSE10 and WLC5500 (8.1.10.183) |
CSCut16170 |
Mobility tunnel down after switchover on 7.6 |
CSCut18071 |
IRCM Guest access mobility failing during roam test. |
CSCut21931 |
EmWeb Core "spamGetMeshRunningConfig" when configure mesh network |
CSCut22092 |
Client Disassociated due to inactivity ReasonCode: 4 |
CSCut23325 |
1700 AP not encrypting icmp and arp sent from the client over the air |
CSCut24276 |
unexpected PMKID count field in beacon's RSN IE |
CSCut25670 |
CSCuwAP: %DTLS-5-SEND_ALERT: Send FATAL; join failure loop |
CSCut27598 |
Client unable to get IP when switching wlan on New mobility. |
CSCut31468 |
local profile showing wrong stats under Manufacturer Stats |
CSCut35315 |
Negative rogue count reported in show rogue ap summary - GUI changes |
CSCut39010 |
Multiple APs Reset with Beacons Stuck |
CSCut39118 |
WLC 8510 Failure to collect feature MobilityExtGroupMember on PI 2.2 |
CSCut40305 |
console logs are creating during AP-GUI login session and pse status |
CSCut42926 |
WLC crash on SNMPtask after doing config audit from PI |
CSCut43770 |
PMIPv6 Client Traffic is Sent to the Wrong LMA |
CSCut46811 |
3702 AP not accepting clients on 5Ghz when WIPs Submode enabled |
CSCut48172 |
LSC AP provisioning happening after MAP is disconnected for long time |
CSCut56741 |
AP1600: Radio reset with "STOPPING CPQ FWD TRACE ON Bad CPQ removal" |
CSCut62319 |
Broadcast Key Rotation won't occur after MAC Filtering enabled |
CSCut64504 |
Race condition on the AP for delete and add driver client |
CSCut70403 |
WLC crashed with task name 'HAConfigSyncTask' |
CSCut74263 |
MAG on AP:AP does not clear bindings after session/user timeout & deauth |
CSCut76481 |
WLC sends 1499 bytes MTU switchover |
CSCut85027 |
AP is generating corrupted coredump |
CSCut87326 |
WLC generates SNMP traps to PI 2.2 for AIR-3702 PoE+ getting low power |
CSCut88267 |
WLC unexpected reload in task webauthRedirect during client redirect |
CSCut93569 |
MSE - NMSP inactive with WLC |
CSCut93712 |
AP not send RM IE for 11k in association response; no 11k for iOS > 8.1 |
CSCut97683 |
WLC crash on spamApTask2 8.0.110.0 |
CSCut98006 |
DFS detections due to high energy profile signature on 2600/3600 |
CSCut99150 |
2702 AP requesting as a Type 1 power device instead of Type 2 |
CSCuu02281 |
APs on WLC with wireless networks disabled detecting rogues |
CSCuu05565 |
NDP packets not tx'ed on secondary20 channels |
CSCuu06047 |
Packet drops on 2702 AP in flex local auth/local switch mode |
CSCuu07700 |
EAP Packet does not get encrypted in Re-auth request from client |
CSCuu08592 |
Override interf interf-group not been applied on reauth for IPv6 clients |
CSCuu08752 |
SXP Crash when running Trust Sec clients |
CSCuu12045 |
Mobility mac configuration should not be uploaded in the config file |
CSCuu20097 |
Token Bucket leak when QoS Roles setup and when working with WebAuth |
CSCuu23521 |
WLC 5520 crash with task name radiusTransportThread |
CSCuu25362 |
1 byte corruption in capwap payloads using TLV infra |
CSCuu28534 |
Client username doesn't changes when switched from WPA2 802.1x to PSK |
CSCuu30530 |
PMIPv6 sh run correction |
CSCuu37437 |
WLC8510 crashing while NMSP polling in progress. |
CSCuu42396 |
AP radio FW image install failure in the bootup |
CSCuu44155 |
RAP takes 15 minutes to use wired connection if there are wireless peers available |
CSCuu45186 |
dot11 arp-cache does not works well |
CSCuu47016 |
Cisco Application Visibility and Control UDP Vulnerability |
CSCuu54100 |
Switching between SSIDs fails with FAST SSID enabled on PMIPv6 WLANs |
CSCuu57971 |
Sanity: ctlr system crash when ap image predownload |
CSCuu59589 |
False positive AP sourced AP impersonation on corrupted beacon |
CSCuu66675 |
Lock crash on radiusTransportThread during CMCC external auth |
