8.3MR4 Interim Availability
pbaragur
We're pleased to announce that Interim software 8.3MR4 CCO version 8.3.140.0 is now posted on the Forum as well as CCO. Please refer to the release notes for details.
 Obtaining Pre-Release Software
  1. Please fill software request access form for 8.3MR4 Interim: http://cs.co/83Mr4Access
  2. Once above step is completed, access to all supporting materials and pre-released software will be made available to Cisco Beta Customers within 24 Hours at http://cs.co/83Mr4Image
[NOTE: Please make sure to use Aspera Client to download files, if downloading for the first time from shares.cisco.com you will be prompted to install Aspera Client on top of Website]
In order for us to track found issues or simply comments or questions you must submit each initial feedback or bug via Feedback form through provided link: http://cs.co/83Mr4Feedback
Note: The 8.3MR4 release is expected to be posted on CCO  by end of February.
Resolved Caveats:
CSCuz85056    Modifying IP mode from DHCP to Static does not change for a scenario
CSCva27809    Cisco 1850 reboots when joining the Cisco WLC from standalone mode(VAP start failure)
CSCva98597    Emweb task stuck at 100% CPU usage
CSCvb72084    8.2.121.11/8.2.124.15 : Unexpected reload: fatal condition at broffu_fp_dapi_cmd.c
CSCvc07521    AP3800 sends A-MSDU larger than client can handle
CSCvc78347    Cisco 1832 AP stops working in WLAN when voice traffic transmitted through
CSCvc86951    Cisco 1850 AP beacon missing or corrupted during downstream traffic test
CSCvc89971    Cisco WLC msglog shows AP is being contained on slot 1
CSCvc98310    Cisco 1830AP: 2.4-GHz radio stopped working at @0x009915D7
CSCvd20251    Data Plane stopped working on Cisco 5508 WLC running 8.0.140.0
CSCvd28645    AP sending RTS at 6 data rate when data rate 6 is disabled
CSCvd54154    All Cisco 1850 APs connected to master AP unexpectedly reloads in a loop due to watchdog reset
CSCvd54750    Cisco 7500 WLC on 8.4.2.15 reloads unexpectedly in ideal state with TaskName:spamApTask7
CSCve00464    Cisco 1852 APs detect high noise level on 5-GHz radio for every channel except the serving one
CSCve10751    Clients cannot assocate with AP after changing from DFS to non-DFS channels during CAC
CSCve15860    CAPWAP data(client)traffic arriving before first Keepalive, keepalive was getting dropped
CSCve18213    Foreign WLC leaks IPv6 and IPv4 multicast client traffic out of EoIP tunnel
CSCve35938    Dual DFS detection implementation on Cisco 2700, 3700 APs
CSCve49772    Multiple APs running 8.5 release reload unexpectedly due to Assertion failure
CSCve57121    Cisco 3800 AP is not passing traffic
CSCve61049    Radio resets in Cisco 2700 AP
CSCve64066    AP is not joining the controller when for first time IP is changed from DHCP to static
CSCve70752    SNMP issue: Tx power level returns null causing Cisco PI, WLC sync to not update AP information
CSCve75022    Cisco WLC does not apply QoS tag upstream from foreign to anchor
CSCve79470    Cisco Wave 2 APs sends RADIUS message directly even if Local Authentication is disabled
CSCve81183    Cisco 2800, 3800 APs - Rx hang in 8.2.154.17 release
CSCve81269    Clients failed to get connected to the Cisco AP in Flex mode with message as AID already in use
CSCve96870    WCPD out of memory; AP-COS reloads, or fails to send auth or DHCP response to client
