8.2MR5 Interim Availability
Javier Contreras
Release 8.2.145.x Interim (8.2MR5)
Final  code 8.2.151.0 is now posted, thanks for your interest!
New Updated version 8.2.145.64
This release adds the following functionality:
  • TKIP  support for 2800/3800/1800
8.2.145.64
CSCvc18129    Crash on RF profile/client exclusion sync on HA scenario
CSCvd19354  WLC crash while editing config rf-profile hsr-mode disable | enable config rf-profile 11b
CSCvd20843   Beacon stuck due to off-channel stuck
CSCvd25183   2800/3800 does not advertise the extension channel correctly when DCA assigns Bandwidth.
CSCvd29298  2800/3800 - Type 3 off-channel stuck due to callback missing during off-channel
CSCvd07243  Unable to change AP name nor location from the GUI
CSCvc87207  AP2800 802.11b/g radio dropping RTP packets
8.2.145.58
CSCvd16523        AP3800/2800: New CLI to make core dump extended not persistent across upgrade
CSCvc59252        1852 AP showing only power level 1 instead of power level 1 to 8 under 5 Ghz radio
CSCvd16939        1800 Band-Select does not work
CSCvd16993        2800/3800 - Rxhang Fixes
CSCvb94413        2800/3800 -  Fix DAA
CSCvd00405        Silent reboot observed for 3800
CSCvd07657        AP1810 fails to get ARP response intermittently leading to a full reboot
CSCvd18791        2800/3800 - NSS counters after next-hop-MAC failure in capwapd
CSCva91457        WLC: repeated crashes w/Reason: spamApTask4
CSCvc52619        Local EAP do not support any of ciphers, used by 8821 phone
CSCvb77682       2800/3800 -  ioctl error message when setting XOR to 5GHz band
CSCvb73104        AP 1600: Radio d1 reset: FW: irq/mac stat=40000/10000000 command timeout
CSCvd07215        1800/2800/3800 doesn't learn dhcp lease time from dhcp server and defaults to 24hr.
CSCvd09482        2800/3800 - Rxhang Fixes
CSCvd03656       AP2800/3800 not updating ndp to WLC due to Status: NSS_INVALID_PARAM
CSCvd05596        2800/3800 - Rxhang Fixes
8.2.141.40
CSCvb94799 mc2uc packet packet lost with AP 3802E
CSCvc89939 2800/3800: 40 mhz ext offset 8.2.145.33
CSCvc90559 2800/3800: RX Hang seen on alpha 8.2.145.36
CSCvc61560 WLC radius auth aaaQueueReader "Unable to fit Radius packet in allocated memory"
CSCvb78834 wlc crashing with task name emweb
CSCvc64343 AP1530 detected a lot of radars
CSCvc60233 2800/3800: Off-channel timeout is observed
CSCvc86514 2800/3800 - AP CAPWAP reset when extended Radio coredump is enabled
CSCvc81662 2800/3800: RX Hang seen on alpha 8.2.145.26
CSCvc71905 2800/3800: AP detects radar in the absence of radar sources (8.2.131.40)
CSCvc81491 2800/3800: high latency issues on on build 8.2.145.26
CSCvb94436 TKIP support for 1800 series APs
CSCvc52004 1800: iOS device connect to the dot1x network slowly
CSCvc70133 1800/2800/3800: AP flex: MC40 11g client sending Assoc req with g rates in extended rates display issue
CSCvc80161 2800/3800 11n/ac clients failing to associate with XOR in 5GHz
CSCvc11544 Default Neighbor Pruning Timer need to be increased to keep neighbor entries for 1 hour
CSCvc76148 2800/3800 Beacon drift causing mc9060 client drops
8.2.141.26
CSCur63031
AP error: %ENTROPY-0-ENTROPY_ERROR: Unable to collect sufficient entropy
CSCur68316
802AP-891 in flexconnect mode are losing vlan mapping after power cycle
CSCuw41092
AP not send traffic indication in beacon for power-save client after FT
CSCux48308
Broadcast delivery stops with key rotation 1552 rap,  819W 153.3JBB5 wgb
CSCux51833
Client fails on RAP with AAA Override ACL when AP is in Flex+Bridge Mode
CSCux78389
Radius Failover should failover both authacct server on WLAN
CSCux85357
WLC sends GARP for flex local switching clients after HA switch-over
CSCux88967
On MAC Filter failure  Client session timeout can not association back
CSCux95319
Roaming central to local auth causes in flex caused dot1x table failures
CSCux96500
WiSM2/WLC crash on bcastReceiveTask
CSCuy30583
5520 show imm chassis shows no results and crashes WLC
CSCuy53072
SNMP cLMobilityGroupMembersTable returns wrong  value from WLC in PI
CSCuy53596
CleanAir fatal error and radio reset on Flex+Bridge AP
CSCuy64520
Access Points (AP) sending CDP packets to the wireless clients
CSCuy71409
Client detailed params not synced to standby in fast ssid scenario.
