04-07-2017 02:21 AM - edited 07-05-2021 06:49 AM
We are pleased to announce Beta Refresh Release for 8.3MR2.
Please Register at below link to participate in the Beta Program. Once Registered a separate Email will be received with Software Download Link.
Resolved Caveats
Identifier | Headline |
CSCvb05067 | Local EAP fails after wrong username login |
CSCve01552 | Unknown Username when switching from open to dot1x SSID |
CSCve13183 | AP2800/3800/1800 WCPD Crash with clients connected and can't recover after crash |
CSCuz47559 | error saving config file happens on multiple 2702 |
CSCve34143 | Wlan-vlan mapping not working sometime when ap removed and added back in flex grp |
CSCvd20251 | DP stopped working on 5508 running 8.0.140.0 |
CSCvb93365 | WLC msglog showing a lot of traceback |
CSCvd72432 | LocalEAP LDAP Request With Incorrect Password Lockout Users |
CSCve05840 | Addition of DP show commands as part of show run-config |
CSCvb74948 | AVC - CISCO-JABBER-IM application is getting misclassified as SSL |
CSCvd36259 | ME Controller intermittently Flaps with external AP. |
CSCvd96491 | SR: Rest/API for WLC exposing Assurance login password |
CSCux11777 | 1532 non-root bridge high retransmission and latency rate |
CSCvb62874 | Radio interface Input queue gets filled on Autonomous APs. |
CSCvc49713 | AP generates flood of Received and decoded a DMS client request payload SUCCESSFULLY |
CSCvc81929 | Mobility Express crashes when DHCP screen is accessed |
CSCvd58113 | wlc allowing telnet and ssh over ipv6 on global telnet and ssh disabled |
CSCvd66657 | AP 3802: SensorD stuck in offchannel causing radio stops working |
CSCvd90117 | AP3800 - Radio crashing frequently due to beacon stuck |
CSCvd92166 | Couldn't pass host testie build in the branch 8.3 mr throttle in richardson ads, but can pass in sjc |
CSCvd99909 | 8.3 MR2: AP 3800 - 5G Radio crashes - when SI enabled |
CSCve07524 | In GUI 11ac config behavior mismatch with CLi for different AP mode |
CSCve06701 | Client stuck in DHCP_REQD on flex AP after changing native vlan |
CSCvd43728 | Ap1850 DTLS Teardown after channel change |
CSCve18484 | Clear data icon is not working if other languages like korean,japanese is selected in browser |
CSCve13073 | MC9090 doesn't join with 11g disabled |
CSCve01109 | SXP connection on WLC stays off. |
CSCve21379 | During Auto Provisioning Feature, Radius Server Templates are getting applied but staying Disabled. |
CSCvc44293 | 8.4 - ME UI - Changing Transmit power on UI does not work |
CSCvd67178 | Anchor not deleting webauth req client beyond webauth timeout |
CSCve09531 | v6udp_csum_buf overshooting the buffer resulting in WLC crash |
CSCvc81082 | Polaris XOR: The radio is updated as UP whenever AP's XOR band is configured eventhough POE is low |
CSCve17730 | Kernel panic seen due to wlTxDone in 8.2.151.7 |
CSCux97132 | AP starts CAC timer after rolling back to lower bandwidth |
CSCvd53205 | DCA lists in RF profiles are broken after backup/restore the WLC's config |
CSCvd87065 | WLC crash due to task nmspTxServerTask |
CSCve17355 | Upgrade to WLC - 8.3 software enables 11k & 11v by default on all WLANs |
CSCvc41484 | Corsica: high failure rate in off-channel operation, QCA 2721453 |
CSCvc86951 | AP1850 beacon miss/corruption during downstream traffic test, QCA 02793762 |
CSCvc98310 | AP 1830: 2.4-GHz radio stopped working @0x009915D7, QCA 02797962 |
CSCvd18732 | AP 1810 radio FW Assert @0x0099B2DA in overnight multi-client test, QCA 02818890 |
CSCvd28594 | Client association fail after altering data rates in AP 1830. |