CSCvf04412    Cisco 2800/3800 AP acting as ME stopped working due to watchdog reset (OOM) after 23 days of up time
CSCvf05427    Cisco 2800/3800 AP cannot use the RX-SOP
CSCvf07776    Cisco 2800, 3800 AP - FIQ stopped working due to firmware core dump loop
CSCvf10157    Cisco WiSM2 stopped working with emWeb in 8.5.1.183 build
CSCvf12582    Cisco 8.2 release: AP failing NDP Rx causing FRA to misbehave
CSCvf16302    Flash on lightweight IOS APs gets corrupted
CSCvf23079    CAPWAP_HA-3-AP_TEMP_DB_ADD_ERR in standby WLC when changing CAPWAP mode continuously
CSCvf31881    Cisco 2800 AP detects Intel Dual Band Wireless-AC 8260 as rogue client/AP
CSCvf44583    Cisco 2800, 3800 APs transmitting at MCS/802.11n rates to clients with WMM disabled
CSCvf51131    DHCPv6 stateless not working
CSCvf57360    Cisco Wave2 AP clients constantly deleted with active voice traffic and optimized roaming enabled
CSCvf57588    Cisco Wireless LAN Controller - standby WLC reloads unexpectedly at HA Config Sync Task
CSCvf68648    Dataplane reloads unexpectedly when using EoGRE tunnel
CSCvf71789    Client traffic to local resources go through when the client is in WebAuth reqd state
CSCvf75275    WLC local EAP-TLS authentication with Cisco Unified Wireless IP Phone 7925 handshake failure
CSCvf76274    Cisco APs can no longer join the WLC; CAPWAP-3-DTLS_DB_ERR
CSCvf80409    AP1815 not sending all traffic after period under load
CSCvf81919    Cisco 3800 AP stops working: selipc causing double free
CSCvf83391    Cisco 8.3 Release: AP reloads unexpectedly at TAMD ap-tam process
CSCvf83404    VLAN override on RLAN with FlexConnect Local Switching does not work
CSCvf84540    Cisco 3700 AP: radio d1 reset: Tx jammed, probably beacon was not really sent by Hw
CSCvf84715    AP loses config and NAND disk error messages are seen on console
CSCvf85016    Cisco 1142 AP running 8.0 release facing ping loss
CSCvf86148    Cisco 3800 AP reloads unexpectedly while running 8.3.124.40 code
CSCvf93914    AP 3702 5GHz radio constantly flapping
CSCvf95036    Cisco 1850 radio firmware reloads unexpectedly at 0x009A4859
CSCvf96532    WLC anchor commands are missing from the backup
CSCvg00507    Cisco 3700 AP reloads unexpectedly- PID 104: Process "LWAPP Rogue Monitoring process"
CSCvg04467    Client SSID switch: the RADIUS IPv6 traffic does not go out of WLC port
CSCvg07438    AP3800: Low throughput due to packet drops in AP in both fragmented and non-fragmented packets
CSCvg08001    Cisco WiSM 2 reloads unexpectedly on task name spamApTask3 8.2.151.0
CSCvg18366    hostapd deleting client entry when client goes to FWD state in WCPD
CSCvg20743    The client RSSI/SNR is shown as unavailable when connected to 2800/3800 APs.
CSCvg21263    CIAM Alert: GNU dnsmasq DNS Reply Heap Buffer Overflow Vulnerability
CSCvg24597    WLC management VLAN zero in kernel causing reachability issues
CSCvg24833    Cisco 1530 AP in WGB mode reloads unexpectedly on associating with root
CSCvg24954    AID audit should persistent even after reboot
CSCvg25199    Copy cores commands returns syntax error if AP hostname contains (
CSCvg25773    Cisco 7510 WLC on 8.2.151.0 reloads unexpectedly with TaskName:spamApTask7
CSCvg27361    Adding "switchport voice vlan x" causes wired phone not to pull an IP address.