CSCuy75241
5508 system crash with task mmMobility
CSCuy82849
Memory leak found@mm_heartbeat module on Guest anchor WLC
CSCuz05218
Barbados: show ap auto-rf   does not display  xor slot(0) neighbors
CSCuz11717
3-sec delay before sending "dot1x auth initiate" to SPAM with WSSI
CSCuz16883
Address registration issues for mobility scenarios
CSCuz18811
Flex: Local Switching WLAN is changing to Central Switching WLAN on add
CSCuz33818
profiler:  double free issue
CSCuz35221
Mobility handoff fails in new mobility dot1x CWA client reconnect
CSCuz40066
Guest Anchor:Foreign to Foreign roam fails on GA scenario
CSCuz40970
8510 anchor WLC Crash on task osapiBsnTimer
CSCuz49968
8.0 MR4 WLC crash during SNMP set opeartion
CSCuz50774
WLC lossing pings to itlsef Reaper cleaning up exited task osapi_ping_rx
CSCuz67292
Client not moving to RUN state after CAS perform posturing on client
CSCuz77747
Flexconnect: AP 1602 loses native vlan config on reload
CSCuz78555
Bulk sync status "In-progress" after standby boots up
CSCva01578
BARBADOS Ap not showing Syslog Server ip  with DHCP option-7
CSCva01762
AP1815/50: Over-ride Global credentials cleared on GUI after reboot
CSCva03376
UX-AP3702i After primed carrier set 5GHz only allowing four UNII3 ch
CSCva22440
3800: QBSS STA Count keeps incrementing with STA associating again
CSCva28211
AireOS UX AP : 'JP' should be used as world mode in Beacon/Probe Res
CSCva28524
WLC 8.3 - Creating SNMP community fails
CSCva31178
AP: 8.3 - Radio reset due to offchannel stuck
CSCva32411
Clients losing connectivity when reauth with DOT1X over 702w AP
CSCva48201
Unable to set static IP for AP from controller GUI
CSCva52825
2800/3800 does not do PMTU discovery during join/image download
CSCva63541
2/3800 AP CAPWAP restarts continuously during FTP transfer of large file
CSCva72724
AP2602 Crash "disc_tx_requeue_client" "dot11_get_rate_shift"
CSCva74487
8540 crash on running show commands task :emWeb
CSCva74927
Barbados Flex - AP disjoins with 'Failed to get ARP entry for WLC' error
CSCva83234
Barbados : Kernel Crash during image download
CSCva83884
WLC System crash on aaaQueueReader
CSCva87295
Flex AP radio reset during FT with Central dhcp and Nat-pat enabled
CSCva90343
Unable to do VLAN to RLAN mapping at FlexConnect Group
CSCva95251
DSCP traffic is not limited to maximum QoS Profile value
CSCvb09381
Unable to add or modify SNMP strings on a 5520 HA Pair running 8.1.122.0
CSCvb25233
Enable VLAN-RLAN Mapping in FlexConnect Group
CSCvb28231
Controller crashed due to memory corruption
CSCvb35173
Barbados: Radio crash  beacon stuck - due to lost txq reference
CSCvb43105
Barbados outer DSCP not same as inner with DSCP Trust upstream NSS
CSCvb44169
emWeb reaper reset after "clear mdns service-database all"
CSCvb44699
NMSP queue full due to Rouge AP task.
