About Switch voice vlan over Wireless Bridge?
mr.marslin
Dears,
I want to do it:
C3560 --- e0 / Root-AP / Radio0 ======== Radio0 / Non-Root AP / e0 --- CISCO7911 IPPhone --- PC
Config in C3560:
switchport access vlan 10
switchport mode access
switchport voice vlan 100
Root to Non-Root only connect via ONE SSID, not muilt-SSID config!
The PC can get DHCP ip via VLAN10, but the IPPHONE cannot get the voice vlan information.
Could the CISCO AP distinguish the voice vlan or data vlan?
or I must to setup muilt-SSID between AP, then switch set the trunk?
THANKS.
7 Replies 7
Stephen Rodriguez
That would work, you only need the one infrastructure SSID. You do need to configure the sub interfaces for the VLAN that you want to pass across the link.
I would also advise that you look at the deployment guide and configure QoS across the link so the voice traffic gets priority
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Dear Sir,
So, I don't set the muilt-ssid between AP!
Just only one!
Then set the Root AP's sub-interface(on tag) link to c3560.
Is it the same on non-root ap to ip-phone?
Hi mr.marslin
DO you have your issues resolved? can you share your config for your switches ,root and non-root bridge?
Hi Xiao,
This post may give you a similar configuration what you looking for. In here vlan1 (192.168.2.0/24) is the Voice vlan & vlan6 (192.168.6.0/24) is the Data vlan. Vlan999 (192.168.99.x/24) is the management vlan & native vlan for trunk links.
http://mrncciew.com/2013/08/02/a-wireless-bridge-with-qos/
Rasika
***** Pls rate all useful responses ****
Hi Rasika,
I m try to figure it out but here is the issue i 'm facing. the bridge is up but the vlan 407 which i 'm trying to pass down from the root to the non-root site are not sucessfully. client not able to grab any dhcp.
here is my simple network topo
network(switch)-trunk--root----non-root---client
Root
APRootbridgeNCS#ter len 0
APRootbridgeNCS#show run
Building configuration...
Current configuration : 3646 bytes
! Last configuration change at 00:03:38 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname APRootbridgeNCS
logging rate-limit console 9
enable secret 5 $1$efLb$9ZkSogqdPsxPPHbjKDzyB.
no aaa new-model
no ip routing
ip domain name SP
dot11 syslog
dot11 vlan-name Native vlan 1
dot11 ssid BridgeManager
   vlan 1
   authentication open
crypto pki trustpoint TP-self-signed-1453738646
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1453738646
revocation-check none
rsakeypair TP-self-signed-1453738646
crypto pki certificate chain TP-self-signed-1453738646
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343533 37333836 3436301E 170D3132 31303330 32333030
  35375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34353337
  33383634 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B4E0 CD142CDE 72D043F9 53E42C02 66EB231A DFB66643 EDF555D6 D5E899D1
  26A8354A 5AFD0767 ED5D2CDC F0EFB35F 858AEA4E 982F7B41 5BACAB1E 367D898E
  45976884 F004A057 153340C1 85F3EF88 B3380524 FFD40E31 ADD50130 D9F25679
  1E927AC2 2A5313E7 EDF7441C 005E24D1 4BE5B0AB 3104C372 95DA1FBE 3DA68EC8
  E0590203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 144D5B4B 2779F932 A67800CC 2BA1F95A 1B9C10F7 85301D06
  03551D0E 04160414 4D5B4B27 79F932A6 7800CC2B A1F95A1B 9C10F785 300D0609
  2A864886 F70D0101 05050003 81810031 9BA6CEB5 C0433449 57ABC3BA 8B793EA6
  5CBEE20D CF831858 FD9428C5 AD02448C B16B0B09 CB675B07 5A009639 35B8461C
  1BDAA409 48C250F2 A48A4DA1 089822A8 81627865 0705C828 C029BE93 9ABF1D70
  23370EFF 2CF57969 5B163654 06E3781D 9C2DB3BA 46D37A7D 4EB85171 AABBEE57
  0D874DD8 F43F3EA4 42F03C07 BB65B9
        quit
username SPAdmin privilege 15 secret 5 $1$gP5W$WozkY1ELCLZRXIq22I4lp/
username cisco privilege 15 secret 5 $1$78Mn$W43d0RuN4XxrrEdTvtTys0
ip ssh version 2
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid BridgeManager
antenna gain 0
no dfs band block
stbc
power local -4
channel dfs
station-role root bridge
interface Dot11Radio1.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface Dot11Radio1.407
description LWAPP
