Highlighted
Beginner
8510 WLC realase 8.1 New mobility?
Does someone know when the release 8.1 for the 8510 WLC is coming? Does it going to support the New Mobility stuff? As far as I know, Cisco was planning to include this feature back again in version 8.1.
Thank you.
Joana.
1 ACCEPTED SOLUTION
Highlighted
VIP Mentor
We have a 8510 WLC as a
We have a 8510 WLC as a foreign controller and a 5760 as a mobility anchor in the DMZ. Will this be supported?
Yes, Guest anchoring will be supported between 8510 with new mobility & 5760
We have been advised to use 2504 WLCs as mobility anchors for smaller sites. Do you think they will interoperate fine with our core/foreign 8510 WLCs?
I would think so. 2504 with new mobility, you should be able to peer it with 8510.
Rasika
*** Pls rate all useful responses ****
3 REPLIES 3
Highlighted
VIP Mentor
I believe 8.1 coming in late
I believe 8.1 coming in late April or early May.
Yes, new mobility will be there. But if you are hoping to put 5508/WiSM2/8510 as MC for 3850/3650 MA, that won't be feasible. Cisco has dropped MC functionality on these platforms starting on 8.1 code. So if you require dedicated MC, then it has to be 5760.
Still once you enable new mobility on 5508/WiSM2/8510, you can peer it with a 5760. So roaming will work between converged access & centralized (5508/WiSM2/8510) in mixed deployment.
Rasika
**** Pls rate all useful responses ****
Highlighted
Beginner
Hi,Ok, not too far then.We
Thank you for your response.
Joana.
Highlighted
VIP Mentor
Rasika
Content for Community-Ad