CSCvb48603
Evaluation of wlc for Openssl September 2016
CSCvb52310
Silent Boot on 2800/3800
CSCvb54166
Malformed 11v element on HSR WGB with WLC 8.2+
CSCvb66080
VLAN override from ISE is not working for RLAN with FlexConnect Local Switching
CSCvb69962
Client traps not showing session ID's
CSCvb71168
RSA256-AES256 dtls encryption lowers PMTU but AP doesnt' respect it
CSCvb72380
performance profile show all values as 0 after clear config for XOR radio
CSCvb79274
WGB wired client expiring periodically
CSCvb80511
CWA is not working for flex-bridge APs pointing ACL rx from Radius doesn't exist
CSCvb81003
WLC crashes as emWeb uses 100%
CSCvb81359
WLC 8540 HA. RMI ping and access to standby fail when using non-default ap-manager
CSCvb85576
Evaluation of wlc for CVE-2016-5195 (DIRTY CoW)
CSCvb89781
2700-B AP unable to join WLC: Unable to create temp dir "flash:/update"  LR= 0xc011e2dc
CSCvb90403
AP1810W hardware watchdog reset at PC= 0xc03b3ffc
CSCvb90793
AP name unknown in SNMP bsnDot11StationDeauthenticate traps
CSCvb92562
Evaluation of all for Openssl 1.0.1 September 2016
CSCvb94610
Restore command to disable GARP
CSCvb94697
2800/3800 11n macbook client has dropping connectivity while connecting to AP3800
CSCvb95147
AP 1572EAC unable to use 80MHz
CSCvc00358
WLC crash  "apfRogueTask_0" missed software watchdog
CSCvc09824
the AP2800 band select stats counter show zero
CSCvc13175
GLC-T SFP stopped working in CT5520 (1G Port down on 5520)
CSCvc15149
Barbados 8.2 MR4 - Not beaconing a SSID when it is in an AP group and SSID enabled later
CSCvc16755
AP3802 custom power level not initialized after reboot
CSCvc18699
Corsica: High pings drops  traffic connectivity drops seen 8.2.131.40
CSCvc23658
Clients not removed from flexconnect and capwap in APs flexconnect central-sw
CSCvc25669
rfidTask is causing a high CPU on the WLC
CSCvc29030
100MHz channel separation between 5G band with XOR in monitor mode
CSCvc31133
Unable to enable wlan with enabled selected option in GUI. Security: FT + Open
CSCvc31304
83MR1: AP syslog flood for TLV-DEC-ERR: cannot process TLV for TLV_DMS_CLIENT_REQUEST_PAYLOAD(325/0)
CSCvc32706
3800 APs: Not seeing all COS neighbors
CSCvc32856
Barbados: Sends a AQ Event as soon as RRM changes channel causing bad channel selection and changes
CSCvc33258
WLC: Unable to config RX-SOP threshold for IW3702 AP
CSCvc33511
SNMPv3 access failing with either unknown user / no response
CSCvc38214
2800/3800 Sending Acks to client at 54 data rate although Basic rate is 12 & 24
CSCvc39963
Barbados : FRA revert command failing to revert XOR to 2.4GHz
CSCvc40470
AP radio hang chatter: wl0: rxRingStuckDetect(271): RX-HANG Detected!!
CSCvc40564
TPC - Maximum/Minimum power level are not set as expected
CSCvc42566
1702I AP - radio resets observed due to CleanAir error count exceeded
CSCvc42741
AP3800/AP2800 : Failed to receive data keepalive and  Process capwapd gone
CSCvc42939
3800 AP duplicating multicast packets
CSCvc43232
2800/3800 uses 11n data rates to send data packets to 11b only clients failing to assoc
CSCvc43328
2800/3800 Sending Acks to client at 54 data rate although Basic rate is 12 & 24 in 8.2Mr4Esc
CSCvc45038
2800/3800 Beacon drift 25ms with offchannel/cleanair scanning @3sec mc9060 client drops
CSCvc48232
AP crash due to kernel panic at mhsm_transition
CSCvc50228
2800/3800 Sending Data packets to the 11g clients sometimes with messed up data rates
CSCvc50377
WLC7500: emWeb crash while doing "show run-config" on 8.0.110.11
CSCvc53578
2800/3800 11b only clients does not associate if HT is disabled
CSCvc53675
1852 AP - kernel backtrace at ol_ath_tx_mgmt_wmi_send+0x0/0x1e4
CSCvc74695
XOR radio pushes local-mode AP config for flex-mode AP causing Client disconnect
53 Replies 53
Leo Laohoo
Hi Javier,
Will CSCvc57427 be addressed with this release?
