03-03-2018 11:46 PM - edited 07-05-2021 08:20 AM
we have some APs AIR-AP1852E-E-K9, they have the firmware 8.2.141.0.
The last AP we got, had the firmware -version 8.4.100.0. i have downgraded
to 8.2.141.0, so that AP joined to the primary Controller.
The backup image is now 8.4.100.0.
cisco AIR-AP1852E-E-K9 ARMv7 Processor rev 0 (v7l) with 966404/639236K bytes of memory. Processor board ID KWC213001DA AP Running Image : 8.2.141.0 Primary Boot Image : 8.2.141.0 Backup Boot Image : 8.4.100.0 AP Image type : MOBILITY EXPRESS IMAGE AP Configuration : MOBILITY EXPRESS CAPABLE 2 Gigabit Ethernet interfaces
How can i switch to the backup- image to use the newer firmware ?
Is it possible to download the backup- image to a tftp- Server ?
Thanks, George
03-04-2018 04:36 PM
If you have wlc then you have to use the wlc firmware version. If you want a newer version just upgrade the wlc.
I believe is possible to download the firmware version. Try to use copy flash:firmware version tftp
-If I helped you somehow, please, rate it as useful.-
03-05-2018 04:56 AM
03-05-2018 05:48 AM
Today we don't have a service contract, it is not possible to download any firmware from Cisco.
If we would have a AP with firmware 8.4.100.0 i would try to transfer the image to a tftp. Server, so we could upgrade all APs with this firmware.
I downgraded the AP to 8.2.141.0, so the firmware is onlay in the backup- image.
We don'T have another AP with newer firmware release.
George
03-05-2018 05:55 AM
Since this is Mobility Express, if you want to upgrade, why not promote that one AP as the master and then swap the image. I would think that is way, all the other AP’s would then download that image and perform an upgrade.
03-05-2018 06:12 AM
From the WLC, issue the following command:
(WLC) >config ap image swap <AP_NAME>
Upon next reboot, the AP will use its backup image. However, it will switch it back if it finds a suitable controller running different code.
03-05-2018 06:12 AM
03-05-2018 09:33 AM - edited 03-05-2018 09:36 AM
That was the way to switch the image:
Thanks.
I Switched the AP to Mobility Express and now i can reach the webinterface.
Now I would like to upload the firmware to an tftp- Server, so i can use the file for upgrading other aps.
Tomorrow i will try "copy flash:firmware version tftp".
Is there an other way to upload the image with a transfer-command ?
@scott: We have about 15 APs, one primary, secondary and tertiary controller. This is a production enviroment, so i want to feel certain, that everything works. So i want to test in my office with reserve APs. Then I will put the image on a tftp Server and upgrade through the Webinterface of the Controller.
By the way, is the upgrade of all APs an safe transaction or is that risky job ?
George
03-05-2018 09:51 AM
