328
Highlighted
Participant
802.11 probe requests with 00:00:00:00:00:00 source mac
We're having a weird issue that I hope someone here can shed light on.
On several of our 4500 VSS pairs of distribution switches we've observed this type of log message every 6 hours:
Oct 28 11:15:06.463 EDT: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 20025 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Po40 in vlan 508
We have traced the source of these logs to one of our edge 3850 switch stacks that are running 16.3.6 code.  There are no such logs appearing on the 3850 stack however.
After placing a sniffer on the the 3850 stacks' portchannel uplink to the distribution switch 4500 vss pair, We discovered that the this odd traffic is coming from ALL of the Cisco APs connected to this stack.  The traffic in question is predominantly probe requests to other APs.
Any idea why just these 20 APs out of the hundreds that we have across our enterpirse, are performing this way, generating these malformed frames?
Thanks in advance.
John
Everyone's tags (1)
6 REPLIES 6
VIP Mentor
Re: 802.11 probe requests with 00:00:00:00:00:00 source mac
What model of APs are they ? What version of AireOS running on these AP/WLC ? All APs connected to that 3850 behaving in same manner ?
Do you have another 3850 running on 16.3.6 & not having this issue ?
If a given AP directly connect to that 3850, pls take a capture from AP connected switchport to confirm its coming from a given AP.
Rasika
Participant
Thank you very much for your reply Rasika.
To answer your questions...
AP's are AIR-AP3802I-A-K9 running this code 8.2.166.0.
All AP's on this stack are exhibiting this behavior.
We do not have any other 3850 stack running this code.
In response to your request, I took captures on a few of the AP ports and quickly realized something I had not realized before... the destination MAC addresses of these frames are the base radio MACs of the APs themselves.  The traffic is not originating on the AP switch ports, its destined there... but just to the APs of this stack, for some reason.
I will keep digging around to see I can locate the source of the traffic.
VIP Mentor
I did not have good experience with IOS-XE 16.x.x codes yet :) Running couple of stacks 16.6.4a at the moment (3802 had trouble registering after power outage with 16.6.4). Most of our 3850 still running 3.7.5E
If you could not figure it out source of these traffic, I would suggest to try different software version on 3850
Rasika
Participant
What's even more confusing to me is that these 802.11 frames going TO the base radio MAC of the AP, are encapped in an ipv4 packet going from the AP to the WLC (which is in the opposite direction to the 802.11 frames). 000 source macs.PNG
VIP Mentor
Yes, this is strange. Probe requests should not go to wire. So it could be AP side of issue.
Pls check it on a working 3850 connected AP & ensure this behavior is not there.
Rasika
Beginner
Something in that location bridging wireless traffic onto the LAN?
I can't see how the switch or its OS could make any difference to the behaviour of the APs.
Content for Community-Ad
August's Community Spotlight Awards