encapsulation dot1Q 407
no ip route-cache
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.407
no ip route-cache
bridge-group 47
interface BVI1
ip address 192.168.7.101 255.255.255.0
no ip route-cache
ip default-gateway 192.168.7.1
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
line vty 5 15
login local
transport input all
end
noon-root
APNonrootbridgeNCS#show run
Current configuration : 3678 bytes
! Last configuration change at 10:38:15 SG Mon Mar 1 1993
version 15.2
no service pad
hostname APNonrootbridgeNCS
enable secret 5 $1$NVEP$InaBq1wYMgpii/zAnzE.7/
no aaa new-model
clock timezone SG 8 0
no ip routing
ip domain name SP
dot11 syslog
   vlan 1
   authentication open
crypto pki trustpoint TP-self-signed-1453738562
subject-name cn=IOS-Self-Signed-Certificate-1453738562
rsakeypair TP-self-signed-1453738562
crypto pki certificate chain TP-self-signed-1453738562
  69666963 6174652D 31343533 37333835 3632301E 170D3132 31303330 31363038
  31325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  33383536 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B52A 97AD2866 A783E40D 0050D441 93960196 AE65BAE9 EC989E8E 1FCF50A2
  FCFAB3B7 3AC370ED 7E299197 3B6F5C80 025A4982 53A57840 97E37230 A0E2DDB3
  470243F5 693C26DD 25208857 A0D6EFE8 22B6753A 6875C024 62A7566F 4444BA6D
  C77567C4 314BEA0E AB778111 0A6E422C 8206D9A0 49F1DB32 4E773552 052ACD0A
  F5EB0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14FE9D3D 3C7E992F E7252886 D13256C7 4BD5CCCB FB301D06
  03551D0E 04160414 FE9D3D3C 7E992FE7 252886D1 3256C74B D5CCCBFB 300D0609
  2A864886 F70D0101 05050003 81810083 5D6E3021 97756D8F 42E1F01D B2B615EE
  E36A2EBF 6AE967F6 6FC22C7D 39522857 806C8920 4C5BBD52 995DBD29 1DDFAB62
  14241267 831DEE5F F9ED159C 2EB248C6 297188E0 122FF7C6 5097D4A9 133E31BB
  98826FB0 094577CE EEADF7E9 4F4089DA 675ECF63 1FA42528 D32C8CB7 0429FA7C
  B6DE5731 02B0673E FC2D8023 4F47BF
        quit
username SPAdmin privilege 15 secret 5 $1$qU3Z$iQX5tW3HxE3PJTnull4XA1
username cisco privilege 15 password 7 151C081F0723382778
ip ssh version 2
bridge irb
no ip address
no ip route-cache
shutdown
antenna gain 0
stbc
station-role root access-point
bridge-group 1
no ip address
no ip route-cache
ssid BridgeManager
antenna gain 19
stbc
power local -4
station-role workgroup-bridge
infrastructure-client
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 47
no ip address
no ip route-cache
duplex auto
speed auto
no ip route-cache
bridge-group 1
description lwapp
no ip route-cache
bridge-group 47
interface BVI1
ip address 192.168.7.102 255.255.255.0
no ip route-cache
no ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
workgroup-bridge client-vlan 407
end
APNonrootbridgeNCS#show ip int b
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       192.168.7.102   YES manual up                    up
Dot11Radio0                unassigned      YES NVRAM  administratively down down
Dot11Radio1                unassigned      YES NVRAM  up                    up
Dot11Radio1.1              unassigned      YES unset  up                    up
Dot11Radio1.407            unassigned      YES unset  up                    up
GigabitEthernet0           unassigned      YES NVRAM  up                    up
GigabitEthernet0.1         unassigned      YES unset  up                    up
GigabitEthernet0.407       unassigned      YES unset  up                    up
Virtual-Dot11Radio0        unassigned      YES unset  up                    up
Virtual-Dot11Radio0.1      unassigned      YES unset  up                    up
Virtual-Dot11Radio0.407    unassigned      YES unset  up                    up
APNonrootbridgeNCS#wr
[OK]
switch
10G-Temp_Switch#sh run int fa1/0/47
Current configuration : 132 bytes
interface FastEthernet1/0/47
switchport trunk allowed vlan 407
switchport mode trunk
end
Hi Xiao
Since you have posted your query seperately, I have replied to it here
https://supportforums.cisco.com/thread/2254004?tstart=0
Rasika
abwahid
Level 4
Level 4
Connect non-root AP switch-port with 7911 IP phone and then connect PC with IP like daisy chain and then check.
