Highlighted
Beginner
9800-L Trapped in GUI Wizard Loop
Our 9800-L-F WLCs arrived and I went through the basic CLI wizard to get an IP on one of the interfaces.  I chose Te0/1/0 and after getting a default gateway could ping the WLC.  I then went to the webserver and was greeted by a redirect to a /dayzerowireless url asking me for the same questions.  I reentered the management IP (which is funny considering I'm already reaching the page on that interface), and clicked next through the next two pages.  After clicking save I am returned by "success!".  However, when I go back to the webserver IP I'm once again greeted by the webredirect to the dayzerowireless webpage.  I cannot get to the main WLC screen.  I've tried rebooting with no luck.
1 ACCEPTED SOLUTION
Highlighted
Participant
In the CLI, try to disable the radio interfaces and assign your country code and then try to access the GUI again, just remember to enable your radios again:
WLC(config)# ap dot11 5ghz shutdown
Disabling the 802.11a network may stand mesh APs
Are you sure you want to continue? (y/n)[y]:
WLC(config)# ap dot11 24ghz shutdown
Disabling the 802.11b network may stand mesh APs
WLC(config)# ap country <Country_Code>
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
2 REPLIES 2
Highlighted
Participant
Highlighted
That worked. Thanks!
Content for Community-Ad
