Community Live- Understanding How Multicast Works with Cisco
4701
AIR-AP2802E-G-K9 unable to join WLC 5508
Dear All,
We received new APs which are unable to contact to WLC. previously tha version was 8.2.121.14 and we upgraded the WLC firmware as per the recommendation of Cisco TAC to 8.2.131.40 and still we are getting same reponse on console when we try to connect AP to WLC:
This AP model is supported by controller version newer than 8.2.102.2!
[*08/24/2016 03:41:46.6241]
[*08/24/2016 03:41:46.6241] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*08/24/2016 03:41:46.6241] Failed to decode discovery response.
[*08/24/2016 03:41:46.6241] CAPWAP SM handler: Failed to process message type 2 state 2.
[*08/24/2016 03:41:46.6242] Failed to handle capwap control message from controller - status 4
[*08/24/2016 03:41:46.6242] Failed to process unencrypted capwap packet from 172.20.3.100
[*08/24/2016 03:41:46.6242] Failed to send capwap message 0 to the state machine. Packet already freed.
[*08/24/2016 03:41:46.6242] wtpProcessPacketFromSocket returned 4
[*08/24/2016 03:41:56.1240] CAPWAP State: Discovery
[*08/24/2016 03:41:56.1254] DNS resolved CISCO-CAPWAP-CONTROLLER.ptml.pk
[*08/24/2016 03:41:56.1254] DNS discover addr: 172.20.3.100
[*08/24/2016 03:41:56.1255] Discovery Request sent to 172.20.3.100 with discovery type set to CAPWAP_DISCOVERY_TYPE_DNS(3)
[*08/24/2016 03:41:56.1255] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*08/24/2016 03:41:56.1264] Discovery Response from 172.20.3.100
Thanks in advance!
Everyone's tags (1)
9 REPLIES 9
VIP Mentor
Pls post "show sysinfo" &
Pls post "show sysinfo" &  "show time" output from your WLC
Rasika
Hi Rasika,
Hi Rasika,
Thanks for the response. Please see attached the file having outputs of both commands.
Contributor
Simplest way is to:1. Access
Simplest way is to:
1. Access the AP via console and delete all the contents of the flash EXCEPT for the primary LWAPP image the one with the "rcvk" meaning, you should only have one file on the AP
2. Configure its original IP address
#capwap ap ip address <IP> <MASK>
#capwap ap ip default-gateway <GATEWAY>
#capwap ap controller ip <WLC-IP ADD>
3. Re-join it on the WLC :)
If is still doesn't join, download a higher version of the LWAPP image of that AP and upgrade it
Once upgraded, try to rejoin i
Re: Simplest way is to:1. Access
Hello!  thanks for this, for some reason our japanese ap's were not querying the dns name cisco-capwap-controller.  I hard coded the controller name and IP using "capwap ap primary-base <ap dns name> <IP address of controller>" and restarting capwap discovery.
just in case anyone needs it.  thanks!
Highlighted
Beginner
Re: AIR-AP2802E-G-K9 unable to join WLC 5508
Hello Muhammad Hamid Ashraf,
Have you resolve the issue, i have the same one?
thanks in advance,
Mohammed
VIP Mentor
Hi, Nidjo,
Please create a new thread and also paste the output of these commands:
from WLC: sh sysinfo
from AP: sh version
Dont forget to rate helpful posts
Beginner
Hi Sandeep Choudhary
Please find below the requested output.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.140.0
RTOS Version..................................... 8.0.140.0
Bootloader Version............................... 7.3.101.0
Emergency Image Version.......................... 7.3.101.0
Build Type....................................... DATA + WPS
System Name...................................... ZZSDC2WLC1
System Location.................................. Paris
System Contact................................... Vincent Shaal
System ObjectID.................................. 1.3.6.1.4.1.9.1.1615
Redundancy Mode.................................. SSO
IP Address....................................... 172.26.58.154
IPv6 Address..................................... ::
System Up Time................................... 372 days 9 hrs 56 mins 18 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries:AE,AT,BE,CH,CZ,DE,ES,FR,GB,GR,HU,IE,IN,IT,MC,NL,RO,RU,ZA
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +22 C
Fan Status....................................... OK
RAID Volume Status
Drive 0.......................................... Good
Drive 1.......................................... Good
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 65
Number of Active Clients......................... 7865
Burned-in MAC Address............................ 70:81:05:CF:BA:80
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 6000
System Nas-Id.................................... ZZSDC2WLC1
WLC MIC Certificate Types........................ SHA1
P# show Version
cisco AIR-AP2802I-R-K9 ARMv7 Processor rev 1 (v7l) with 1030580/712644K bytes of memory.
Processor board ID JTV2127A132
AP Running Image : 8.2.151.0
Primary Boot Image : 8.2.151.0
Backup Boot Image : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version :
Thanks in advance,
Mohammed
2800 AP model supported from 8.2.110.0.
So please upgrade your WLC to latest 8.2.166.0 to support 2800AP's.
You can refer compatibility matrix:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
***************Please rate Useful Post**************
Beginner
Thank you Vengatesa Prasath :)
Content for Community-Ad
August's Community Spotlight Awards