CSCvg27599    Cisco WLC reloads unexpectedly sometime when client switches between FT enabled SSID and CCKM SSIDs
CSCvg28378    AP: cmd timeout AP radio reloads unexpectedly in 8.6 due to Rx hang
CSCvg29907    AP 3800/2800 8.5.107.61 AP sending wrong BSSID in the Request,Identity packet
CSCvg32087    Cisco 5520 WLC reloads unexpectedly on Task Name: nmspTxServerTask
CSCvg32924    SNMPTask (module:k_mib_cisco_lwapp_local) causing memory leak in 16B buffer
CSCvg34444    IW3702 WGB one way broadcast traffic on 5 GHz (but good in 2.4 GHz) in a MESH network 1572 AP
CSCvg35115    Cisco 3802 running 8.3.130 shows radio core without the crash file
CSCvg38669    ERROR-MeshSecurity: Processing EAPOL from CAWAWP, Mesh mode is not started
CSCvg38681    FlexConnect APs WLAN-VLAN mappings inheritance is lost when a WLAN is deleted from AP group
CSCvg39960    Cisco WLC reloads unexpectedly on task - sntpReceiveTask
CSCvg40792    Client global IPv6 not correctly mapped to MAC address under certain conditions
CSCvg42682    Key Reinstallation attacks against WPA protocol
CSCvg44078    WLC unable to timeout clients; stale client entries
CSCvg46125    Cisco WLC reloads unexpectedly multiple times
CSCvg46620    Dataplane watchdog timeout due to NBAR max flows exceeded
CSCvg46708    Cisco 5508 WLC reloading due to memory leak in Anon Pages emweb
CSCvg49007    APIC-EM PnP Status as "Error" when should be "Provisioned" for 2802I & 1852I on Release 8.3.132.0
CSCvg49532    HA : "config service statistics" not synced
CSCvg50082    Prevent unexpected WLC reload related to CSCvf87731
CSCvg53640    Cisco 1830 AP Triggered FW assert for radio failure (beacons stuck)
CSCvg57548    Beacon stuck observed on radio 0
CSCvg59338    NMSP drops observed in high density deployments
CSCvg60452    aIOS and flex standalone failure on FT-dot1x authentication or M3 RSN IE
CSCvg60758    Cisco Wave 2 APs drops TCP retransmit from server
CSCvg62039    False radar detection on AP 1832 with 40MHz CW
CSCvg62359    Cisco 2800, 3800 APs: Click scheduler 0 stuck at Sched/FSys:1/0 Epoch
CSCvg63216    WLC RFID queue breached with more than 4000 tags.
CSCvg64993    WLC mDns secure printer service response missing TXT record with mDNS snooping enabled
CSCvg66702    OUI Update failure and WLC System reloads unexpectedly while updating the OUI file
CSCvg67318    TPC version is not included in the run-config commands
CSCvg70384    Cisco 1832/1852 AP radio reloads unexpectedly at 0x009A497D
CSCvg73522    Cisco 5508 WLC reloads unexpectedly due to memory leak in snmpApPowerTrap()
CSCvg75933    Webauth related ports are not blocked by CPU ACL
CSCvg77711    System reloads at random on running mesh commands
CSCvg78101    Local EAP profiles changed not retained after it is applied
CSCvg82215    Cisco 3504 WLC undergoes unexpected silent reloads when using mGig port
CSCvg83585    APs cannot send NDP Tx on all channels and cant be found as neighbors on nearby APs
CSCvg85175    Cisco WLC reloads unexpectedly with task name spamApTask0
CSCvg85651    Management Packets are marked with wrong DSCP
CSCvg86324    WLC reloads unexpectedly with SNMP operation with Flex ACL
CSCvg89807    Silver QoS profile is assigned to RLAN when configuration is imported
CSCvg91108    WQE size constantly increasing, error messages
CSCvg91708    WLC emweb reloads unexpectedly at commandConfigSpamApAntennaMonitor
CSCvg91734    Cisco 1852/1832 AP: AP data traffic stall in HD environment
CSCvg93191    8.3.134.40: AP3800 beacon stuck when radio reloads unexpectedly with signature "B0B0"
CSCvg95268    Allow flex/bridge mode APs in FIPS mode
CSCvg97208    AP1852: Apple clients connection fails in 802.11r adaptive mode in WLAN
CSCvg97712    Cisco 1850 AP console flooded with "Total NR report Length exceeds Max Buffer Size -1067447752"
CSCvg98098    AP1852: 5-GHz radio firmware crash @0x00981CED and @0x0099010D
CSCvg98786    IOS AP DTLS flap issue seen in pre commit sanity
CSCvg99890    'config certificate generate' line of uploaded config is corrupted
CSCvh00256    Cisco WLC has multiple open ports, cannot be properly secured