There is no fix available at this time, development is working on it, initial evaluation points to a leak related to AAA override function. if the fix is ready for the time window for MR5, 8.4, 8.3, we will try to include it
regards
Thanks, Javier.
patoberli
not planned for MR5 at this time (no fix ready yet)
The  bug is on investigation phase, there was a debug image provided, plus some debugs pending, development is on hold waiting for that data.
regards
Ok thanks, opened a TAC yesterday for this issue (that bugid is not mine) as we also have this issue with our new 2800 models. Working fine with 2700 and 3700 with 80 MHz channels and the same test client.
But yeah, maybe it's also an Intel issue (which I really don't hope, as my clients are unmanaged).
ok... please let TAC know if a debug image is possible. you can send me the case ID on email, so my colleague working on this issue can check it.
For intel, for all of their 11ac cards, it is extremely recommended to load the 19.20.3 bundle, as it has important fixes
regards
Damn, that is my next step actually that I should test. But I couldn't do that with our users, as those are mostly "external" clients where I can't do anything.
Interestingly it works fine with the older 802.11AC models (2700, 3700 with 80 MHz channel).
Will send you an email with the with the TAC. I might be able to install a debug image, but on my old and now unused 5508 controller. The live network (with the bug) is on a 5520 controller though.
[edit]
clarified controllers.
Update on my case. With my two test clients (Windows 7 x64 + Intel 8260AC / Windows 10 x64 + Intel 7265AC) it was an Intel driver issue, fixed in the latest version 19.20.3 (Win 7) and 19.30 (Win 10). With those drivers the packetloss disappeared.
But we also found a new issue, for which a new TAC will be opened, if the 2800 AP is set to 80 MHz and a channel order which isn't from low to high (for example DFS has chosen 40,36,44,48), then the Intel 8260AC has a really low performance and only connects with 20 MHz speeds. Once the channels were manually reordered (by manually configuring the channels and selecting 36 is the primary), the client connected with 80 MHz.
It's yet unclear if this is an Intel issue or 2800 one, as we don't have it on 3700 and 2700 models, where DFS also tends to order the channels like this. I haven't yet received the new TAC number.
Definitely if using Intel's 11ac adapters (726x/826x), you will want to be sure to use current drivers (at least 19.20.3 bundle.)
That said, we have our share of just-fixed issues on our (2800/3800) side as well.  We've recently fixed several bugs that revolve around channel width changes (e.g. CSCvc81491, fixed in 8.2.145.32, and I think another that I can't find right now.)  So do run the latest 8.2 MR5 interim that you can get, then upgrade to CCO 8.2 MR5 once it releases (within the next several weeks.)
If you should hit some interop issue between our APs and Intel adapters that we can't figure out, then be sure that you have a TAC case open, and be sure that TAC finds or files a corresponding bug.  If you willing to capture OTA pcaps etc. we can bring in Intel as needed to resolve any lingering issues.
Cheers,
Aaron
Thanks for the update. Maybe this bug is the issue I have, I will probably soon see.
This "new" channel ordering issue is with the latest drivers. Luckily I'm in no hurry to replace my old APs with the 2800 models, they can stay a few more weeks in the box, until 8.2 MR5 is released.
ilja.sas
Javier,
We seem to experience CSCvc32706 with 2800 Series AP's.
They do not see their neighbor AP's even though they are a few meters apart.
DCA and TPC do not work properly due to this.
Out of 135 AP's, 90 are on channel 36 and all run TXpower level 1.
Any suggestions for a workaround other then manual channel and power assignments?
sorry, no workaround. You can use either 8.2MR4Esc (through TAC), or load this interim 8.2MR5, which already has the fix
regards
We managed to get RRM running properly again by rebooting all AP.
They now see their neighbor AP's and can make TPC and DCA calculations.
Any idea if the issue can suddenly reappear?
