06-08-2009 12:12 PM - edited 07-03-2021 05:41 PM
Is there anyway to assign users to different vlans with ACS/Automous AP's? I know how to do this with CUWN but not with Autonmous. Any ideas?
Solved! Go to Solution.
06-09-2009 03:21 AM
yes ,
It is possible , you can assign Vlans via radius per user.
For details - please refer user guide on cisco.com
Vinay
06-09-2009 03:21 AM
yes ,
Vinay
06-09-2009 04:35 AM
Thanks for the response. I never did find anything in the user guide but I set this up in a lab environment and was able to get it working.
06-09-2009 04:40 AM
Cool !! if that working for you .
There is full chapter in config guide dedicated to vlan assignments. Please refer
chapter 14 - Configuring Vlan from the latest config guide.
06-09-2009 04:48 AM
I must have glazed over that section, thanks for pointing it out!
