Highlighted
Beginner
Access point cant associate with WLC.
Dears,
I can ping for primary and secondary WLC from my indoor access point but when goto Wireless Lan Controller i didnt found the AP.
iam try ping to AP from WLC but WLC didnt ping it. please Advice how i can solve this issue knowing that i used option 43 to discover the controller
7 REPLIES 7
Highlighted
Re: Access point cant associate with WLC.
Sounds like you don't have L3 reach ability between he AP and WLC. Do you have the correct gateways configured?
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Highlighted
Beginner
where i can configure gateway the AP is LAP ??
Highlighted
VIP Mentor
Here is how you set IP address, Gateway & Controller IP address for a LAP via its console.
LAP#debug capwap console cli
LAP#capwap ap ip address
LAP#capwap ap ip default-gateway
LAP#capwap ap controller ip address
See whether in this way AP get registered to your WLC ?
By the way what is the AP model & what is the WLC model & software code you are running.
Still not success post the AP console output during this process
Refer this post to see how AP registration process works
http://mrncciew.com/2013/03/17/ap-registration/
Rasika
***** Pls rate all useful responses *****
Highlighted
Beginner
lAP model 1042
WLC model 7.0, but i have many access point with the same model and assocciated to WLC without any configuration. so why i must give the LAP static IP and static gateway and controller. please givce me ur feedback.
Highlighted
VIP Mentor
you do not want to give a static IP, since you asked how to set gateway for a AP I mentioned all those.
Post your AP console output since it is booting up, that will tells what's the reason it cannot register.
Have you enable any AP policy on your WLC ?
Rasika
Highlighted
Hall of Fame Community Legend
Can you please post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh  inventory; and
5.  AP:  sh ip interface brief
Beginner
Try doing a hard factory reset to the AP and then it should join as rest of your AP's have.
Content for Community-Ad