CSCvd28645 | AP sending RTS at 6 data rate when data rate 6 is disabled, QCA 02829301 |
CSCvd77037 | AP1832 sending instant ACK after CTS that block data from client, QCA 02862955 |
CSCve00464 | AP1852 detects high noise level on 5-GHz radio for every channel except the serving one |
CSCve10751 | Clients cannot assocate with AP after changing from DFS to non-DFS channels during CAC, QCA 02910240 |
CSCvb57350 | SNMP trap for "AP Interface Up/down Traps" not getting generated. |
CSCvd69782 | Roaming L3 test was failed with 50% in Talwar and Pata WLC |
CSCvd80962 | 8.3MR2: LWAPP-3-AP_LOCK_ERR traceback observed on WLC for AP2800/3800 AP |
CSCvd81926 | CCX Proxy arp flag not set in IOS APs |
CSCve08894 | Unable to debug VRRP issues unless have devshell access |
CSCvb70551 | COS AP's rebooted due to Kernel Panic-Not Syncing: Out of Memory |
CSCvc81429 | 8.2MR5: AP3800 throughput drop in client scale test with random client MAC addresses |
CSCvd61747 | AP3800: Radio crash due to off channel stuck due to defer_chchange_flag always set to TRUE |
CSCvd91894 | 3800/2800 kernel panic crash PC is at mv_dev_kfree_skb+0xc/0xa4 [ap8x] |
CSCvd96867 | Sanity: radio1FW core found in ap1560 with 8.4.2.52 |
CSCve14081 | AireOS: Same channel has been assigned to both the 5Ghz Radios after capwap restart |
CSCuw45964 | Mobility Express: While Editing a WLAN in HTTP session ,user is getting logged out |
CSCvd37808 | 8510 WLC stopped working - iappSocketTask |
CSCvb04932 | APs not discovered because of wrong bsnAPIfType returned for 1810W |
CSCvd06463 | AMSDU packets tx cause 5sec gap of packet tx to 8821 from IOS AP |
CSCvd44446 | Retried EAP Response Dropped as a duplicate while First EAP Response was not even received on the AP |
CSCve30199 | CCKM PMK (Version 2) message flooding 8.3MR2 |
CSCve23103 | AP3800: False RADAR detection without RADAR source |
CSCve23874 | BARBADOS-Client got associate immediately even if CAC timer start on AP log ,when DFS channel is set |
Resolved Caveats
CSCvc67005 | 2802 AP drops client ARP packets after web authentication |
CSCvc08052 | DFS false detection on AP2700 |
CSCva90265 | iPAD PRO with IOS10 is getting deauthenticated at times due to M3 timer |
CSCvc86170 | ClickAP FlexConnect Local Auth doesn't work on WLAN with CCKM security |
CSCvd85995 | AP3800:AP deauth client after roaming and doesn't send deauth when client sends qos null |
CSCvd18773 | 8.2 clients unable to authenticate 'Sending assoc-resp with status 12 station' |
CSCvd90669 | Need support for AAA override w/ MAC filtering on RLAN |
CSCvd79597 | Smart License 5520/8540 : Unable to reset HTTP-Proxy on Call home configuration from GUI |
CSCvd70755 | AIR-AP3802I crash due to kernel panic |
CSCvc49492 | AP1852 detects high noise level on 5-GHz radio |
CSCvd56581 | Client not getting IP address when moving between SSID |
CSCvd14806 | APs randomly not showing any neighbors on both radios |
CSCvd97103 | IPv4 CPU ACL - IP-Address with netmask other than 255.255.255.255 doesn't work |
CSCvd98548 | Kernel panic inside ForwardFrame function! |
CSCva17630 | WLC sends warm-start trap instead of cold-start during autoprovisioning |
CSCvd54154 | All AP1850 connected to master AP crash in a loop due to watchdog reset |
CSCvd86274 | 1800/2800/3800 Series AP does not send the Platform value via CDP when it is brand new |
CSCvc74876 | 8.2.145.21: Barbados CAPWAP disconnect then stuck in discovery loop |
CSCvd91770 | Trust-DSCP-Upstream broken on 8.2.151.0 |
CSCvd88630 | AP 3800: Ap crash due to 'wcpd' in 8.4 |