CSCuu68490 |
duplicate radius-acct update message sent while roaming |
CSCuu72366 |
Silent Crash 8.0.110.11 mmListen process |
CSCuu77304 |
Clients deauthenticated from OEAP 600 LAN ports |
CSCuu77738 |
Prime 3.0 Auto Provisioning is not working |
CSCuu82416 |
Evaluation of wlc for OpenSSL June 2015 |
CSCuu82610 |
WLC dtls_free should zero out memory |
CSCuu83748 |
WLC sends bsnRogueAPRemoved Trap when notify configured none |
CSCuu83941 |
8510: Error enabling global multicast with capwap mode unicast |
CSCuu91001 |
Netflow record sent without client IP address |
CSCuu93296 |
EAP-TLS loosing device certificate in standalone mode after reboot |
CSCuu98792 |
AP 1570, antenna enable config is lost on reboot |
CSCuu98971 |
controller crash during HA testing |
CSCuu99344 |
WLC crash - DHCP packet content while on new mobility |
CSCuu99662 |
Controller crash with 8.1.104.30 8.1MR1 |
CSCuv00107 |
PMIPv6 Client MAC Address shows up on the mac address table of Switch |
CSCuv00598 |
Optimized Roaming per WLAN feature |
CSCuv01337 |
config pmipv6 add profile error not clear when profile length>32 |
CSCuv03963 |
WLC dataplane crash: "fatal condition at broffu_fp_dapi_cmd.c" |
CSCuv04474 |
Sanity: AP1700 crashed during multicast client traffic(cont.CSCuu89311) |
CSCuv08570 |
1532 AP loses all config at times after power cycle |
CSCuv09655 |
Anchor crash on 8.0.110.14 New Mobility apf_msDeleteTblEntry |
CSCuv13731 |
3702 AP sends burst traffic - AMPU/MSDU/Off-channel/RRM disabled |
CSCuv22052 |
Link local multicast control traffic sent by Aps IGMP Snooping Enabled |
CSCuv22936 |
AP Flapping -- capwap keepalives are not replied to. |
CSCuv22951 |
Radio reset with reset code of 37 . |
CSCuv24097 |
multicast from Pmipv6 client show client mac on layer3/2 switch |
CSCuv27320 |
Wired clients in 702w AP leaking traffic across ports/vlans |
CSCuv28555 |
3702 - Voice Queue stuck with no new clients able to associate. |
CSCuv31162 |
WLC 5500 Crashes continously in HA Setup@task: apfRogueTask_2 and 3 |
CSCuv34277 |
Wireless Client not able to get IP address on 3650 MA from 5508 anchor |
CSCuv34946 |
EOGRE and PMIPv6 client fails to move to Run state |
CSCuv36505 |
8.0 WLC messages flooding cli after debug client |
CSCuv37613 |
Apple devices failing 802.11r FT roam |
CSCuv51521 |
Active WLC should send GARPs when HA Re-Paring after Active-Active state |
CSCuv53952 |
SSID still broadcasted by the AP after the wlan is deleted from wlc |
CSCuv59274 |
1142 CPU spike and utilization is 100% all the time |
CSCuv61271 |
Window DHCP BAD_ADDRESS for Access Points |
CSCuv67144 |
Need to re-evaludate Algeria if in -E or -I |
CSCuv69967 |
OEAP600 wired 802.1x remote LAN forward traffic in 802.1x Required State |
CSCuv74719 |
Apple Clients EAP-FAST Authentication Failure |
CSCuv77499 |
Dynamically excluded client not updated in UI of Controller |
CSCuv82110 |
vWLC: Decrypt errors occurred for client using WPA2 key on 802.11a intf |
CSCuv85747 |
Mobility Member entries going stale |
CSCuv86494 |
WLC clears AP MAC before deleting client sends netflow with Zero AP MAC |
CSCuv87657 |
8.0/8.1 WLC's fail to send FRAMED-IP attribute to AAA server |
CSCuv87839 |
Wired clients in 702w AP getting put in mgmt vlan |
CSCuv90042 |
Fastlocate distant clients have strong rssi value from AP intermittently |
CSCuv90333 |
Pineridge - afpmsConntask flood when running client console debug |
CSCuv95254 |
Failed to associate cisco7925 phones |
CSCuv96333 |
readonly user able to change "Telnet Capability" setting |
CSCuv97793 |
WiSM2 crash AP_DB_CREATE_ERR Message queue MFP-Q is nearing full |
CSCuw01581 |
WISM WLC crashes in 'SISF BT Process' with 8.2.1.71 |
CSCuw03414 |
WLC crash: "Software Failed while accessing the data" |
CSCuw06127 |
