8.0MR3 Beta Availability
Javier Contreras
8.0.122.x Available - 8.0MR3 Beta
8.0MR3 (8.0.132.0) is now posted, the beta process is closed. Thanks for all the feedback!
Resolved Caveats
CSCtl96208
capwap ap hostname CLI returns "ERROR!!! Command is disabled."
CSCtu45614
Spectrum Management Bit Should be set to 1 all the time
CSCul07738
DPAA Tx/Rx stuck; reload due to ethernet interface receive failure
CSCum86031
Roaming 5508 to 5760 applies wrong QOS policy on configuring aaa-overrid
CSCun12965
Lightweight AP should not send jumbo frame by default
CSCun52472
show dtls connection shows blank in AP Name column for Capwap_Data
CSCuo16301
HA:-Unable to pair up the active/Standby wlc due to config sync failure.
CSCuo48442
Stale old DTLS data_encryption session histories are left on WLC
CSCup13091
 Local eap, local user, created for specific WLAN works for diferent wlan
CSCup56257
SNMP PMIP NAI type attribute support is required
CSCup64468
WLC device sends invalid format "#" in front of syslog message
CSCup68372
Stats are carried over when session timeout occurs
CSCup72502
5500 on 7.6 does not deauth client when Flex ACL is not present on AP
CSCup75446
Default interface takes precedence over foreign VLAN mapping with CWA
CSCup80403
Low iMac Tput -supported rate IE in association response has ZERO length
CSCup88910
630937505 - AP impersonation flood of events on WLC 8510-SR14-00512
CSCuq50069
SHA1 key cipher not working between WLC 80 and MSE 80 CCO versions.
CSCuq56604
GRE key DB can leak in case of flapping clients
CSCuq56829
Flex+Bridge Maps drop after assoc  - Failed to receive data keep-alive
CSCuq68753
5500 anchor running 7.6.122.21 crashed on osapiBsnTimer
CSCuq73590
WLC adds incorrect class attribute in accounting stop
CSCuq86274
1530 dfs detection across all channels
CSCuq88573
Thunderbird-[DBS] : Client type count is incorrect
CSCuq88748
Rogue APs wrong classification from malicious to unclassified
CSCur08754
Local auth is not working for flex ap auth users
CSCur11060
False positive on honeypot alert with multple SSIDs
CSCur13400
DHCP Option 82 and Sub Option 5 issue in WLC 8.0
CSCur24512
3602/3702 unexpected reload
CSCur25239
Controller crash on mping command over telnet/ssh
CSCur30618
SNMP WALK fails for all APS if Country code is not present for single AP
CSCur32475
NewMobility Web-Auth on MacFilter Failure always send client to web-auth
CSCur33320
SC1/SC2/SC3 Radio reset w/ FW stuck in macenb (Cont. of CSCuo27106)
CSCur43124
WSSI module stops working after Upgrade from 7.4.121.0 to 7.6 MR3
CSCur46376
Controller crash with task "webauthRedirect" under heavy load
CSCur48612
8.1 emWeb crash when adding devices to mDNS policy
CSCur48944
Problem in Client Stats Reports and Optimized Roaming
CSCur49165
WiSM2 system crash radiusTransportThread aaaRadiusAuth
CSCur57909
Client misses to override vlan after shifting wlan.
CSCur60218
New mobility web auth on mac filter failure Export Anchor request fails
CSCur69774
8500 wlc crashed with  snmp task
CSCur71315
1552 bridge Transmit voice queue stuck   leading to out of TX buffers
CSCur74208
Name/OID: cLMobilityExtMgrAddress.0;  Returning in IP in Reverse Order
CSCur80006
Unable to enable HTTPS redirect in WLC GUI
CSCur80935
8.0.100.0:AAA overridden acl is not applied on Guest access controller
CSCur88307
AP name unknown in dissoc messages (Intermittent)
CSCur90555
T8.0 WLC keeps ghost client entry
CSCur91936
MDNS discovery issue with WLC 8.0.100
CSCur94924
emWeb Memory Leak on 8500 SP WiFi Profile Testbed
CSCur95365
Controller crashes when issuing command show ap config general
CSCur98573
Memory increase on DTLS connections when >500 APs join 5508.