CSCve01859 | With FIPS enabled on 5520WLC, 3802AP shows no 5Ghz neighbors |
CSCvc82845 | WLC returns nothing for SNMP get WEB ACL - cldcClientAaaOverrideAclName |
CSCvd36736 | AP in local sw/local auth disconnect EAP-SIM client idle for more than 0.5 second |
Resolved Caveats
CSCvd40646 | AP2802 - Kernel Panic - Dot11Classifier: Mgmt frame not supported 0 |
CSCvd69992 | AP: 2800/3800 unable send proper sequence# and burst rate upstream |
CSCva44397 | WLC gateway not reachable after disabling LAG |
CSCvc15976 | Trustsec: AP: Not able to enable/disable AP inline tagging and SGACL Enforcement via SNMP |
CSCvb54392 | 3800: MacBook Pro Clients with OS X 10.11 getting stuck in DHCP_REQ |
CSCvd46216 | AP1832 sometimes does not send authentication response |
CSCvd46314 | Standalone COS AP should reject new client if MAC auth is configured |
CSCvd72664 | 1850 AP sometimes tags 802.1q vlan for native WLAN, causing ARP packet drop |
CSCvd74063 | AP1832 Crash due to watchdog reset(wcpd no heartbeat) |
CSCva26821 | Auto Anchor Deployment: Scheduling deletion of Mobile Station fails |
CSCvb77390 | WLC stopped working accessing MAC Address Database |
CSCvd32632 | Standby Controller stopped working @rmgrReboot |
CSCvd42348 | Standby WLC stopped working on performing SNMP Set on bsnDot11QosProfileEntry |
CSCvc85164 | 11k: WNM neighbor report is empty in when WLAN ID is greater than 1 |
CSCvd61977 | 2800/3800 -radio coredump generation may stuck ca_status leading to IPC call function failures |
CSCva33212 | Re introduce auto provisioning feature on WLC 2504 running 8.0 |
CSCva46506 | Flexgroup RADIUS configurations are not pushed to AP |
CSCva84030 | Increase CLI WLC username and password to 128 char for TACACS support. |
CSCva88600 | Evaluation of WLC for TCP August 2016 |
CSCvb71600 | WLC stopped woking after applyng CPU ACL |
CSCvc40852 | 82MR4. Active controller in HA pair shows different socket errors |
CSCvd50044 | System stopped working multiple times on ping rx task |
CSCva88319 | 5508-HA-WLC stopped working with Task Name: TransferTask |
CSCvb64042 | WLC HA transfer download failure with legitimate network latency |
CSCvb93189 | AP drops Retransmitted M3 from WLC |
CSCvd15742 | AP crash with %ENTROPY-0-ENTROPY_ERROR: Unable to collect sufficient entropy |
CSCvd83741 | AP: 1850 unable send proper sequence# and burst rate upstream from AP to MSE |
CSCvd30952 | RM3010L-B-K9 Hyperlocation Module stopped working |
CSCvd81303 | 2800/3800: Limit 'best' DCA to 80 MHz also for RF profiles |
CSCva14667 | GET on Ap groups Table after set - response missing |
CSCvc94648 | Evaluation of wlc for OpenSSL Jan 2017 |
Resolved Caveats
CSCvd24540 | SNMP System crash when tried to create tunnel with clGatewayTunnelEntry MiB |
CSCvd19354 | WLC crash while editing config rf-profile hsr-mode disable | enable config rf-profile 11b |
CSCuz47786 | FlexConnect AP sending IGMP report to WLC for local switching WLAN |
CSCvb86157 | clients can't connect anymore to vWLC- Instrumented code added |
CSCvc67465 | Flex AP loses vlan mapping if vlan tagging is enabled. |
CSCvd37960 | 83MR2-clients getting re-anchored if critical application is present on client |
CSCvb64560 | CISCO-LWAPP-AAA-MIB: DEFVAL format incorrect for some objects |
CSCvb67724 | 5508 is going out of memory |
CSCvb69962 | Client traps not showing session ID's |
CSCvb98859 | AP in local sw/local auth disconnect EAP-SIM client idle for more than 0.5 second |
CSCvc52210 | After reboot of the Master AP, CMX connector service has to be disabled/enable for Test link to work |