CSCvh00398    WSA: Flex RADIUS Stats data parsing fails
CSCvh01089    False beacon stuck issue due to no beacon updates in WCP message Host Triggered a radio crash
CSCvh01470    Cisco 5520, 8540 : Little Endian issue while adding rules in IPtables for SNMP trap over IPsec
CSCvh05911    Cisco WLC reloads unexpectedly after enabling FIPS
CSCvh07545    AP2800/3800 Kernel Panic due to processing of RX frames before driver is initialized
CSCvh08020    AP stuck in ap: after upgrade - flashfs[0]: writing to flash handle Illegal Operation
CSCvh12768    IOS 3700 AP could not join WLC over CAPWAPv6 tunnel using DHCPv6 address
CSCvh14989    Client in RUN state on anchor with 0.0.0.0 IP address
CSCvh16615    Cisco 5520 WLC reloads unexpectedly in a loop with task nmspRxServerTask
CSCvh16970    Cisco WLC does not apply ACL Template from PI correctly
CSCvh18096    CPU ACL does not block HTTPS traffic to management interface from wired client
CSCvh21486    WLC reloads unexpectedly due to Task "apfMsConnectionTask" when MBUF debug is enabled
CSCvh23785    AireOS WLC: Multiple wireless clients failing the broadcast Key refresh (M5)
CSCvh25039    SNMP causes unexpected reloads
CSCvh25368    WLC memory leak on CDP
CSCvh27570    cLSiIdrClusterAffectedChannels OID returning unexpected values
CSCvh28179    Kernal panic with PC is at skb_release_data+0xe0/0x230
CSCvh32031    ME: Update Root CA Certificate for Mobility Express Cisco.com Software Download Method
CSCvh47521    Cisco AP decrypt failed
CSCvh49418    WSA dx-sync enabled by default on 8.3 code - ask is to disable it on 8.3
CSCvh53094    Unable to access GUI of Cisco WLC with webadmin certificates
CSCvh53814    COS Flex LS: IPv6 RA dropped with high level of multicast on wired interface
CSCvh70354    Alpha WLC: Memory Leak in radiusTransportThr
CSCvh72803    AP stops working during sh tech collection command that includes show capwap client config
CSCvh74663    IOS AP stops working during sh tech collection command that includes show capwap client config using SSH
23 Replies 23
Martin Andersen
When is the expected release date?
Hi Martin,
I have gathered the release date for 8.3MR4 will be end of January 2018
H
Hi Harris,
Could you please share from where did you get this info that 8.3MR4 would be released end of Jan ?
Prashanth
Hi Martin,
8.3MR4 is scheduled to be released by end of Feb.
Thank you for the update... We are looking forward to the release :-)
Hi Martin,
We are targeting to publish 8.3MR4 on CCO by Mid of Feb.
Hi Martin,
The plan is to publish by Mid Feb.
I can not find the 5520 image on the share? Can you please confirm is posted?
The image used for 5520 is same as 7500.
Thank you for the update, I just noticed this on 8.5 Release Notes.
himbeertoni
Is there also an 8.3MR4 Interim image available for 8510?
Yes, the image used for 8510 is same as that of 7500,5520 and 8540.
Yes, please use the image AS_7500_8_3_134_68.aes for 8510/7510/5520/8540 platforms
navitas-it
 >show boot
Primary Boot Image............................... 8.3.122.0 (default) (active)
Backup Boot Image................................ 8.3.112.0
>transfer download start
Mode............................................. FTP
Data Type........................................ Code
FTP Server IP.................................... ********
FTP Server Port.................................. 21
FTP Path......................................... /IMAGES/WIRELESS/
FTP Filename..................................... AS_5500_8_3_134_68.aes
FTP Username..................................... ********
FTP Password..................................... *********
This may take some time.
Are you sure you want to start? (y/N) y
FTP Code transfer starting.
FTP receive complete... extracting components.
Checking Version Built.
Image version check passed.
Waiting for the Transfer & Validation result from Standby.
Standby - Standby receive complete... extracting components.
Standby - Image version check passed.
Transfer & validation on Standby success, proceed to Flash write on Active.
Transfer Failure: the image is not for this model.
WLC5520
Any ideas?
