11-14-2018 01:17 PM - edited 07-05-2021 09:27 AM
Hi experts,
I have a doubt and would like to be sure before making some changes.
I tried to add a license on a 5520 cluster on HA - normally this is quite simple as it is RTU system.
But I got an error message telling I can’t add licenses on the secondary WLC, and after checking I realised that the secondary WLC is the active one.
My idea is to make a reboot self, in order for the secondary (active) to reboot and let the primary become the new active, and I suppose after that I will be able to add my license.
What do you think?
Thank you
Solved! Go to Solution.
11-15-2018 03:05 AM
11-14-2018 07:55 PM
You only need to apply it to active unit.
Rasika
*** Pls rate all useful responses ***
11-14-2018 11:34 PM
Yes but the currently the active unit is the standby WLC, that inherited the licenses from the primary, that’s why I get the error message
i can’t choose on which WLC i can apply the license as it is SSO, or am I wrong ?
11-15-2018 03:05 AM
11-15-2018 04:53 AM
Yes that was what I was thinking. While doing "redundancy force-switchover" it will make a reboot of the current active one , right ? Then the standby one (primary) will become the active and the current active will reboot ?
Thank you.
11-15-2018 07:25 AM
11-15-2018 07:38 AM
Alright, thanks Scott and all.
I will go ahead and perform this process.