CSCvd33140 | ME 8.4 - Constant increase in WLC Memory reaching 90% and above |
CSCvd35988 | 8.5 5520WLC-HA causing DENY rule on WLC and Telnet&Gui access down |
CSCvb20553 | Coa for session timeout not working using free radius server |
CSCvb53368 | validate rogue clients against AAA not work |
CSCvc11630 | Radio reset in switching to connected mode from standalone |
CSCvc24485 | #APF-3-UNKNOWN_RADIO_TYPE: [SS] apf_utils.c:571 Unknown Radio Type 0 from Standby flooding syslog |
CSCvc65675 | WLC: Constantly increasing memory consumption by SNMPTask |
CSCva72390 | 8.4.1.27 - Corsica in Bridge intermittently stalls show commands ... |
CSCvc03468 | 2800/3800: Packets not beamforming with beamforming enabled. |
CSCvc49263 | RLAN-VLAN mapping misconfigured after moving to secondary |
CSCvc55328 | AP crash due to kernel panic at WlLoadRateGrp |
CSCvc86979 | 2800 AP silent reboot with NUL print every 10 mins continuously |
CSCvc93398 | AP2800/AP3800 MU-MIMO forms MU groups with 2SS clients |
CSCvc95222 | 1810w LAN port dropping IPTV packets when wired device is 100M(QCA 02835075) |
CSCvd20271 | Ap 3800 crash 8.3.104.131 in Monitor mode with wips submode |
CSCvd27285 | ME_1852E : CCO image download re-initiated on the APs on which the Dwnld was alrady completed |
CSCvd29564 | Layer 2 Packet Drop Of CDP Packets for COS APs |
CSCvd35231 | AP1810W: Reload Reason: 0: Unknown aka Silent Reboot |
CSCva99545 | Invalid information displayed in show cert webauth/webadmin |
CSCvb45130 | Part of ATF config is not pushed to uploaded config |
CSCvb62478 | Wlan is allowed to be enabled when FT enabled without FT-psk/FT-802.1x |
CSCvc61652 | m25/1.0 is shown in client info |
CSCvc63169 | Flex AP specific WLAN-VLAN Mapping lost on rebooting the AP |
CSCva99052 | Configuring 1810W to OEAP does not enable DHCP on Local port LAN3 |
CSCvb29996 | 1810W Hardware Watchdog reset crash PC=0xc03b3ffc, LR=0xc008af24, QCA 02698633 |
CSCvb54306 | 1815: LED blikning green - light green even at full power and clients connected |
CSCvc07184 | Media streaming behavior different between 1560/3800 and 3700 |
CSCvd20843 | Beacon stuck due to off-channel stuck |
CSCvd21051 | AP3800: Kernel crash at wlTxDone+0x190/0x688 [ap8x] |
CSCvd51674 | AP1810W: Silent reboot : revert highest power table value |
CSCva81406 | WLC - Unmap deauth reason codes 13-22 from reason code 15 exclusively |
CSCva92917 | Observed Traceback logs in show msglog and logging |
CSCvc83583 | 5520 controller crashed with taskname apfProbeThread |
CSCvc87433 | Webauth with proxy doesn't work after 8.2 |
CSCvc88997 | FRA probe suppression config not saved after WLC reboot |
CSCvd01586 | WLC crash - Task Name: RRM-DCLNT-2_4 | rrmClientCoverageHoleAlgorithm |
CSCvd05332 | After changing AP mode to FlexConnect, AP does not assign IP to RLAN clients |
CSCvd06848 | crash SNMPTask Reason:System Crash |
CSCvd07423 | AP firmware corrupt after power cycle bad mzip file, unknown zip method reboot loop |
CSCvd15404 | Rule creation with CLRuleConfigEntry crashes the controller |
CSCvc07521 | AP3800 sends A-MSDU larger than client can handle |
CSCvd25231 | Collect Stack info for silent reboot of 2800/3800 |
CSCvd33219 | AP 3800: FW hang detected - chatter: wl1: fwHangDetect(357): FTR! |
CSCuz16883 | Address registration issues for mobility scenarios |
CSCva68921 | WISM2 reaperWatcher got stuck on DP0 while retriving crash and crashed |
CSCva77707 | AIR-CT5508 SSO ARP request out redundancy management sent with wrong MAC |
CSCva79367 | Cannot add or delete Syslog Servers To WLC |