CSCur99863
CWA: WLC 8.0 some times moves to RUN state while in redirect state
CSCus03406
Dataplane crash on 8500 WLC with 7.6
CSCus03487
AP 3700 sends wrong TLV during power level negotiation
CSCus07013
Adding mac filter check when client is changing SSID for webauth
CSCus17191
AP 1142 DHCP renew delay after Eap-Fast authentication
CSCus20991
Radius NAC Client auth issues for 7.6.130.0
CSCus21502
Flex AP1142 crashes while debug dot11 mgmt station enabled
CSCus30429
OEAP600 not giving ip on remote LAN port in 8.0
CSCus33759
Local Policies not working after OUI Update
CSCus39396
8.0.100.0 QoS Bronze Profile not marking traffic to AF11 on Flex
CSCus46424
Band select not working on 1042 AP
CSCus48467
Core file upload fails  crash file not showing any content for WLC crash
CSCus53635
Add 802.11a Philipines country support for 1532I Aps joined to 5760.
CSCus54751
sisfSwitcherTask crash and came up with blank config
CSCus61445
DNS ACL on wlc is not working - AP not Send DTLS to WLC
CSCus62323
Web-Auth on MacFilter Failure mobility enum change needed
CSCus68340
Standby keeps auto rebooting and stays in "STANDBY COLD" state
CSCus73932
Multicast configuration issue on 8510 WLC OS 8.0.110.4
CSCus74299
New mobility:Client not deleted on 5508 when it roams at webauth state
CSCus76833
CT5508 crashes at sisfSwitcherTask
CSCus77368
WLC: Crash ewaFormSubmit_cell_edit
CSCus77477
NGWC Increase the number of URLs allowed in a DNS ACL in wlc
CSCus78002
AP1262 crash right after STACKLOW for Dot11 DB Audit
CSCus79185
QN - Standby Controller crash on fp_main_task
CSCus80249
Reaper reset with APF Guest crash with scale
CSCus80478
CAP1530 not forward  send packets to wired side after bootup
CSCus80685
AP sends few frames with previous security association's packet number
CSCus89468
Need to add AP802 to list of APs that support Flex+Bridge mode
CSCus89485
Negative rogue count reported in show rogue ap summary
CSCus91251
Probe Filter mis-config causing issues with FastLocate and FlexConnect
CSCus91439
WLC - Memory leak - k_mib_cisco_lwapp_dot11_client.c
CSCus92667
GET on Ap groups Table after set - response missing
CSCut02524
default NAS-ID value at the AP-Groups should be empty or "none"
CSCut03762
On 8500-Endianess issue with debug mobility keep-alive enable peer-ip
CSCut06502
WLC crash due to task name RRM-CLNT-5_0
CSCut09821
Unused Data DTLS session is remained on WLC running 7.6.130.19
CSCut11821
WLC: ad-hoc containment doesn't stop
CSCut14459
session ID changes for an intercontroller client roam using EAPFAST
CSCut14796
Cafe-17 Alpha: NMSP link is down between MSE10 and WLC5500 (8.1.10.183)
CSCut16170
Mobility tunnel down after switchover on 7.6
CSCut18071
IRCM Guest access mobility failing during roam test.
CSCut21931
EmWeb Core "spamGetMeshRunningConfig" when configure mesh network
CSCut22092
Client Disassociated due to inactivity ReasonCode: 4
CSCut23325
1700 AP not encrypting icmp and arp sent from the client over the air
CSCut24276
unexpected PMKID count field in beacon's RSN IE
CSCut25670
CSCuwAP: %DTLS-5-SEND_ALERT: Send FATAL; join failure loop
CSCut27598
Client unable to get IP when switching wlan on New mobility.