Silent crash 8.0.120 due to memory leak in CDP Main |
CSCuw10610 |
Non authenticated HTTP page allows to logout any connected client |
CSCuw12544 |
Rate-limiting is causing 500ms gap of traffic when roaming |
CSCuw13264 |
702w missing interface information on controller after HA failover |
CSCuw15008 |
Mobility Task Hogs CPU - Reaper Reset in SpamApTask |
CSCuw18179 |
Wism2 crashed with SNMP task on 8.2.1.71 |
CSCuw18257 |
Wism2 Pri&Sec clear-conf "MEM_ALLOC_FAILED"&"Standby IPC failure" |
CSCuw18589 |
Duplicate radius IDs causing conflicting packets at the Radius servers |
CSCuw24476 |
Increased Ping latency & Reduced traffic on 8510 with QOS rate limiting |
CSCuw24958 |
AP fails to transmit ADDBA response if a data packet is retried prior. |
CSCuw26377 |
Crash due to invalid form field validation on switch_cfg_rw.html |
CSCuw28141 |
Reaper Reset: Task "SNMPTask" missed software watchdog |
CSCuw29564 |
APs show 0 neighbors on 5GHz band and client 802.11 packets are ignored |
CSCuw35341 |
IP address lost on AAA override+muiltiple subnetworks per vlan+DHCP req |
CSCuw35349 |
DHCP registration failing when mask from WLC intf does not match client received mask |
CSCuw35395 |
8.2 Reap ACL msg send should be sent from spam context. |
CSCuw37942 |
Local EAP hardening |
CSCuw44480 |
802.11r client fails auth if self reset before user idle timeout expires |
CSCuw50324 |
Crash on high CPU for bonjour |
CSCuw57588 |
C3600 AP crash on am_xml_GetChildCount |
CSCuw57850 |
Filtering for client calibration pulses with frequency offset |
CSCuw71432 |
ME: Iphones/Ipads unable to connect 11r enabled WLAN bec of invalid MDID |
CSCuw79765 |
WLC: System Crash: apf80211vTask |
CSCuw87468 |
Rogue containment not working on 8.0.120.0 for AP3700 with WSM module |
CSCuw89581 |
WLC System Crash on apfReceiveTask |
CSCuw90625 |
Rogue rules not applied correctly after upgrade to 7.6.130.30 |
CSCuw91763 |
Feature "AES Key Wrap" does not work |
CSCuw94949 |
Invalid FTIE MIC on ME WLC when client tries FT roam between IOS APs |
CSCuw97316 |
show client detail displaying "allowed URL" IP in reverse format |
CSCuw97431 |
Mobility MAC is not synced to Standby WLC |
CSCux00512 |
WLC_L2-auth_cleints_dropping_ReasonCode23_&_AAA_Error_Out_of_Memory |
CSCux02735 |
50%clients DHCPreq state wlan with interface-grp with client static ip |
CSCux03108 |
8510 crashed on Task Name:portalMsgTask. |
CSCux06492 |
AP is sending RM IE in Re-assoc response for non-11k clients |
CSCux07993 |
DNS-ACL: Redirection happening for the defined URL's also |
CSCux18259 |
PI 3.0 - Sync Issue on Flexconnect Native VLAN Configuration |
CSCux22620 |
8510 WLC crash in radiusTransportThread system task |
CSCux22935 |
HA+802.11r:Post SSO FT PSK/EAP Apple clients fails to connect. |
CSCux37498 |
CoA with wlc 8.1.131.0 shows error message on ISE server |
CSCux39331 |
8500 crashed with Task Name:osapiBsnTimer reason:Reaper reset |
CSCux41354 |
Evaluation of wlc for OpenSSL December 2015 vulnerabilities |
CSCux44741 |
Wism crashed on build 8.2.1.139 reason SXP CRASH |
CSCux47470 |
8.0.110.14 controller crash at openssl_cert_hash_algo_check_callback |
CSCux53523 |
Interface NASID is not updating when client moves between interfacegroup |
CSCux69928 |
Wism2 Silent crash PMALLOC_DOUBLE_FREE on 8.0.122.18 MR3 |
CSCux82268 |
8.0MR3:Support for 11v clients to show '11v supported' in client detail |
CSCux83098 |
CSCux83635 |
FATAL: Couldnt Send message out prints on 5500/7500 standby console |
CSCux86824 |
WLC - Kernel hang condition after crash |
CSCux91000 |
wlc uses its Virtual IP (instead of Mgmt IP) to communicate with PI |
CSCux94240 |
Interop- 11vDMS fails with 3600 + xale module |
CSCux95619 |
Prime controller auto provisioning not working |
CSCux96677 |