CSCvb44979 | WLC Local EAP with 7925 Handshake Failure |
CSCvc04089 | 2700 series AP radio resets reason code 71 RADIO_RC_NO_REPORT |
CSCvc12594 | Controller fails to send SNMP when using untagged interfaces on different ports |
CSCvc78510 | 2702 aux port goes to disabled after the ap is rebooted |
CSCvd53765 | After restarting WLC NMSP goes down on CMX |
CSCuz70879 | MAP reloads on hitting 40 mins timer even when it is downloading image |
CSCva06617 | 8.3Beta :Globally configured ATF mode not applied to newly joined AP2700 |
CSCva20342 | WGB uses incorrect MAC while trying to setup BA |
CSCva31890 | MIB table bsnMobileStationPerRadioPerVapTable has no data |
CSCva39537 | 802.11h configuration not saved after restoring config backup |
CSCva40580 | 8.3:BulkSync on active wlc never completes and is stuck in 'in-progress' |
CSCva83802 | HA: SSH on redundancy management interface rejected |
CSCva91483 | AP2700 failing co-channel fairness with Samsung S5 |
CSCvb11778 | 8.1.131.18 WLC crash on sisfSwitcherTask |
CSCvb48354 | RRM Not updating as per configured on WLC |
CSCvb57779 | APs unable to join WLC in different subnet through gateways with proxy-arp disabled. |
CSCvb61023 | DHCP Option 82(remote-id) not present is some AP |
CSCvb81940 | Vlan tagging for external module removed from Ap after upgrade to 8.3.102.0 |
CSCvc39231 | SNMP GETBULK on cLIpsecProfileTable returns with No response from controller |
CSCvc68156 | Full support for "distance" on AP1572 |
CSCvc79811 | When adding/removing country codes 2.4GHz channels change |
CSCvc83490 | Redundancy Mobility MAC does not stay, Primary WLC's MAC is always set instead |
CSCvd09240 | Local-auth EAP-TLS win10 not working |
CSCvc62277 | 5520 crashes on running rrm commands on task emWeb |
CSCvc85328 | AP1832/1852: Power injector/Normal mode inspite of power supply by AIR-PWR-C |
CSCvd15394 | 3800 AP will reject login for login credentials with childer ~ in password |
CSCuz77859 | Flexconnect: AP specific DHCP-NAT-PAT config does not apply in the WLC |
CSCvb12026 | Client Load Balance export to Anchors Fails with New mobility enabled |
CSCvb51570 | WISM 2 crashed on upgrade to 8.3.102.0 with Task Name: spamApTask6 |
CSCvb89781 | 2700-B AP unable to join WLC: Unable to create temp dir "flash:/update" |
CSCvb97383 | WLC deauthenticating roaming client with idle timeout |
CSCvc33793 | WLC tears down connected AP due to unequal loadbalance between SPAM queues high load |
CSCvc83175 | VWLC does not learn client IP / Client stuck in DHCP_REQD |
CSCvd00067 | wired WGB client is removed from parent AP's association table |
CSCvd18025 | anchor1 wlc does not free client sessions after client roaming to anchor2 wlc-client entries stale |
CSCvd21155 | WLC Crash when multicasting traffic and accessing WLC GUI |
CSCvd21969 | AAA AVC Override - AVC profile retained after roaming |
CSCvd41350 | 83mr2-8500 crash osapiReaper fatal condition at broffu_fp_dapi_cmd.c:4574 |
CSCvd56671 | WLC Crash : Task 'apfMsConnTask_0' in 8.3 MR2 |
CSCvc94524 | 2800/3800 iphone & android phones are not getting ipv6 addresses |
CSCvd00289 | 2800/3800 capwapd init unsuccessful creating 2 capwapd causing WCPD watchdogd reset |
CSCuz45986 | CWA not working on 8500 as Guest anchor with Accounting enabled |
CSCva66176 | AP drop of from Network due to large set of Mobility groups in down/down |
CSCva95121 | Stale IP route left on Flex AP config if booting up in standalone mode |
CSCvb13666 | WiSM2 crash with Task Name 'IPv6_Msg_Task' |
CSCvb15871 | aIOS not forward broadcast multicast frames with dynamic vlan |