CSCut31468
local profile showing wrong stats under Manufacturer Stats
CSCut35315
Negative rogue count reported in show rogue ap summary - GUI changes
CSCut39010
Multiple APs Reset with Beacons Stuck
CSCut39118
WLC 8510 Failure to collect feature MobilityExtGroupMember on PI 2.2
CSCut40305
console logs are creating during AP-GUI login session and pse status
CSCut42926
WLC crash on SNMPtask after doing config audit from PI
CSCut43770
PMIPv6 Client Traffic is Sent to the Wrong LMA
CSCut46811
3702 AP not accepting clients on 5Ghz when WIPs Submode enabled
CSCut48172
LSC AP provisioning happening after MAP is disconnected for long time
CSCut56741
AP1600: Radio reset with "STOPPING CPQ FWD TRACE ON Bad CPQ removal"
CSCut62319
Broadcast Key Rotation won't occur after MAC Filtering enabled
CSCut64504
Race condition on the AP for delete and add driver client
CSCut70403
 WLC crashed with task name 'HAConfigSyncTask'
CSCut74263
MAG on AP:AP does not clear bindings after session/user timeout & deauth
CSCut76481
WLC sends 1499 bytes MTU switchover
CSCut85027
AP is generating corrupted coredump
CSCut87326
WLC generates SNMP traps to PI 2.2 for AIR-3702 PoE+ getting low power
CSCut88267
WLC unexpected reload in task webauthRedirect during client redirect
CSCut93569
MSE - NMSP inactive with WLC
CSCut93712
AP not send RM IE for 11k in association response; no 11k for iOS > 8.1
CSCut97683
WLC crash on spamApTask2 8.0.110.0
CSCut98006
DFS detections due to high energy profile signature on 2600/3600
CSCut99150
2702 AP requesting as a Type 1 power device instead of Type 2
CSCuu02281
APs on WLC with wireless networks disabled detecting rogues
CSCuu05565
NDP packets not tx'ed on secondary20 channels
CSCuu06047
Packet drops on 2702 AP in flex local auth/local switch mode
CSCuu07700
EAP Packet does not get encrypted in Re-auth request from client
CSCuu08592
Override interf interf-group not been applied on reauth for IPv6 clients
CSCuu08752
SXP Crash when running Trust Sec clients
CSCuu12045
Mobility mac configuration should not be uploaded in the config file
CSCuu20097
Token Bucket leak when QoS Roles setup and when working with WebAuth
CSCuu23521
WLC 5520 crash with task name radiusTransportThread
CSCuu25362
1 byte corruption in capwap payloads using TLV infra
CSCuu28534
Client username doesn't changes when switched from WPA2 802.1x to PSK
CSCuu30530
PMIPv6 sh run correction
CSCuu37437
WLC8510 crashing while NMSP polling in progress.
CSCuu42396
AP radio FW image install failure in the bootup
CSCuu44155
RAP takes 15 minutes to use wired connection if there are wireless peers available
CSCuu45186
dot11 arp-cache does not works well
CSCuu47016
Cisco Application Visibility and Control UDP Vulnerability
CSCuu54100
Switching between SSIDs fails with FAST SSID enabled on PMIPv6 WLANs
CSCuu57971
Sanity: ctlr system crash when ap image predownload
CSCuu59589
False positive AP sourced AP impersonation on corrupted beacon
CSCuu66675
Lock crash on radiusTransportThread during CMCC external auth
CSCuu68490
duplicate radius-acct update message sent while roaming
CSCuu72366
Silent Crash 8.0.110.11 mmListen process
CSCuu77304
Clients deauthenticated from OEAP 600 LAN ports
CSCuu77738
Prime 3.0 Auto Provisioning is not working
CSCuu82416
Evaluation of wlc for OpenSSL June 2015
CSCuu82610
WLC dtls_free should zero out memory
CSCuu83748
WLC sends bsnRogueAPRemoved Trap when notify configured none
CSCuu83941
8510: Error enabling global multicast with capwap mode unicast
CSCuu91001
Netflow record sent without client IP address
CSCuu93296
EAP-TLS loosing device certificate in standalone mode  after reboot
CSCuu98792
 AP 1570, antenna enable config is lost on reboot
CSCuu98971
controller crash during HA testing
CSCuu99344
WLC crash - DHCP packet content while on new mobility
CSCuu99662
Controller crash with 8.1.104.30 8.1MR1
CSCuv00107
PMIPv6 Client MAC Address shows up on the mac address table of Switch
CSCuv00598
Optimized Roaming per WLAN feature
CSCuv01337
config pmipv6 add profile error not clear when profile length>32
CSCuv03963
WLC dataplane crash: "fatal condition at broffu_fp_dapi_cmd.c"
CSCuv04474
Sanity: AP1700 crashed during multicast client traffic(cont.CSCuu89311)
CSCuv08570
1532 AP loses all config at times after power cycle
CSCuv09655
Anchor crash on 8.0.110.14 New Mobility apf_msDeleteTblEntry
CSCuv13731
3702 AP sends burst traffic - AMPU/MSDU/Off-channel/RRM disabled
CSCuv22052
Link local multicast control traffic sent by Aps  IGMP Snooping Enabled
CSCuv22936
AP Flapping -- capwap keepalives are not replied to.
CSCuv22951
Radio reset with reset code of 37 .
CSCuv24097
multicast from Pmipv6 client show client mac on layer3/2 switch
CSCuv27320
Wired clients in 702w AP leaking traffic across ports/vlans
CSCuv28555
3702 - Voice Queue stuck  with no new clients able to associate.