Client not associatied with Radius NAC enabled WLAN |
CSCuy04186 |
Interop- 11k failure in flex mode as no RM IE in reassociation response. |
CSCuy06619 |
Interop- 11r preauth failure leading to full association |
CSCuy11085 |
Incorrect nasid send when Ap group and wlans have different interface |
03-07-2016 06:43 AM
hi Kevin
if the OUI file is corrupted, it may not be changed on upgrade
The fix prevents invalid files to damage the OUI listing, but depending on the state of the list in your WLC, it may need to be manually uploaded, which you did.
if the problem needs follow up, please write to us at the wnbu-mr... alias
02-08-2016 08:47 PM
We've also been hitting CSCux56652 but have had to move to MR3 to resolve a different issue for now. Hoping for an MR3 escalation build with this fix...
02-29-2016 02:56 AM
can you seperate the list again so that we can see which bugs were fixed in the newer versions.
I would like to know which bug is new fixed between the 8.0.122.44 and the 8.0.122.50
03-23-2016 02:01 PM
Is there an update on when 8.0.130 will be available? I sent an email this morning to the email above to at least get the latest build, but haven't received a response as of yet. Thanks.
03-23-2016 02:12 PM
I am waiting for newer 8.0.122.x build to be released. A bug I have been waiting to be fixed recently and added to the 8.0.122.50 build. Unfortunately a new build has not been released yet. Like to get a newer build for testing if possible so we can examine the fix.
03-23-2016 03:54 PM
8.0.122.55 is available internally I believe. I saw it as a fixed version for a bug I was checking the other day.
03-28-2016 02:23 AM
hi
I will publish release candidate this week, we were waiting on final update to accommodate regulatory changes for FCC
regards
03-30-2016 02:07 AM
Do you know when this week. ? We will have got a maintenance windows next week on the 7.4.2016 and i would like to update directly to 8.0.130 for 10 WISM2 Controllers with about 2500 APs. I Have got running on one WISM2 the Beta 8.0.122.44. And would like to upgrade this bevor the maintenance window. For final Testing.
Feel free to Contact me.
03-30-2016 02:11 AM
hi
Current plan is to publish tomorrow. I will notify the registered beta customers when the final gold build is done, and it has passed validation
regards
04-01-2016 07:34 AM
Hi Javier
is there an delay for the publish ? because at the moment i can't find the release on the homepage :(.
04-01-2016 07:40 AM
yes, sorry on delay. There was a extremely corner case on the final build creation, and it has been delayed. There are no issues on the 8.0MR3 content itself, just on final image creation and stamping.
The problem is now resolved, and the final build (8.0.132.0) is under testing right now
if all goes well, it should be posted very soon
regards
04-01-2016 12:34 PM
Will this be the 'final' release, or is there still another release coming with the FCC changes? Will this release support the updated FCC channels/power levels, and support the '-B' APs? Also, will older '-A' APs be able to utilize the new changes, or only the new '-B' APs?
Thanks.
04-01-2016 11:24 PM
Final release, 8.0.132.0, is now available on the beta forum. The files are being posted in CCO, and should show up in the next few hours.
This has support to the new -B FCC APs (updated channels/powers).
The new channels are only available on -B APs. Both can coexist on same controller. For migration of -A to -B, please contact your account team for options.
04-01-2016 11:25 PM
hi Tobias
The final release is being posted now (it takes few hours), you can alternatively access them through the beta forum
regards
04-03-2016 12:56 PM
Thank you for the Updated. I have upgraded 2 WISM 2 Controller yesterday. And the rest next week.