CSCvb16806 | 5500 MC showing stale connections from MA clients |
CSCvb33076 | WLC: GUI does not allow to change sniffer channel |
CSCvb96009 | WLC Crashed on emweb task on 8.3.102 |
CSCvb99468 | AirOS WLC crashed in emWeb when serving an EmWebForm exclusion-list |
CSCvc66352 | 5500 controller crashed with taskname emweb |
CSCvc74515 | 8.2.121.11/8.2.124.15 : WLC Data plane crash due to fragmentation |
CSCvc78546 | WLC sets Zero 11e QoS for downstream voice traffic when CAC is disabled |
CSCvd39346 | 2800/3800 WCPD slow memory leak |
CSCvd49909 | Kernel panic @ ClientCapabilitiesTracker virtual address invalid |
CSCvb91652 | PMIPv6 Sluggish cli/gui response as well as sporadic lack of snmp response |
CSCvc23724 | WLC crash with EoGRE Heartbeat and skip count configured with value 0 which makes tunnel dead |
CSCvc65568 | 8821 fails 11r FT roam with "Invalid FTIE MIC" |
CSCvc82053 | The nmsp info/probe notification queue is saturating |
CSCvc82376 | EAP-TLS certs and PMK cache are missing on Flex AP after reload |
CSCvd12057 | Flex AVC : Downstream QoS marking not working - 8.3 |
CSCvd56064 | Flex local switching, local auth not supported when PMF is enabled in 8.3.114.22 |
CSCvd61701 | SSH to Standby RMI or Service port Fails |
CSCuq05475 | Controller GUI shows AP's NAT IP instead of private |
CSCvb12565 | WLC stops working when running 'show run-config' command with no APs |
CSCvd48333 | Controller stopped working : emWeb |
CSCvd63242 | Click AP not associating with 11r client in flex connect mode |
CSCux83260 | BGL-Alpha: "lbs-ssc" &" sha256-lbs-ssc" missing in WLC web UI |
CSCva85361 | WLC losing IPv6 Connectivity |
CSCvc41438 | WGB running 15.3(3)JD WGB takes ~500ms longer to scan DFS channels vs JBB |
CSCvb35865 | AP2800 crash for flexconnect-Sensor-Flexconnect |
CSCvc83465 | 8.3MR1: 3800 AP sometime stops sniffing on DFS channel |
CSCva64515 | %SPECTRUM-3-CA_LOGMSG: SPECTRUM LOG: invalid radio type |
CSCvc40267 | WLC sends wrong VLAN for AAA overriden client re-associating to AP belonging to FlexConnect Group |
CSCvc74507 | Fix incorrect commit of CSCuu59589 in 8.0-mr |
CSCvd27065 | EAP-FAST EAP-Chaining on Wired 1810W port does not work |
CSCvd58664 | AP dropping EAP packets on Radio which is seen on Wired uplink |
CSCvd56422 | Error cause 403 generated for 'RFC-3576 Disconnect-Request' |
CSCuz03702 | New mobility:Wired client behind WGB fails to pass traffic after roaming |
CSCva66489 | 11r sess timeout after reassoc causing Deauth 17 mismatch FTIE |
CSCvb94413 | 2800/3800: Fix DAA |
CSCvb97656 | Unexpected reload: Task Name: mmListen on 8.3.102.0 |
CSCvc28168 | WLC set ZERO 802.11e QoS UP for part of the downstream voice packets and APs trust it |
CSCvd06993 | Upgrade to 8.3 requires to reconfigure DNS server IP |
CSCva49263 | 802.11r re-auth failure after roaming |
CSCvb05494 | Wrong format of SNMP trap - mobility flap alarm |
CSCvc09824 | AP2800 band select stats counter show zero |
CSCvc18670 | WLC: Client stops passing traffic on DHCP Reqd. WLAN after sending a Reassoc request but no DHCP pkt |
CSCvc50436 | WGB wired client randomly stuck in the DHCP_REQD state after layer 2 roaming between the controllers |
CSCvc52093 | WLC send deauth 17 to phone in 4-way handshake |
CSCvc65641 | WLC reports tracebacks reported very frequently but no crashes |
CSCvd07215 | AP1810/2800 doesn't learn DHCP lease time from DHCP server and defaults to 24hr. |
CSCvc12566 | New transfer upload command for uploading bundled wlc log files |
Solved! Go to Solution.