CSCuv31162
WLC 5500 Crashes continously in HA Setup@task: apfRogueTask_2 and 3
CSCuv34277
Wireless Client not able to get IP address on 3650 MA from 5508 anchor
CSCuv34946
EOGRE and PMIPv6 client fails to move to Run state
CSCuv36505
8.0 WLC messages flooding cli after debug client
CSCuv37613
Apple devices failing 802.11r FT roam
CSCuv51521
Active WLC should send GARPs when HA Re-Paring after Active-Active state
CSCuv53952
SSID still broadcasted by the AP after the wlan is deleted from wlc
CSCuv59274
1142 CPU spike and utilization is 100% all the time
CSCuv61271
Window DHCP BAD_ADDRESS for Access Points
CSCuv67144
Need to re-evaludate Algeria if in -E or -I
CSCuv69967
OEAP600 wired 802.1x remote LAN forward traffic in 802.1x Required State
CSCuv74719
Apple Clients EAP-FAST Authentication Failure
CSCuv77499
Dynamically excluded client not updated  in UI of Controller
CSCuv82110
vWLC: Decrypt errors occurred for client using WPA2 key on 802.11a intf
CSCuv85747
Mobility Member entries going stale
CSCuv86494
WLC clears AP MAC before deleting client  sends netflow with Zero AP MAC
CSCuv87657
8.0/8.1 WLC's fail to send FRAMED-IP attribute to AAA server
CSCuv87839
Wired clients in 702w AP getting put in mgmt vlan
CSCuv90042
Fastlocate distant clients have strong rssi value from AP intermittently
CSCuv90333
Pineridge - afpmsConntask flood when running client console debug
CSCuv95254
Failed to associate cisco7925 phones
CSCuv96333
readonly user able to change "Telnet Capability" setting
CSCuv97793
WiSM2 crash AP_DB_CREATE_ERR Message queue MFP-Q is nearing full
CSCuw01581
WISM WLC crashes in 'SISF BT Process' with 8.2.1.71
CSCuw03414
WLC crash: "Software Failed while accessing the data"
CSCuw06127
Silent crash 8.0.120 due to memory leak in CDP Main
CSCuw10610
Non authenticated HTTP page allows to logout any connected client
CSCuw12544
Rate-limiting is causing 500ms gap of traffic when roaming
CSCuw13264
702w missing interface information on controller after HA failover
CSCuw15008
Mobility Task Hogs CPU - Reaper Reset in SpamApTask
CSCuw18179
Wism2 crashed with SNMP task on 8.2.1.71
CSCuw18257
Wism2 Pri&Sec clear-conf "MEM_ALLOC_FAILED"&"Standby IPC failure"
CSCuw18589
Duplicate radius IDs causing conflicting packets at the Radius servers
CSCuw24476
Increased Ping latency & Reduced traffic on 8510 with QOS rate limiting
CSCuw24958
AP fails to transmit ADDBA response if a data packet is retried prior.
CSCuw26377
Crash due to invalid form field validation on switch_cfg_rw.html
CSCuw28141
Reaper Reset: Task "SNMPTask" missed software watchdog
CSCuw29564
APs show 0 neighbors on 5GHz band and client 802.11 packets are ignored
CSCuw35341
IP address lost on AAA override+muiltiple subnetworks per vlan+DHCP req
CSCuw35349
DHCP registration failing when mask from WLC intf does not match client received mask
CSCuw35395
8.2 Reap ACL msg send should be sent from  spam context.
CSCuw37942
Local EAP hardening
CSCuw44480
802.11r client fails auth if self reset before user idle timeout expires
CSCuw50324
Crash on high CPU for bonjour
CSCuw57588
C3600 AP crash on am_xml_GetChildCount
CSCuw57850
Filtering for client calibration pulses with frequency offset
CSCuw71432
ME: Iphones/Ipads unable to connect 11r enabled WLAN bec of invalid MDID
CSCuw79765
WLC: System Crash: apf80211vTask
CSCuw87468
Rogue containment not working on 8.0.120.0 for AP3700 with WSM module
CSCuw89581
WLC System Crash on apfReceiveTask
CSCuw90625
Rogue rules not applied correctly after upgrade to 7.6.130.30
CSCuw91763
Feature "AES Key Wrap" does not work
CSCuw94949
Invalid FTIE MIC on ME WLC when client tries FT roam between IOS APs
CSCuw97316
show client detail displaying "allowed URL" IP in reverse format
CSCuw97431
Mobility MAC is not synced to Standby WLC
CSCux00512
WLC_L2-auth_cleints_dropping_ReasonCode23_&_AAA_Error_Out_of_Memory
CSCux02735
50%clients DHCPreq state  wlan with interface-grp  with client static ip
CSCux03108
8510 crashed on Task Name:portalMsgTask.
