07-24-2019 01:10 AM - edited 07-05-2021 10:44 AM
I need to configure an SSID which will use 802.1x authentication for ipods corporate network.
Is there an option in cisco Wireless environment to use 802.1x authentication without the use of RADIUS servers?
07-24-2019 01:58 AM
You can use local EAP on WLC but its not recommanded from my side.
https://mrncciew.com/2013/04/21/configuring-local-eap-on-wlc/
Best case would be to use cisco ISE integrated with WLC.
Dont forget to rate helpful posts
07-24-2019 02:01 AM
We donot have ISE in our network.
I am looking for the options that I can configure along with 802.1x without RADIUS server.
07-24-2019 02:32 AM
If you dont have RADIUS then there is no other option.
07-24-2019 02:35 AM
Can static WEP be combined? Can the MAC filtering be combined here along with 802.1x?
I have the APs joining this WLC on flexconnect mode.
07-24-2019 03:40 AM
you can combine: Static-WEP+ 802.1x
more info about layer 2 and layer 3 security comptibility :
07-24-2019 05:18 AM
07-24-2019 09:58 AM
Basically, I am looking for a solution that would provide 802.1x authentication for non domain clients. So this would involve L2 security as WPA+WPA2 and Authentication key management as 802.1x without a RADIUS server. Is this solution possible?
As a second option, can I have WLC based WPA2 Personal (AES) + Client MAC Address Authentication.?
All the APs are on flex connect mode.
07-24-2019 10:03 PM
HI,
For 802.1x you need a RADIUS server else it will not work.
for your 2nd option(WPA2/AES+MAC filetr): Yes its possible but you need to enter all the MAC address in WLC locally.
FYI: The local user database in WLC is limited to a maximum of 2048 entries and is set to a default value of 512 entries.
07-24-2019 10:28 PM
Cool.
So, the Layer2 security WPA+WPA2 and authentication key management as 802.1x and mac filtering will work?
The Aps are in flexconnect mode.. Would this combination work?
I notice in the WLC footnotes that mac filtering is not supported for flexconnect APs.
07-25-2019 12:03 AM
yes you are right..
MAC Filtering is not supported on FlexConnect access points in standalone mode.