05-22-2017 06:24 AM
Mitch, EoL doesn't matter. End of software maintenance is October this year. Also, if the bug is on the WLC side Cisco would still need to fix it. The 8821 has had some buggy software up until now. (and still does compared to the 7925g)
05-22-2017 06:22 AM
I'm going to upgrade tonight. I'll have more information tomorrow as to if our 7925g phones work or not.
05-23-2017 07:03 AM
Genesis IT-
So far so good on our 7925g phones with 8.3.114.74. We're running phone firmware 1.4.8.4.LOADS to an 11.5 CM environment. I do know that earlier code like 1.4.4.xx on the phones doesn't work for us. We're also using PEAP to RADIUS with CCKM enabled FWIW.
07-17-2017 11:14 AM
Just wondering if you still experienced 7925 one-way audio and registration issues on 8.3.121.0 or 8.3.121.4? We upgraded our 8540/8510 to 8.3.121.0 and 8.3.121.4 (esc image) a couple weeks ago and we still have random one-way audio on 7925s and phones appear as "rejected" in CUCM and say "Configuring CM List" on the phone screen. Debating on moving back to 8.3.112.2 (esc image). Unfortunately, we have to support AeroScout RFID and 2802 APs together in our environment, so anything older than 8.3.112.2 is not an option.
07-17-2017 04:36 PM
I'm running 8.3.121.4 on a pair of 8540 and the 7925G phones are not able to join CUCM, however, an 8821 is able to. Weird.
07-18-2017 10:57 AM
Cisco TAC was able to reproduce the problem that we are having with 8.3.121.x. From their testing and packet captures, they were able to see that TCP packets from CUCM were being dropped by the controller and the phone just kept re transmitting TCP. This was causing our phones one-way audio and deregistering from CUCM. TAC is going to file a new bug with their development unit, but in the meantime, they have suggested we roll back to 8.3.112.7 (esc image). If you have 7925/8821 and 2800/3800 APs and need version 8.3.x, I would NOT recommend ANY of the 8.3.121.x train due to the VoWLAN problems we've experienced. I hope this may help out others that might be having the same issues.
07-18-2017 05:12 PM
Right-o. Thanks for the update. Rated the post so others can take notice.
Kindly update us with the Bug ID when it's available.
07-19-2017 07:13 AM
Downgraded our controllers back to 8.3.112.7 last night and so far this morning, 7925s/8821s are operating as intended again.
The BugID they created for our VoWLAN issues on 8.3.121.x is CSCvf29221 but it's not yet publicly available.
07-19-2017 10:32 AM
Does anyone know if the 8.3.112.7 image contains the fix for the 3800s randomly dropping location information to the Aeroscout location engine? I'm currently running 8.3MR2 because of this but finding that we are running into the one-way audio with the 7925s in the areas with APs attached to that controller.
On a side note, I'm glad TAC was finally able to identify the issue, the case I had opened on this issue unfortunately didn't go anywhere.
