802.11k in multi-controller network
AECOMpete_2
Hey Cisco,
When will the "single WLC only" AirOS requirement for 802.11k be lifted?
Also, Can you clarify what the consequences of enabling 802.11k in a multi-controller environment are? Will clients who roam across controllers fall-back to traditional roaming? Or, are the consequences something worse?
I run a large wireless network at a healthcare provider and clinical staff are using iOS devices for critical patient care and voice applications.. Enabling 802.11k is very desirable in our environment and I feel hamstrung by Cisco's current (lack of) support.
From 8.0 Configuration guide:
"• This feature must be implemented only if you are using one controller. The assisted roaming feature is not supported across multiple controllers."
Pete
0 Replies 0