CSCux06492
AP is sending RM IE in Re-assoc response for non-11k clients
CSCux07993
DNS-ACL: Redirection happening for the defined URL's also
CSCux18259
PI 3.0 - Sync Issue on Flexconnect Native VLAN Configuration
CSCux22620
8510 WLC crash in radiusTransportThread system task
CSCux22935
HA+802.11r:Post SSO FT PSK/EAP Apple clients fails to connect.
CSCux37498
CoA with wlc 8.1.131.0 shows error message on ISE server
CSCux39331
8500 crashed  with Task Name:osapiBsnTimer  reason:Reaper reset
CSCux41354
Evaluation of wlc for OpenSSL December 2015 vulnerabilities
CSCux44741
Wism crashed on build 8.2.1.139  reason SXP CRASH
CSCux47470
8.0.110.14 controller crash at  openssl_cert_hash_algo_check_callback
CSCux53523
Interface NASID is not updating when client moves between interfacegroup
CSCux69928
Wism2 Silent crash PMALLOC_DOUBLE_FREE on 8.0.122.18 MR3
CSCux82268
8.0MR3:Support for 11v clients to show '11v supported' in client detail
CSCux83098
CSCux83635
FATAL: Couldnt Send message out prints on 5500/7500 standby console
CSCux86824
WLC - Kernel hang condition after crash
CSCux91000
wlc uses its Virtual IP (instead of Mgmt IP) to communicate with PI
CSCux94240
Interop- 11vDMS fails with 3600 + xale module
CSCux95619
Prime controller auto provisioning not working
CSCux96677
Client not associatied with Radius NAC enabled WLAN
CSCuy04186
Interop- 11k failure in flex mode as no RM IE in reassociation response.
CSCuy06619
Interop- 11r preauth failure leading to full association
CSCuy11085
Incorrect nasid send  when Ap group and wlans have different interface
32 Replies 32
hi Kevin
if the OUI file is  corrupted, it may not be changed on upgrade
The fix prevents invalid files to damage the OUI listing, but depending on the state of the list in your WLC, it may need to be manually uploaded, which you did.
if the problem needs follow up, please write to us at the wnbu-mr... alias
We've also been hitting CSCux56652 but have had to move to MR3 to resolve a different issue for now.  Hoping for an MR3 escalation build with this fix...
Feichti
can you seperate the list again so that we can see which bugs were fixed in the newer versions.
I would like to know which bug is new fixed between the 8.0.122.44 and the 8.0.122.50
kdavison007
Is there an update on when 8.0.130 will be available?  I sent an email this morning to the email above to at least get the latest build, but haven't received a response as of yet.  Thanks.
I am waiting for newer 8.0.122.x build to be released. A bug I have been waiting to be fixed recently and added to the 8.0.122.50 build. Unfortunately a new build has not been released yet. Like to get a newer build for testing if possible so we can examine the fix.
8.0.122.55 is available internally I believe.  I saw it as a fixed version for a bug I was checking the other day.
hi
I will publish release candidate this week, we were waiting on final update to accommodate regulatory changes for FCC
regards
Do you know when this week. ? We will have got a maintenance windows next week on the 7.4.2016 and i would like to update directly to 8.0.130 for 10 WISM2 Controllers with about 2500 APs. I Have got running on one WISM2 the Beta 8.0.122.44. And would like to upgrade this bevor the maintenance window. For final Testing.
Feel free to Contact me.
hi
Current plan is to publish tomorrow. I will notify the registered beta customers when the final gold build is done, and it has passed validation
regards
Hi Javier
is there an delay for the publish ? because at the moment i can't find the release on the homepage :(.
yes, sorry on delay. There was a extremely corner case on the final build creation, and it has been delayed. There are no issues  on the 8.0MR3 content itself, just on final image creation and stamping.
The problem is now resolved, and the final build (8.0.132.0) is under testing right now
if all goes well, it should be  posted very soon
regards
Will this be the 'final' release, or is there still another release coming with the FCC changes? Will this release support the updated FCC channels/power levels, and support the '-B' APs? Also, will older '-A' APs be able to utilize the new changes, or only the new '-B' APs?
Thanks.
Final release, 8.0.132.0, is now available on the beta forum. The files are being posted in CCO, and should show up in the next few hours.
This has support to the new -B FCC APs (updated channels/powers).
The new channels are only available on -B APs. Both can coexist on same controller. For migration of -A to -B, please contact your account team for options.
hi Tobias
The final release is being posted now (it takes few hours), you can alternatively access them through the beta forum
regards
Thank you for the Updated. I have upgraded 2 WISM 2 Controller yesterday. And the rest next week.