07-19-2017 10:55 AM
Genesis IT. Describe your RTLS issue some more. Do you just see that doing a 'show rfid detail < mac address > the 3800s don't report a value randomly? I haven't noticed 8.3.112.0 having RTLS issues, but I just have a few at my desk. Our entire hospital is now on 8.3.112.0 as of yesterday, but our new hospital clinics with 3800s won't over for a few more weeks.
Also, thanks for pointing out that one-way audio issue early. I didn't see it when you did, but when we jumped to 8.3.121 it was horrid. We lasted a day and had to roll back like you did. My tac engineer took all of my captures up to the BU and they could duplicate the problem.
I can't believe that an MR2 release we can't run because a Cisco phone won't work with a Cisco network. *sigh*.
07-19-2017 12:01 PM
KDavison, the issue we were experiencing was tied to the Aeroscout exciters and the tags not beaconing correctly. I don't have the exact details as our Aeroscout environment is managed by someone else, but essentially when they were testing the new deployment, at times the location engine wouldn't register that they had entered a patient room like it should (we use Stanley Critical Alert that ties into Aeroscout). Apparently this is fixed in the MR2 code but breaks voip - I ended up configuring a spare 5508 with the MR2 code and moved only those floors that need this feature over to it while leaving the rest of the hospital on my 5520 running 8.3.112.0.
I'm somewhat glad to hear I'm not the only one that had the issues. I will say that the 8.3.114.74 code doesn't have the one-way audio problem as "bad" as .57, but it's still there.
BMHanson - thank you for the info, I may need to investigate and see if I can get my hands on 8.3.112.7 as the info for CSCvd69992 definitely sounds like what I was experiencing on the 3802s.
Thank you everyone for the input, it's greatly appreciated!
07-19-2017 10:58 AM
From the sounds of it, you might referring to bug CSCvd69992 which is actually fixed in 8.3.121.0, but then you still have the same problem I have (CSCvf29221) with VoWLAN with 8.3.121.x code. The release notes that TAC provided me yesterday on 8.3.112.7 indicates that CSCvd69992 is fixed on 8.3.112.1 Special Build so therefore it's also included in 8.3.112.7 Special Build. We haven't even been 24 hours yet on 8.3.112.7, but we no longer are having 7925/8821 one-way audio and de-registering issues that we had on 8.3.121.x. We also have around 146 2800 series APs and haven't experienced RFID/AeroScout issues either on the special build. Just from my experience the last few weeks, if you have 7925/8821 + 2800/3800 AP + AeroScout RFID in your environment, 8.3.112.7 is what seems to work for us so far.
07-21-2017 05:54 AM
Comment removed.
07-21-2017 05:57 AM
My SR is 682572370 with associated bug CSCvf29221. I'm not sure why TAC wouldn't provide you with a 8.3.112.x train...it says right in the CSCve20123 bug details that "This bug does not affect 8.2, 8.3.112.0 or 8.4 - only 8.3.121.0."
From my experiences with our VoWLAN problems, I would not recommend any 8.3.121.x release for anyone with 7925s/8821s. The bug we discovered in 8.3.121.x CSCvf29221 is a new bug in which TAC can easily replicate in their lab (the WLC is not forwarding TCP ACK from CUCM). The bug you mentioned CSCve20123 is actually fixed in 8.3.121.4. That bug never affected us anyways as we do not use CAC/AVC, but TAC had us upgrade to it only to find out we still had VoWLAN problems w/ one-way audio and phones not registering, hence the new bug was logged.
Like kdavison007 said, I can't believe this is a MR2 release. I'm thinking Cisco might have to make 8.3.121.x a deferred release and hope they fix all of these VoWLAN problems with 8.3MR3. In the meantime, I strongly recommend going back to 8.3.112.7 until a new 8.3 MR is out.
07-21-2017 04:10 PM
Thanks for the SR number.
I've asked TAC to provide me with the latest escalation release for 8.3.112.X and he's looking for it.
Going to see what he will provide on Monday.
